Old 02-03-2009, 03:04 PM   #276
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
Originally Posted by frpe82 View Post
The fuel cut is going to happen when the A/D-converter max out. Between 5 and 6 volts.
Same as most other ECU's.
Some older ECU's and ECU's for B200 engines have a lower level of fuel cut though (software limited), but that is fixed with the chips.
so what? a 960 AMM and keep the pressure within ~15PSI and i should be ok?
740tankDriver is offline   Reply With Quote
Old 02-03-2009, 03:34 PM   #277
frpe82
Guest
Bigger AMM = less air reported to the ECU = less voltage.
By using an AMM suited for your application, you can run any amount of boost you like.
Old 02-09-2009, 05:46 PM   #278
boosted_nonv
can i use a ezk box from another turbo car or na to put in my 91 740turbo, its ezk isnt chippable but the ecu is, i think the number on the ecu was 580
91 740 Turbo project begins now
GeckoSquad Member
boosted_nonv is offline   Reply With Quote
Old 02-09-2009, 06:32 PM   #279
TIPSP
Got Boost?
TIPSP's Avatar
You should be able to use any of the LH2.4 EZK once you put the new chip in.
You ECU might me the same as mine (560). you have to check.
Old 02-10-2009, 02:09 PM   #280
boosted_nonv
yea it is, and thanks for the advice,
Duane
Old 03-03-2009, 06:43 PM   #281
frpe82
Guest
I have updated the last part of the first post to include some questions about EGR.
Tell me if you have any other relevant questions that might be intereting to incorporate in the same post.
Old 03-03-2009, 08:43 PM   #282
white83glt
white83glt's Avatar
will the chips you are selling work with a 760 turbo sedan auto?
id really love more boost also since this car is intercooled.
2000 toyota rav4, wifes daily
1994 850 sedan, my daily
1983 240 GLT turbo wagon, 4 speed manual w/ overdrive (sold)
1986 760 turbo sedan, auto (sold)
white83glt is offline   Reply With Quote
Old 03-04-2009, 06:30 PM   #283
frpe82
Guest
You need to be more specific.
Year and engine type please.
Old 03-04-2009, 06:33 PM   #284
white83glt
white83glt's Avatar
my bad. 1986 760 turbo, auto, intercooled. engine is b23FT
Old 03-05-2009, 06:16 AM   #285
ipdown
Член на форума
ipdown's Avatar
A bit off topic, but if someone wonders here are the pictures of B204FT TCU unit: http://linuxfan.org/~ipdown/mybrick/tcu/
ipdown is offline   Reply With Quote
Old 03-05-2009, 01:01 PM   #286
frpe82
Guest
It may be LH2.0 (or even earlier version) if you have a B230FT. I do not have chips for those.
If you can check the ECU number it would be great. Then we would know for sure.
Old 03-30-2009, 03:27 PM   #287
fsl
Which fuel ECUs can I use on the B204FT chip?
- 1997 volvo 944 lpt auto
- 1993 audi 100 2.5 tdi
fsl is offline   Reply With Quote
Old 03-30-2009, 03:32 PM   #288
frpe82
Guest
597 and 950.
Do you have another number?
Old 04-08-2009, 02:31 PM   #289
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
I'm to understand that the black EZK boxes are not directly chipable & require a daughterboard? Or is this an instance that I need to pull it & check?
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 04-08-2009, 02:41 PM   #290
JR-66
Yes, you need to pull it open and check, good possibility for chipable black boz is -119, found in early n/a 16V
Turbopower
JR-66 is offline   Reply With Quote
Old 04-08-2009, 03:40 PM   #291
thelostartof
unbalanced chemical
thelostartof's Avatar
Now that is odd, a 86 760 should be LH 2.2 with a b230ft
Old 04-08-2009, 06:01 PM   #292
frpe82
Guest
Yeah. Then it would have LH2.2, but the B23 would have an older EMS.
As far as I know, all B2x engines came with older stuff than LH2.2. This goes for Europe though (where most of them had ML1.1).
B1x engines on the other hand, can have LH2.2, but those are not sold in the US (360 sport and 460/480, ES and turbo).
Old 04-08-2009, 06:37 PM   #293
thelostartof
unbalanced chemical
If the chassis is an 86 is should be 2.2
Old 04-08-2009, 07:32 PM   #294
Ursan
Ursan's Avatar
Turns out that it is!
Bosch # 0 227 400 148 black box, chip riser perpendicular to the MoBo with a PLCC socket.
Old 04-08-2009, 11:09 PM   #295
JR-66
? chip socket is DIL type, not PLCC.
Old 04-09-2009, 08:07 AM   #296
Ursan
Ursan's Avatar
Yup, you're right. My bad. Things I learned in the 80's are slowly eroding away.
The whole board looks like the old SIP chip carrier though. Like those lasted a long time...
not
Old 05-04-2009, 12:50 AM   #297
yamahapro
Turbonetics power!
yamahapro's Avatar
can you runs megasquirt with these? do they come with rev limiters? and can i eliminate egr with them?
yamahapro is offline   Reply With Quote
Old 05-04-2009, 04:02 AM   #298
frpe82
Guest
Megasquirt and chips are two different things. Chips upgrade the stock ECU/ezk, and Megasquirt replaces the stock system entirely.
The chips for LH2.2 and LH2.4 from me still have the stock rev limit at the moment. On my chips for several of the Motronic cars (M4.3/M4.4/ME7) the limiter is sometimes changed depending on the engine used.
The chips will eliminate the EGR function, yes.
Old 05-04-2009, 10:09 AM   #299
yamahapro
Turbonetics power!
yamahapro's Avatar
so with the chips it will red line and keep bouncing off it?
and just a few more questions. do green top injectors flow enough for higher boost? and does gettinga 3 inch amm really make ur car faster just by adding it? thanks so much
Old 05-04-2009, 02:36 PM   #300
frpe82
Guest
I don't exactly understand where you are getting at, but yes.
[QUOTE=yamahapro;2423970]and just a few more questions. do green top injectors flow enough for higher boost?
For around 15psi on the 13c turbo and T cam, yes.
If you add bigger injectors at the same time it will.
