Old 10-08-2017, 05:13 AM   #1
Steerfromdarear
Default 1990 740 2.3 turbo how to get power on the cheap
Hi all great forum I'm thinking of buying a standard 1990 740 2.3 turbo. how to get power more power without internal engine work
Steerfromdarear is offline   Reply With Quote
Old 10-08-2017, 05:32 AM   #2
Steerfromdarear
What do I buy then
Old 10-08-2017, 06:16 AM   #3
centason
CNT-FAI
centason's Avatar
Buy a standard 240 2.3 turbo. You'll look normal driving around in a car not made for 90 Year olds.
How cheap we talking here? Power cost money. We talking cutting corners?
Member: TBCCS
"Democracy is also a form of worship. It is the worship of Jackals by Jackasses." -H. L. Mencken
Any forums history.
Old 10-08-2017, 07:45 AM   #4
Steerfromdarear
Would love other side on 200bhp
Old 10-08-2017, 08:06 AM   #5
Shifted
C&M '17 Survivor
Shifted's Avatar
No.
With a perfect stage 0~1 tune/overall condition and fairly tight engine you can install a manual boost valve in the system and push about 10~12psi... good for a much better kick in the seat than stock.
Beyond that is Kool-Aid, and serious coin to do it right.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"Ego is the anesthesia that deadens the pain of stupidity" - Rick Rigsby
Shifted is offline   Reply With Quote
Old 10-08-2017, 08:20 AM   #6
Ilvmetal
Ilvmetal's Avatar
0 Tune, bigger exhaust, bigger turbo and a partridge in a pear tree
1973 142 Turbo 16V build
1986 FJ60 V8 conversion "lerch"
1989 740 bunch of stuff done
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is online now   Reply With Quote
Old 10-08-2017, 08:27 AM   #7
swedish-rocket
OP can make decent power with 2.3 stock block. I can't see why he can't have a reliable 14 second car with just minor modifications. There are other cars better suited for higher performance that in the long run will cost you less. I guess it depends on how fast you want and how much your willing to work on your car.
swedish-rocket is offline   Reply With Quote
Old 10-08-2017, 08:30 AM   #8
tryingbe
Boosting along.
tryingbe's Avatar
Sell the 2.3L 740, buy a 2.3L 850 with 222hp stock.
Cheap, fast, reliable, you can only pick two. The manaul transmission on the 740 is weak.
85 GLH 367whp
00 Insight 72 mpg
Old 10-08-2017, 09:07 AM   #9
Grr baby, grr
Wow, now we're sending people to the dark (fwd) side? Just install a manual boost controller and an accurate boost gauge and don't go over 11psi. If you want more you'll need an afr gauge.
Old 10-08-2017, 10:33 AM   #10
Steerfromdarear
Thanks can your reply can you tell me power difference and a bit more details
Old 10-08-2017, 11:11 AM   #11
PromiseRing
We don't even like Volvos
7 additional hp per psi with the stock everything bro. So 12 psi on an otherwise stock car should yield you right at 200 bhp. Install 2.5” or bigger exhaust and it’ll be even faster and spool faster. Might be a good idea to fill fill 91/93 octane if you’re running elevated boost.
http://www.turbobricks.com/forums/sh...ad.php?t=56340
http://forums.turbobricks.com/showthread.php?t=107113
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
-94' M-Edition Miata-Stock with a hardtop
Past
-80' 242gt m46-
-92' 940 turbo, got for free, fixed, sold
Feedback Thread
can't replace u joints
PromiseRing is online now   Reply With Quote
