Old 10-08-2017, 11:49 PM   #1
bullet5150
Default where did my engine oil go.. snapped conrod
i just had a catastrophic engine failure and left stranded in the middle of nowhere.. lol
i think one of the conrod has snapped & seized the block.. the thing is.. where did my oil go..?
theres no leaks on the driveway.. no white smoke.. turbo compressor fin is clean with just a little wet (oil fumes) from the PCV... by the way the speed was 238 km/h @16psi of boost.. 😉
it sure was fun though.. but at the same time sad.. 😖
bullet5150 is offline   Reply With Quote
Old 10-09-2017, 12:03 AM   #2
PromiseRing
We don't even like Volvos
The oil? It went out the side of the block.
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Ps how nice of you to browse my thread history. Next time you want to see up my skirt just message me and I’ll send you a Polish Sausage shots
Feedback Thread
Old 10-09-2017, 12:12 AM   #3
LC4CARL
Aero challenged
LC4CARL's Avatar
That sux.
Built-not-bought: PDXdl Resto-Mod.
Old 10-09-2017, 12:53 AM   #4
cosbySweater
cosbySweater's Avatar
It happens man, my roommate back in 2004 was driving with no load and the car chucked a rod. I will say this though, what were you running for oil?
1979 Volvo 244DL 6.0/4l80e,8.8,Ms3x goldbox ecu and Mircrosquirt tcu, s366 clone.
1982 Ford Fairmont Futura, 4.8/th400, 8.8, mircrosquirt, 7665 turbo, Project Cheap Thrills
Old 10-09-2017, 12:57 AM   #5
122power
dude
122power's Avatar
140 mph. Nice.
Old 10-09-2017, 01:04 AM   #6
Cwazywazy
Cwazywazy's Avatar
When did you last check the oil?
Old 10-09-2017, 01:59 AM   #7
cosbySweater
I swear, everyone using delo on this forum for more then flushing the engine or crazy high performance is dumb
Old 10-09-2017, 11:43 AM   #8
Mogly
Mogly's Avatar
check your oil every time you pump gasoline.
El Es Juna Swap people be like "I get 19mpg !"
Mogly is offline   Reply With Quote
Old 10-09-2017, 12:19 PM   #9
One hundred gift baskets
What do you recommend since we're so dumb?
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 10-09-2017, 12:38 PM   #10
gross polluter
They see me trollin'
gross polluter's Avatar
Your mountain of logic is insurmountable.
Old 10-09-2017, 01:08 PM   #11
cosbySweater
I've had dirty engines and used delo to flush them out but I've also had 2 separate engines now that have gotten clogged oil filters from the delo, one collapsed and sent oil filter particles through the engine. I dunno, maybe I just had bad luck with it, I just stick with 10 30 now and have had no issues ever since. Only time I have ever completely destroyed a engine was from the oil filter getting clogged because from what I can tell all the deposits inside the block ended up in the filter.
Old 10-09-2017, 01:18 PM   #12
gross polluter
Definitely the oil’s fault. Had nothing to do with the clapped out engines.
Old 10-09-2017, 01:36 PM   #13
Stiggy Pop
Stiggy Pop's Avatar
I think you're assigning too much credit to the 'detergent' properties of the oil. HDEO packages don't clean solids out of a block, they suspend carbon/suit/contaminants and lead to a cleaner engine long term.
At least, that's my understanding of oil additives. I've never seen any supporting evidence for HDEO oils "cleaning" a block.
'79 242
943 pickup
Old 10-09-2017, 02:42 PM   #14
cosbySweater
Yea, I wasn't really clear about that, I think if you start with a clean engine and use delo from the start it's totally fine. But I just had extremely bad luck with it in the used engines I've had unless I would change it several times in the first few thousand miles
Old 10-09-2017, 02:55 PM   #15
gross polluter
The point that’s being made is the oil has nothing to do with you failing engines because they’re full of dirt. If an engine is full of mud to the point it clogs the bypass in the filter, running any oil will cause the same failure.
Old 10-09-2017, 03:00 PM   #16
John V, outside agitator
Is it just Delo that we're dumb for using? or are those of us using Rotella T also dumb?
"Just what KIND OF fool do you think we are?
...............................................Moe Horowitz aka Moe Howard.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 10-09-2017, 03:03 PM   #17
That IS the definition of "detergent"---hold 'junk-n-stuff' in suspension so it goes out the drain at changes.
Old 10-09-2017, 03:07 PM   #18
Well it has to be all your fault..All the experts here all say routinely that a B230 is "fine' to run up to 400+ hp on a completely stock n.a. bottom end that's been +Ted
Some contrarians say its cheaper in the long run to build a good turbo friendly bottom end..
Shirley, I could not comment.
Old 10-09-2017, 03:15 PM   #19
240240
White of Hispanic origin
240240's Avatar
My 600k mile b21ft said otherwise.
Originally Posted by alschnertz View Post
What would 240240 do?
Old 10-09-2017, 03:27 PM   #20
Stiggy Pop
Stiggy Pop's Avatar
actual photo of Delo oil in a b230... probably
Old 10-09-2017, 03:48 PM   #21
The only thing that worries me about these guys is that their Prozac/ssri smiles are a little creepy, maybe they're all on chantix trying to quit smoking
Old 10-09-2017, 08:59 PM   #22
LC4CARL
Aero challenged
LC4CARL's Avatar
Awesome!
I've used "crank case cleaner" on some of my sketchier second-hand purchases before. Dump in a quart, let it idle for 15 minutes, the dump the lot. I think it's basically kerosene or diesel fuel.
