Old 10-21-2018, 01:13 PM   #1
Arn02
Arn02's Avatar
Default The Euromurican; a 242 with an M60B40
So a few years back I made the 245 GT. Unfortunately I no longer really had a use for it and I wanted an e30 as daily driver again. So I sold it to this character:
Who is in fact the builder of the other Dutch 245-with-m50-transplant: http://forums.turbobricks.com/showthread.php?t=329198. He sold his (again) and wanted it back (again) so he bought mine.
All the while I had this 242 which I bought little over 4 years ago. It's a '76 with b20 and 4-speed.
I drove it every now and then but I had it parked at my retired father's place and he uses it mostly for himself and to drive the grandchildren around. I used it for a holiday to Romania few years back. It was great on the Transfagarasan, one of the best roads in Europe.
It was however horrible on the highway. I have very little love for the b20. So at first my idea was to build a b230fk with bigger t for it, then I scrapped that. Then I built a b230+16V head for it..... and sold that. The main reason is that I never really got a concept for it (and I need a concept when I build a project car) other than another 242 with 16V engine.
So I bought a M60B40 from a 1995 e38 740i. I decided the concept should be an american muscle car, but completely made from european parts. Anything non-metric is banned.
The car will have an automatic, comfortable black leather seats (from a Citroen XM), airco.
And a 5HP30 5-speed automatic. It's huge. And 109kg.
And a drop bar from STS:
I could prepare the swap without the car so the last months I've spend some time building engine mounts and resealing and checking the engine.
Flat surface on sump:
Subframe with welded on spacers and centre line:
Lower mounts:
Upper mount and some pre-load:
Done and back from powdercoating:
Left:
Right:
Stuff for engine:
Engine:
Some modifications on the "bridge" that connects the cilinder heads:
Then the car finally arrived at surgery. Out with the old, hateful block:
And in with the new...
Enough space.
Front:
Making the bmw radiator work:
And the airco rad:
This is it so far. Hopefully the car will be drivable by spring 2019. I'll keep updating.
Ambitious but rubbish.
The 245 GT
The Euromurican
Old 10-21-2018, 01:47 PM   #2
Do you want to sell the B20 M45 bell housing?
Old 10-21-2018, 01:56 PM   #3
Arn02
Arn02's Avatar
Already sold.
Old 10-21-2018, 02:23 PM   #4
JW240
All idiot, no savant
JW240's Avatar
Great work, as always!
Really like the 245 too and love how it rides, curious how this will be!
Old 10-21-2018, 03:29 PM   #5
Sander
Good news everyone!
Sander's Avatar
Cool project! The M60 looks right at home in there.
Old 11-04-2018, 09:30 AM   #6
Arn02
Arn02's Avatar
Small update.
Made a strutbrace to compensate for the added torque. I will make linke to the firewall later.
Flat black. What else?
Shifter will work for sure.
Swapped motor and fitted the airco. This will work just not sure yet how.
Chow for now.
Old 11-04-2018, 10:07 AM   #7
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Rad!!
Old 11-04-2018, 11:24 AM   #8
80/20 speed parts club
Neat!
Old 11-04-2018, 12:26 PM   #9
Broke4speed
Broke4speed's Avatar
You had me at
Originally Posted by Arn02 View Post
metric
Old 11-08-2018, 09:44 PM   #10
740atl
educator monkey
740atl's Avatar
How are you going to control the 5hp30?
Old 11-08-2018, 11:00 PM   #11
stick70
All the gauges
stick70's Avatar
Hell yeah, this is badass.
Old 11-10-2018, 01:42 PM   #12
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Awesome. That fit in there surprisingly well! I would think weight-wise the engines are close? Lookward to engine management integration.
Will you be updating suspension after the swap?
2013 Audi Q5
Sold- 2006 V70R
Old 11-10-2018, 04:53 PM   #13
Walter
Walter's Avatar
M60s sound so good. Can't wait to see this finished.
Walter is offline   Reply With Quote
Old 11-13-2018, 02:56 PM   #14
Arn02
Arn02's Avatar
The engine loom is connected with the automatic. I need to plug this in and it will run. I'd have to do so wiring obviously but not there yet.
I think the m60+5hp30 is about 90kg heavier than a b230+m46. That's like having a passenger with you all the time.
Old 11-13-2018, 03:13 PM   #15
Arn02
Arn02's Avatar
So it was time to get the engine and transmission in.
The 5hp30 required a bit a massaging the tunnel. Nothing too serious though.
Room enough to get place the steering rack, or take it out if needed.
Motor mounts seem fine. Tape measure to the frame rails.
Fiited the brake pedal and tossed the clutch.
I also scored a 404 dme since the 484 from my donor has ews and is a pain.
After the engine was in, it was time to make the transmission mount.
Bolted through the hardy and used it as a spacer, and made a template to help center the drive shaft in th center bearing.
It sits fine so next are the headers.
Chow for now.
Old 11-16-2018, 01:49 AM   #16
Vol242vo
Vol242vo's Avatar
Well, this should be stupid fun.
Derek - 1980 242
Vol242vo is online now   Reply With Quote
Old 11-17-2018, 05:01 AM   #17
JW240
JW240's Avatar
Nice update!
Old 11-17-2018, 11:46 PM   #18
LC4CARL
Aero challenged
LC4CARL's Avatar
Really nice. Like the black under hood / blue body.
Life begins at 10PSI.
Old 11-18-2018, 08:57 AM   #19
Arn02
Arn02's Avatar
Thanks guys!
Yes I'm happy with it as well. I was a bit reluctant because of the boy racer-look, like the under-the-hood equivalent of carbon mirrors, but it turned out just fine.
Old 11-25-2018, 08:19 PM   #20
miguel.760ti
miguel.760ti's Avatar
This is rad, M60 sounds amazing and loves to be wrung out to high RPM.
1988 760 Turbo - garage queen, everlasting project
also
2016 Ford Fiesta ST - size small daily
1995 Ford F150 - size large daily
miguel.760ti is offline   Reply With Quote
Old 12-26-2018, 04:57 AM   #21
Arn02
Arn02's Avatar
Small update time. I have been puzzling and testfitting to get everything in the eniginebay in it's right place and connected. For the sake of it and because this is a budget build I want it all simple and elegant with the least amount of (non-necessary) work and effort. So M60 remote oil filter housing and airfilterbox have been kept. Also the relative location of the ecu's is to be the same: in the engine compartment. I won't bore you with too much text so on with the pics.
Because the windowwash reservoir is moved to the driver's side and the headlights will be connected on relays, I was able to delete the whole wiring loom on the passenger's side. The engine itself and the wipermotor will be fed from inside through a new hole in the firewall.
Made a bracket for the oil filter housing and steering fluid reservoir. Window washer reservoir is from and old bmw 2002 and is perfect for this.
I was lucky because an m54 vanos pressure line was a direct fit from the steering pump to rack. Return also connected so the power steering is sorted.
Made a new strut brace from some oval tube I have laying around. The round one didn't clear the intake manifold.
The m60 airbox (requires some sheet metal wort in the engine bay to work) and the reservoir from a 245 turbo. Not shown yet are the dryer and expansion can for the airco, and the LPG reducer. But I'm positive I'll manage to get those in too.
The ecu's in a 540/740 are in a box inside the engine bay. There is even a temp sensor and small fan inside this box. I'm making my own for the 242. I decided to put them there because I also need to put the LPG injection ecu somewhere, so that can go inside, and the wires are too short to get it inside in a way I like. The airco lines are requiring precious space.
Chow for now.
Old 12-26-2018, 12:19 PM   #22
JPS
very cool project Arno, keep it going!
JPS is offline   Reply With Quote
Old 12-27-2018, 08:15 AM   #23
pwaes
pwaes's Avatar
Very nice. What is the plan for the exhaust? 2 times through the hood?
'88 740: '92 b230ft, 90+ manifold, ported/flowed 531, t04e turbo, siemens deka 630cc injectors, TLAO chips, full 3 inch, npr intercooler and more goodies
pwaes is offline   Reply With Quote
Old 12-27-2018, 03:12 PM   #24
Arn02
Arn02's Avatar
Will do!
If only No probably 2x 2.5" to 1x 3" and then under the rear axle and out.
Old 12-30-2018, 08:35 AM   #25
reiernumans
My friends stock 245 didn't get a pass for its APK with the exhaust lobbed off behind the rear wheel (with a turn-down on it), apparently there's some regulation since about two or three years that the exhaust has to be stock length.. 75 car too, you might have to go over/under axle and finish it there, though I'd ditch the bend and muffler that usually sits behind the bumper to exit the exhaust on the left. Looks odd from the rear of the car and there's plenty of space to add a muffler or two in the remaining exhaust length.
Cool project btw! I need to show this to the 240 people I know and convince them the stock engines are too slow.. :D
reiernumans is offline   Reply With Quote
