Old 07-11-2019, 12:35 PM   #1
fred.malmberg
Default 1971 142 as daily driver?
I lost my 1984 240 daily driver last night.
https://globalnews.ca/news/5483675/c...oquitlam-fire/
I've got my 242 project, but its too many hours away from getting back on the road
What do you guys think of a 1971 142 as a daily driver?
My commute is only 10km one way, Vancouver doesn't have much of a winter. It has a B20E with Bosch D-Jetronic and M41
Is it too much headache to keep it reliable as a daily?
fred.malmberg is offline   Reply With Quote
Old 07-11-2019, 02:00 PM   #2
Bricktothefuture
I daily drove my '79 245 20 miles each way to work for a while. Do a thorough stage zero tune up to make sure you're at a good starting point.
Wash it frequently in winter to keep the salt off, good snow tires, etc and you'll be good to go.
Bricktothefuture is offline   Reply With Quote
Old 07-11-2019, 02:07 PM   #3
Bricktothefuture
and MAN that pic of the car on fire. Sympathies.
Old 07-11-2019, 02:11 PM   #4
2manyturbos
Sorry about your 240. If I had a chance to grab a 1971 142 with M41 for a decent price, I would already own it.
Old 07-11-2019, 02:36 PM   #5
Cwazywazy
Single jingle
Cwazywazy's Avatar
It doesn't matter how old the car is, it matters what mechanical condition it's in. I put close to 3k on my '63 Ford in the span of 2-3 months no problem, but my '82 240 can barely go 1000mi without breaking something..
I don't know what I have
Old 07-11-2019, 02:44 PM   #6
fred.malmberg
I thought early fuel injection was a bit finicky?
Old 07-11-2019, 02:52 PM   #7
IansPlatinum
IansPlatinum's Avatar
I've only owned one d-jet car now.
In my extremely limited experience, it seems to be like most other injected cars, just open loop and analog. So an exhaust gas analyzer is a useful tool to tell if you're running lean or rich.
The injectors are often ancient and super clogged, even if they work. Get em cleaned.
There's a knob on the computer to adjust overall mixture.
The fuel pumps apparently are a trouble area, as well as fuel relays. I'd replace both preemptively.
Rent a gas pressure gauge, set the rail to 29.8 psi.
Bellows on intake hose often gets cracks.
General B20 stuff to also look out for is cams, pushrods, valve adjustments, fiber gear, seals, etc.
I think the greenbook has test procedures to see if any sensors are faulty if the car acts up.
I bought my D-jet car barely running. But it still ran, impressively.
After much needed attention and diagnostics, it runs good. I'd prefer a carb'd 140 being a mechanical engineer and all.
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 07-11-2019, 03:24 PM   #8
2manyturbos
Trust me on this, you would not prefer a carburated 140. They constantly need to be tuned and produce nowhere near as much torque as the fuel injected version does.
Old 07-11-2019, 04:47 PM   #9
alschnertz
Enough already!
alschnertz's Avatar
I loved daily driving my '72 144 (1993-2006) and '70 145 (2006-2015) year round in CT. Both cars were simply unmodified well maintained drivers. CT winters ultimately did them both in due to rust.
They were my favorite go-to cars and I used them as often as possible for any occasion. They were not fast, handled like a typical early '70s car, were noisy, comfortable and reliable.
Both were SU HIF equipped and I disagree with another poster that said they needed "constant" tuning. Did it take some time to get them sorted? Yes, of course. I had to undo all the "fixes" that previous owners and gas station mechanics did. Once that was done, they really didn't give me much trouble.
Ran the 144 from 132,000 to 240,000 miles and the 145 from 99,000 to 198,000 miles.
Old 07-11-2019, 10:17 PM   #10
JohnLane
Sorry about the torched 240.
142E will have flurry of arms steering. Lots of front end bushings, balljoints and the like that are forever just itching to wear out.
D-Jet is great when it works well.
I'd reach for a Corolla or Camry for reliable inexpensive transport.
Old 07-11-2019, 11:33 PM   #11
c1800
“There's a knob on the computer to adjust overall mixture.”
The knob only controls mixture at idle.
142E sounds good, without knowing more about the prospective acquisition you’ll have to check it out thoroughly. The d-jet is fairly easy to get running properly, just takes some time getting yourself up to speed and checking all the components. And yes, they run very well.
Old 07-12-2019, 12:15 AM   #12
Jack
junkman
Jack's Avatar
I daily my 122
Old 07-12-2019, 02:01 AM   #13
planetman
planetman's Avatar
We have at least a 100 customers with 142E/144E/145E, 164E, 1800E and 1800ESs with D-jet fuel injection that use their cars regularly and a good portion use their cars as their daily drivers here in Southern California.
I call the D-jet system dumb but reliable, but you have to meet it half way by having an engine in good condition. That means cylinder compressions above 140 psi and a camshaft without badly worn lobes. It's also important to use at least a 180°F coolant thermostat.
It can be expensive to replace or repair some of the parts, but all of the components can be serviced or replaced when there is a failure.
I have a lot of NOS D-jet parts, but most of the time my customers cars get parts that are still available new, used or rebuilt.
Eric
Torrance, CA 90502
Old 07-12-2019, 09:29 AM   #14
fred.malmberg
Thanks for the feedback and encouragement. Hopefully I have good news Saturday.
Old 07-13-2019, 07:58 AM   #15
summer_sky
summer_sky's Avatar
I have no advice, however, you have my sympathy and condolences for your 240. I hope the perpetrators were caught and held responsible!
Good luck finding a suitable replacement.
"humility advances Life's ambitions" - Unknown
"There is no reward for settling for something you do not want." - John Mellencamp
summer_sky is offline   Reply With Quote
Old 07-14-2019, 07:20 PM   #16
fred.malmberg
Good news .. I have a new car now
Its a 1971 142E. I picked it up on Saturday and drove home 500km without incident.
Somewhat unique in that it has rally gauge instrument cluster.
It has been repainted, has some rust but not terrible given its age.
Interior; headliner, door cards and dash excellent conditon. Leather seats especially drivers poor.
Mechanical a solid driver, so that's a good starting point.
It came with Virgos with fairly wide tires so handles well when on country roads
Time to dive into DJet and all the other things to learn to bring this to a solid stage 0 for starters.
Old 07-14-2019, 07:37 PM   #17
sksmith
sksmith's Avatar
Congratulations!
Now post some pictures of the new beast.
Steve
Old 07-14-2019, 09:18 PM   #18
summer_sky
summer_sky's Avatar
Congratulations! Good lick and have fun getting to know your new car!
Old 07-15-2019, 09:59 AM   #19
IansPlatinum
Nice. One thing to note is do not do the seafoam / water / chinese water torture treatment on D-jet cars. The vacuum sensor diaphragm is supposedly sensitive to the seafoam procedure and can get damaged.
Old 07-15-2019, 10:42 AM   #20
fred.malmberg
OK .. here are a few photos.
I barley had time to get home before going out of town for work early Sunday morning, so didn't have time to take more photos.
The first two photos are mine, the last one was from the craigslist add
Note the photos hide a lot of the rust/flaws.
Old 07-15-2019, 10:46 AM   #21
IansPlatinum
Score. 1971 is the best looking year IMO
Old 07-15-2019, 12:35 PM   #22
sksmith
sksmith's Avatar
Very nice!
Steve
Old 07-15-2019, 02:31 PM   #23
stick70
All the gauges
stick70's Avatar
Awesome score, I'm jealous.
Old 07-15-2019, 04:26 PM   #24
2manyturbos
That look like a great score. The red paint color is rare.
Old 07-15-2019, 06:01 PM   #25
summer_sky
summer_sky's Avatar
I concur with the others..... NICE SCORE!!
