Old 10-08-2017, 06:35 PM   #1
smncutler
Default Pertronix Ignitor for JFUR 4 0231146078 vacuum retard distributor
Someone told me Pertronix 1844 was correct for my distributor, I bought it, it won't fit. I searched for the right one and nothing came up. I found an old thread on Brickboard asking the same question, with no replies. Now what?
JFUR 4 0231146078 cast iron
While we're on the subject, why is the points plate shifted and rubbing on the shaft?
smncutler is offline   Reply With Quote
Old 10-08-2017, 07:03 PM   #2
This should be the kit you want. The 078 distributor uses the same points as the D-Jet distributor and this kit fits them.
https://www.summitracing.com/parts/pnx-1847v
Post a pic of the breaker plate.
Old 10-08-2017, 07:26 PM   #3
smncutler
https://scontent-sjc2-1.xx.fbcdn.net...43&oe=5A43C6E8
Old 10-08-2017, 07:26 PM   #4
smncutler
Thanks! Or should I just convert to coil on plug? -sarcasm-
Old 10-08-2017, 08:10 PM   #5
matt b
Not to muddy the waters but I really like the Hot spark products. I just installed the exact one you need on a spare distributor: P/N 3BOS4U1 At $40, it's nice.
Link: http://www.hot-spark.com/1-volvo-saab.htm
Old 10-08-2017, 08:37 PM   #6
sbabbs
sbabbs's Avatar
I bought one on ebay for my boat distributor with vacuum advance, not sure on brand, but looks just like that hotspark one. Came from england.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 10-08-2017, 08:41 PM   #7
The top ½ of the breaker plate centers on the lower ½ with a small lip in the center. The lip can wear out which will allow it to move off center. You can remove the breaker plate and take it apart to verify if this is the problem. Just be careful of the ground strap between the 2 halves.
I've never liked the Pertronix Ignitor very much, but they have better coverage for the older Bosch distributors than the Compu-Fire kit that I'm using in my '71 142E (although I recently learned that Pertronix now owns Compu-Fire). I guess if you can't beat 'em, buy 'em out.
Old 10-08-2017, 08:45 PM   #8
smncutler
Thanks y'all!
