Old 10-09-2017, 10:41 AM   #1
Tfrasca
Tfrasca's Avatar
Default AEM UEGO Wideband
As much as I loathe the thought of more gauges in my 140 (B23et + LH2.4), I need a wide band AFR reading. My last fuel mileage calculation put me at 15 mpg, without too much boosting. I don't know why it's so dismal, so I need some numbers.
I've read several threads on this, but I just want to confirm that the AEM is still the way to go. I won't try to get LH to run off the emulator - I'll just weld in a new bung for the wide band and keep the stock O2 sensor. Does this sound like the right thing to do?
The one I'm thinking about is this:
https://www.amazon.com/AEM-30-4110-U...ct_top?ie=UTF8
Old 10-09-2017, 11:23 AM   #2
turbotankshane
Do it. That looks to be a pretty good price for a 4.9 sensor, controller/gauge and bung.
I know a lot of people that swear by AEM for a wideband, I have had good luck with the innovate stuff but a lot of others have not. I haven't heard of anyone who has had a bad time with AEM.
Old 10-09-2017, 11:27 AM   #3
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Yeah that's what I have and how I installed it. Kept the regular o2 for LH, AEM for monitoring. Worked right the first time. Innovate seems to be really sensitive and hit and miss. They might be better in a laboratory environment but get finicky in old cars with not perfect ground spots.
Hello My Glorious!
Old 10-09-2017, 11:28 AM   #4
AndrewNance
Amateur hour!
AndrewNance's Avatar
That's the one I use too. No complaints. Just install it and forget about it.
'71 142
'80 245
Feedback
Old 10-09-2017, 12:21 PM   #5
Tfrasca
Tfrasca's Avatar
That's good enough for me. Ordering now, thanks.
Old 10-09-2017, 02:30 PM   #6
Marvelous3
Who engineered this?
Marvelous3's Avatar
That amazon link is just the gauge? It's missing the actual o2 sensor and the controller it looks like.
Marvelous3 is online now   Reply With Quote
Old 10-09-2017, 02:42 PM   #7
Tfrasca
Tfrasca's Avatar
Says it includes everything:
"Bosch 4.9 LSU wideband sensor and weld-in bung included PN 30-4110"
Old 10-09-2017, 04:56 PM   #8
AndrewNance
Amateur hour!
Yeah it should be everything. The AEM doesn't use that separate controller that the Innovate LC-1 does.
Mine included a gauge, two harnesses, and an o2 sensor. Maybe there was a bung in there too
Old 10-09-2017, 05:21 PM   #9
Tfrasca
Tfrasca's Avatar
Yeah it says it includes a bung, but I'll probably want to put it in the DP, which is stainless so I'll buy a new bung for that anyway.
How far from the turbo have you guys mounted yours?
Old 10-09-2017, 05:44 PM   #10
soclosenotnear
It tells you in the manual, but at least 36" down stream with turbo. I put mine about where the factory test port(?) Is on a stock turbo down pipe.
soclosenotnear is online now   Reply With Quote
Old 10-09-2017, 06:32 PM   #11
Marvelous3
Marvelous3's Avatar
That's so cheap! Maybe I've been out of it a while but I remember those damn things being like $300.
Old 10-09-2017, 10:24 PM   #12
tryingbe
Boosting along.
tryingbe's Avatar
I bought one 9 year ago for around the same price, where have you been?
85 GLH 367whp
00 Insight 72 mpg
Old 10-11-2017, 12:17 AM   #13
towerymt
the real Towery
towerymt's Avatar
I remember them being around $200 when I bought one....YEARS ago.
I never had any issues with my AEM. I retired the beige-case Innovate LM-1 to the 24hr lemons car where it worked reliably until ~2014 when we semi-retired the car.
Old 10-11-2017, 10:32 AM   #14
GTJordan
Been here for too long
GTJordan's Avatar
He may be thinking of the AEM failsafe
https://www.amazon.ca/AEM-30-4900-Wi...s=aem+failsafe
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 10-11-2017, 05:23 PM   #15
cosbySweater
cosbySweater's Avatar
Tyler, did you order it already? I bought this one because it matched the gauges, It would probably look great in your car as well
https://www.summitracing.com/parts/a...xoCYqsQAvD_BwE
Old 10-11-2017, 08:23 PM   #16
Tfrasca
Tfrasca's Avatar
Damn, I already placed the order. That would have worked pretty well in my car...
Old 10-31-2017, 01:50 PM   #17
Tfrasca
Tfrasca's Avatar
Another related question. Is there a good reason not to hook up this wide band gauge with an on/off toggle switch? I know it's going to bug me at night.
Old 10-31-2017, 02:34 PM   #18
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
No reason you couldn’t, just splice a SPST switch to interrupt 12v or ground. I don’t notice mine much anymore.
1980 242 Turbo
2004 V70R
Old 10-31-2017, 02:40 PM   #19
soclosenotnear
Not sure how your interior is on those cars or where you plan to mount it, but mine is in the left vent (940) and it never really gets my attention if I'm not looking for it.
Old 10-31-2017, 02:43 PM   #20
Stiggy Pop
Stiggy Pop's Avatar
yeah, modern gauges are a bit of a pain in a classic interior at night. I ended up making my WB 'hideable'. It's a rectangular display so I built it into the ash tray, then chopped the ash tray cover off so it could go over the gauge face and stay in place with magnets. Maybe another way to manually disappear the entire gauge... dummy blank out panel?
And people always derided SAAB for the 'Night Panel' function, in fact I've seen it included in lists of most asinine car features. I drove my first car (900 turbo) with no interior lights for months and months, and I use the Night Panel on my modern SAABs ALL THE TIME! I don't think I've ever had gauge lights not set on max-dim.
'79 242
943 pickup
Old 10-31-2017, 03:16 PM   #21
Tfrasca
Tfrasca's Avatar
Yup, this is what I was planning. Just didn't know if turning the sensor on while it's already hot might cause issues.
It'll get mounted in a panel in the center console, pretty low. It won't be too bad, but at night I hate all the lights.
Fully agree. I loved how sparsely lit this car used to be. Now with my new gauges, plus boost and oil pressure and soon the wide band and volts... it's going to be ridiculous.
Old 11-01-2017, 02:07 PM   #22
bobxyz
bobxyz's Avatar
Check with AEM. I know that there's a warning not to run without power for the Innovate O2 sensor/controller.
'85 245glt aw71 k-jet -> ms
Old 11-01-2017, 06:41 PM   #23
Tfrasca
Tfrasca's Avatar
You're right. Matt at AEM doesn't want me to run a power cut off because the sensor will fail prematurely without the heater circuit. Oh well!
Old 11-01-2017, 07:17 PM   #24
Dicktater
Stiff Member
Dicktater's Avatar
I followed this thread and bought this gauge after reading the good feedback, and installed it on a 94 940. The car ran great
when I pulled it in the shop to do the install after I was done the fuel pump isn't working.
I think welding the bung in has given me a problem.
Anyone else have this problem? .....both pumps are fairly new. ground cable was removed before welding, car has 300k on it.
Originally Posted by CaliMeatWagon View Post
I hope your treehouse gets cancer
I buy a few when foodstamps get here because I have an investment strategy.....
Originally Posted by volvo740b234/531 View Post
I smoke my weed and dream of an awesome life
Feedback >http://forums.turbobricks.com/showthread.php?t=197700
Dicktater is offline   Reply With Quote
Old 11-02-2017, 11:07 AM   #25
Uncleknucklez
bruspeed
Interesting, I suppose that does make sense, it has a removable clear face, to facilitate changing the color of the gauge, maybe just throw some tint on the clear part of it, and “smoke” out the face a bit?
