Old 07-10-2019, 10:28 PM   #1
Ursan
Bored Member
Ursan's Avatar
Default RWD IPD Pegs issues.
Anyone ever have issues with these rimps getting bent or out of round?
I'm currently (for the moment) running BFG Advantage T/A 225/50R17. It almost feels like tread separation or loose lugs. I can't *see* any wobble when the car is in motion, but I can feel it.
I'm going to have my tires swapped out for Conti ExtremeContact DWS 06 225/45/R17 later this month, but was also going to have the rims checked for true and out round.
Any other thoughts?
how psi a stock can support?
Old 07-11-2019, 08:58 AM   #2
stick70
All the gauges
stick70's Avatar
I have the FWD version of the IPD pegs on my 850 and have zero issues fwiw
Old 07-11-2019, 09:03 AM   #3
JohnMc
JohnMc's Avatar
Jack it up, rotate each wheel, look carefully on both inner and outer edges (inners are far more likely to get bent). Hold something like a ruler against an unmoving part for visual reference.
If you can't see it, it's not bent enough to matter.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-11-2019, 09:17 AM   #4
Stiggy Pop
Stiggy Pop's Avatar
them there tarrs are getting fairly old now, and they came from the local recycler when I put 'em on the pegs. I'd bet it's a tire thing, not a wheel thing.
'79 242
943 pickup
Old 07-11-2019, 12:33 PM   #5
How old are your BFGs? It would not surprise me if they got out of balance halfway through their service life.
As for the DWS06s, those should fix both your comfort and sizing problems.
Old 07-11-2019, 01:26 PM   #6
Jack
junkman
Jack's Avatar
pegs are known for getting bent easily
Old 07-11-2019, 01:37 PM   #7
You would know
Old 07-11-2019, 03:49 PM   #8
Stiggy Pop
Stiggy Pop's Avatar
However old they are those things deserve a medal! I put them on in early 2013 and I think I paid like $100 for the set from the recycling yard! They were nice and quiet to drive on, too.
Old 07-11-2019, 09:20 PM   #9
Ursan
Bored Member
Ursan's Avatar
You're prolly right. As I said, they're going away end of the month. I'm fairly certain it's not the rims, but wanted to ask of the IPDs had any known issues.
Old 07-11-2019, 09:47 PM   #10
I mean, the best argument for getring rid of RWD pegs is that other wheels exist
Old 07-12-2019, 11:59 AM   #11
Jack
junkman
Jack's Avatar
You would know
you were good
Old 07-12-2019, 02:00 PM   #12
Stiggy Pop
Stiggy Pop's Avatar
pegs only look terrible on 240s. They fit a 945 pretty well!
Old 07-12-2019, 02:05 PM   #13
Ipd pegs look weird if they aren't 19s
Old 07-12-2019, 02:07 PM   #14
Stiggy Pop
Stiggy Pop's Avatar
they make them in NINETEENS?! I bet those weigh even more than the 22x9's on my XC60
Old 07-12-2019, 09:30 PM   #15
alreadyupsidedown
alreadyupsidedown's Avatar
*$100 tires from 2013*
“What could possibly be wobbling???”
Jk jk
I just replaced some tires so bad they caused the rear of the car to undulate about an inch back and forth. They still had plenty of tread. Sometimes it really just be like that, you know?
1986 245 GL
alreadyupsidedown is offline   Reply With Quote
Old 07-13-2019, 11:19 AM   #16
Stiggy Pop
Stiggy Pop's Avatar
I was at a cruise night the other week and watched a guy in a glass t-bucket come in with a rear tire wobbling the back of the car around like that. I got a good laugh out of it.
Old 07-29-2019, 12:37 PM   #17
Ursan
Bored Member
Ursan's Avatar
Ding ding, chicken dinner winnar.
The right rear tire was a blow out in process. The inner sidewall was near complete tread separation causing a wobble.
Why it didn't esplode while driving I'll never know.
Conti ExtremeContact DWS is teh sh!t.
Like butter.
Old 07-29-2019, 06:47 PM   #18
JT
Never had any issue with my RWD IPD pegs. Ran the coni DWS on them. Now that the 940 is gone I need to sell them. Happy to hea found the issue.
Bis später und gute reise!
JT is offline   Reply With Quote
Old 07-31-2019, 07:37 PM   #19
Ursan
Bored Member
Ursan's Avatar
BTDubs, I went with 225/45R17. Near as makes no difference the same diameter as 195/65R15. Speedo is spot on.
Old 07-31-2019, 07:55 PM   #20
Stiggy Pop
Stiggy Pop's Avatar
Yeah I put Conti’s on those 22s mentioned above and super happy with them.
