Old 10-10-2017, 07:32 PM   #1
stevencsat
Default Offset for wide wheels on a 245?
Hey guys,
I'm looking at getting some Diamond Racing wheels for my 1985 245 Wagon, and I'm unsure about the offset. My car is on IPD lowering springs and KYB shocks, and I really want to put a 15x9 in the rear. Any ideas what offset I would need to order to clear in the rear?
stevencsat is offline   Reply With Quote
Old 10-10-2017, 08:03 PM   #2
PeaceEngineered
Sarcastic Optimist
Man this question has been asked a lot try this link. It is a better search function than the board...
http://https://www.google.com/search?q=diamond+racing+wheels+site:+turbobricks&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
2006 V70R a turbo finally!
PeaceEngineered is offline   Reply With Quote
Old 10-10-2017, 09:46 PM   #3
J_Jones
J_Jones's Avatar
My setup: 91 240, fenders rolled flat, stock height. 17x9 et26 with 25mm adapters and 245/45/17. Normally no rub. Tires rub with people in the back seat or with lots of articulation. No rub with me and the wife up front going over speedbumps and in normal driving. Wheels never rub, just the tires and barely at that. I could go with a 235/40 and probably eliminate the issue.
Old 10-11-2017, 09:51 AM   #4
doucheNozzle
doucheNozzle's Avatar
No.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 10-20-2017, 10:44 AM   #5
stevencsat
Originally Posted by doucheNozzle View Post
No.
Not sure how I skipped over such a useful and well thought out reply. How did I ever get anywhere on my build without your knowledge?
Old 10-20-2017, 11:43 AM   #6
Old 10-20-2017, 11:44 AM   #7
Jack
junkman
Jack's Avatar
he knows what he's talking about
Old 10-20-2017, 03:51 PM   #8
stevencsat
By just saying no? I'm confused as to if he was saying no he doesn't know what offset I would need, or if he was saying no to my choice of cheap, wide wheels. Either way, it didn't help with my question.
Thank you, Redwood Chair for the info. I realized after I posted that the wheels only come in an 8" width or a 10" width so I went with 15x8 0 offset on all four corners.
Old 10-20-2017, 04:22 PM   #9
Ya my first response was the same number but in a bit more colorful context, but I guess the mod[s] didn't like it.
Anyway you'll need a 3mm or 5mm spacer to clear the stock car style [inward] brake vent hole lips to caliper on the front of a 240 so that'll push your offset back up a little.
Old 10-20-2017, 05:07 PM   #10
stevencsat
Is that the same situation with a 245? I read somewhere that the 240 sedan had slightly different front calipers than the wagons did
Old 10-20-2017, 09:43 PM   #11
No the only caliper differences are for the early solid rotors VS the later vented rotors.
Old 10-24-2017, 10:04 PM   #12
doucheNozzle
cheap, wide wheels.
You missed heavy and looks like you stole them off a trailer. But sure.
Old 10-27-2017, 03:24 PM   #13
stevencsat
I must have also missed the part where I asked for your useless opinion.
Old 10-27-2017, 04:24 PM   #14
PeaceEngineered
Sarcastic Optimist
One should expect all sorts of opinions when asking for help. Some good, some not, but it is your vehicle. Do as you like. Quit worrying what others think. Or if you are worried, then his advise is helpful. They are very heavy wheels, and more unsprung weight kills handling. Is that worded better?
Old 10-27-2017, 04:33 PM   #15
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
-Stephen
#mclovethesenuts
Old 10-27-2017, 04:37 PM   #16
stevencsat
I understand that everyone has opinions, but I didn't start a thread asking for opinions on the wheel choice. I simply asked about offsets seeing as how many people here have aftermarket wheels on their cars.
And the way I see it there have been two useless comments left on this thread, both by DoucheNozzle. If he feels there is a good reason I shouldn't use the wheels, maybe he should offer a suggestion for a different wheel that comes in the size that I mentioned. It's not "advice" if you're just being negative about someone else's car/choices.
Old 10-27-2017, 05:52 PM   #17
Tuff240
240 Ninja
Tuff240's Avatar
You won't last long around here if you cry and whine about every comment you get that you don't like. If you don't like it, just ignore and move on.
There are not many wheel choices for 240's until you start adapting other lug patterns. Once you start doing that, the wheel world opens up a lot.
-Patrick
Old 10-27-2017, 06:37 PM   #18
KeizerBrickGuy
Sh*t pot stirrer
The 5x108 with very little offset makes it hard. That being said. There are many useful tools and websites out there. Wheel Offset Calculator You could safely run ET10 in the rear. From what I've seen a lot of TBers run ET0. Trying to remember who all is running a 8"+ wide wheel.
Old 10-27-2017, 06:58 PM   #19
fortbrick
fortbrick's Avatar
I run et20 on an 8” in the rear with room for less offset, and -5et via a spacer up front.
You’ll need some fender rolling and getting the offset just about perfect.
Next question, why do you want a 9” wheel?
Old 10-27-2017, 07:03 PM   #20
stevencsat
Thanks. I searched a ton of forum pages, Pinterest accounts, personal build sites and the like but it seemed like everyone either still needed spacers or went with rolled fenders
Old 10-27-2017, 07:07 PM   #21
stevencsat
It's good to hear that the 8" fits well back there. I originally wanted 9" wheels just for the sake of having a little extra contact patch back there for my wagon (5.0 swapped), but I ended up going with 8" all around for the sake of finding a tire size and because I'm sure this thing will never be as powerful as I see it in my head I know the Diamond racing wheels are a lot of unsprung weight, but I don't plan on tracking the car or street racing at every light. I have a hookup on powdercoating them as well, so I think they'll look decent when it's all said and done
Old 10-27-2017, 07:07 PM   #22
centason
CNT-FAI
centason's Avatar
I'm running 225s on 16x8 ET20 wheels with no rubbing. Have to make sure your rear is centered.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Any forums history.
Old 10-27-2017, 07:13 PM   #23
stevencsat
Do you have a picture of how yours sits?
Old 10-27-2017, 09:40 PM   #24
lummert
lummert's Avatar
15x9 wheels? You have any idea if tires with 25" overall diameter exist that would fit the bill? That's like 265 mm section width.
Old 10-27-2017, 09:44 PM   #25
stevencsat
I made a mistake originally. 15x8 is what I was looking at, as there are only two 15" tires on the market that fit a 9" width
