Old 09-30-2017, 09:31 PM   #1
Angus242164
Angus242164's Avatar
Default Biggest injector size for chipped LH2.4 with 012 AMM?
I have a set of brand new Seimens Deka 107961 injectors, rated at 60LB/630cc/min, and I'm wondering if these will be too big to work correctly with LH2.4, with chipped ECU's and 012 AMM?
I know E85 is an option, and it is available here, but I'd prefer to stick with E10 fuels.
If they are too big, would it be worth using a 2.5 bar NA FPR with them to bring the flow down a bit?
Or would I be better off selling them, and getting something like the 440cc/min "green giants"?
The rest of the build specs are:
B230FX squirter bottom end, rebuilt.
531 head, 38mm exhaust valves and seats, mild porting.
RSI stage 2 turbo cam.
Adjustable cam gear.
Cometic MLS HG.
60/63AR T3 with ported turbine housing on machined/ported 90+ manifold.
ATP 3" V-band wastegate housing.
Full 3" exhaust from turbo to tailpipe, 2x Magnaflow mufflers, no cat.
600x300mm IC, custom IC piping.
Stock intake manifold and TB for now, may change that in future.
Fuel supply TBC, but probably a big in-tank pump and deleted external pump.
Hoping to run about 16-17psi, which should be roughly what the turbo can produce before the air starts to get too hot.
Originally Posted by Dauntless View Post
Boost FTW.
I have over 300 parts for sale to suit 100, 200, 700 and 900 series Volvo's, for more info see: http://zyrex.org/gallery/Cars/acw/volvoparts/
Updated April 21st 2016.
Angus242164 is offline   Reply With Quote
Old 09-30-2017, 10:04 PM   #2
cosbySweater
cosbySweater's Avatar
What I always did was 50lb for plump gas and 75lb for e85 on lh2.4
Old 10-01-2017, 07:55 AM   #3
DET17
Reformed SAABaholic
I'm planning to run the 42# Bosch green giants with a similar setup and TLAO chips. With a target of 250 hp for my DD, the online injector calculators select a 42# / 440cc size.
Historical TB record, if it can be believed, says many have run LH2.4 with the larger AMM; apparently the slower velocity thru the instrument "fools" the fueling tables, and the results are good.
Whose custom chips will you use?
Old 10-01-2017, 07:59 AM   #4
K9 240
K9 240's Avatar
I'm using those injectors in my 2ltr 240 on LH2.4 with TLOA chips.
I think the only problem is not the size but the spray pattern which is a wider angle cone than stock. On the stock inlet manifold my AFR's would wander constantly up and down from low 13's to 17's at idle. This was also with stock cam. On anything but idle the AFR's were ok. I could live with the idle but it failed our MOT emissions test here. If you don't have an emissions test you will be ok.
Tim
K9 240 is offline   Reply With Quote
Old 10-01-2017, 11:23 AM   #5
gsellstr
gsellstr's Avatar
Using #65 right now, have been for several years on both 91* and e85, with an 012. No issues at all.
RIP
74 144 B20
90 745Ti
Old 10-01-2017, 02:08 PM   #6
lbd94ta
lbd94ta's Avatar
I also run the same 60lb injectors with a 012 maf with an ostrich moates emulator and love it. Idle afr's are between 14.2 and 15.3....in full boost with a t3/t4 they are around 11.2 to 11.8 at 26psi
lbd94ta is offline   Reply With Quote
Old 10-01-2017, 02:09 PM   #7
lbd94ta
lbd94ta's Avatar
No corn here so strictly 93 though....
Old 10-01-2017, 07:15 PM   #8
DET17
Reformed SAABaholic
Standard TLAO chip, or "custom tables"? I thought you negotiated a custom solution from Mike.
Old 10-01-2017, 11:01 PM   #9
gsellstr
gsellstr's Avatar
I did get a custom tune to try and address issues, but those issues were car related, not chip related. Ran fine except for the knock enrichment issue, which I found out about AFTER getting the custom tunes done.
Old 10-03-2017, 05:32 AM   #10
Angus242164
It's definitely bigger than recommended, but if they'll work, I'd rather keep them and give them a try, rather than selling them to buy some 440cc injectors.
I haven't decided on chips yet, the TLAO chips seem get good reviews though.
Tim
Interesting, not a deal breaker for me though as the car isn't subject to any emissions testing, and will only see a bit of weekend use, so idle quality doesn't matter too much. I wonder if the extra 300cc of my engine would reduce the tendency for that to happen.
Good to know it can be done!
Excellent, sounds really good, and good results at 26psi on 25+ year old EFI hardware is impressive.
Old 10-03-2017, 06:41 PM   #11
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Mines 55lb/hr @22 psi and it's doesn't do anything weird
'91 744t...it's fast as phuck
