Old 10-04-2017, 11:30 PM   #1
One hundred gift baskets
Default Where do I measure the height of the head?
Having my 160 head decked tomorrow yet again, where do I measure to see how much is left?
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 10-05-2017, 04:03 AM   #2
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
everywhere you can but prefer the edges and then measure with a hairlinial? and gaugestripes?
Old 10-05-2017, 04:49 AM   #3
Tuff240
240 Ninja
Tuff240's Avatar
If you don't know how much it has been shaved before, you measure from the valve cover surface to the head surface.
-Patrick
Old 10-05-2017, 05:36 AM   #4
Thanks, this is what I was looking for
Old 10-05-2017, 08:31 AM   #5
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Yeah.. i thought that was clear..??
Old 10-05-2017, 11:43 AM   #6
I don't know if there was one magic spot to check
Old 10-05-2017, 01:11 PM   #7
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
if you want to know how thick something is you measure the thing and not another thing or? ;)
Old 10-06-2017, 07:03 PM   #8
The machinist measured it at 5.695 the greenbook says new they are 5.7563 and the minimum height at 5.7366. So it's had .061 cut off, should I spring for a thicker cometic to reduce the compression, the block has been decked too so I lost some height there as well. I'm using stock M rods , RSI 8.5-1 pistons. I guess I need to figure out the compression ratio I have now. Or should I just remove some material from the head near the intake valve?
Old 10-06-2017, 08:10 PM   #9
culberro
culberro's Avatar
CC the chamber and know what you have. Opening up the chamber near the valves removes a lot of material.
Old 10-07-2017, 11:37 AM   #10
49cc so 9.26-1 according to the calculator I used. My goals are to be able to handle 20-24 psi, does this c/r preclude this level of boost? I'm using an IPD turbo cam
