AndrewNance
Amateur hour!
- Oct 24, 2011
- Winston-Salem, NC
Take that c-clip out and it will make sense. Did you buy all of Dan's B20 turbo stuff?
You should be able to hammer the studs out and back in with no issue. I had access to a press but I ended up not using it. I didn't even have to use the big hammer
Also I need a turbo b20.
So you guys are rolling with turbo's eh? I was thinking long term about a supercharger similar to the Judson style. What were your reasons for gong turbo instead of supercharger?
Yeah I still need to get the radiator mounted but I haven't figured out how I'm gonna secure the top. I'm thinking two brackets that will bolt in the factory weld nut for the radiator and l'll just drill two holes in the lower support so that it can rest in there on top of some rubber grommets.
