Did you ever get the GM flex fuel sensor hooked up? I'd be curious what your gauge reading in Tunerstudio is.
I got the same Gm sensor as you did, got the part numbers from you.
It's been plumbed in and powered up since the motor went together, but for no particularly good reason I only just got around to finishing that last connection in the passenger footwell to hook the sensor wire up to the MS.
I'm just not sure if I got a weak tank of E85, or it 47 - 50% is about what it's going to read.
So far I'm going on a sample size of 1 (one) tank of E85, so I'll see if it changes next time I fill up.
