Old 01-11-2012, 06:03 PM   #76
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Took the B21 apart to see the damage that has been done by the prev owner. I think more than just running without oil happend here
Lets just hope it wont happen to "new" one
Current:|760 Turbo *White-Rice* '86|Volvo 242 |Volvo 780 86|Porsche 986 02|
My Seller Feedback
Old 01-13-2012, 04:48 PM   #77
Mr.Borrie
Mr.Borrie's Avatar
Well that got here soon! a bit hard to communicate with them, but i got the parts for the LPG injection!
Now just have to learn polish
Old 01-13-2012, 05:33 PM   #78
DennisvdB
DennisvdB's Avatar
Not that difficult, we have enough Polish people here.
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 01-13-2012, 05:38 PM   #79
Johann
Johann's Avatar
UWAGA!
Engelschsch
Johann is offline   Reply With Quote
Old 01-13-2012, 05:39 PM   #80
JW240
All idiot, no savant
JW240's Avatar
nice!
will test your JAW this weekend, too late back from 'work' every day to test it earlier.
240 | 1991 | 338K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Old 01-14-2012, 09:20 AM   #81
Mr.Borrie
Mr.Borrie's Avatar
Originally Posted by Johann View Post
Thanks!
Originally Posted by JW240 View Post
nice!
Thanks JW, JAQ will be nice for in my 360 to adjust. might also install in in this 242 for adjusting. Meanwhile i removed the old LPG system and cleaned the enginebay manually.
Also removed the frontbumper and testfitted the bodykit front bumper. I was not sure but now it was on i'm sure it will look mean once restored and made to fit. bumper sticks out too much, does the newer model 240 use shorter shocks i could use on this model?
Old 01-16-2012, 01:53 PM   #82
Mr.Borrie
Mr.Borrie's Avatar
Came home today after work when my dad told be he has been working on the 242!
Thanks dad!
Some parts he could not reach so i will have to do that with a dremel or a "vingervijl" not sure what the english deff is
He also got me this part to cut of the EGR on the exhaust manifold side ^^
Old 01-18-2012, 06:14 PM   #83
Mr.Borrie
Mr.Borrie's Avatar
Did i just dented seal?
I used a piece of wood and a hammer to tap it into the casing. but apparently i dented it.
Seem to install well and shut off but i'm not sure if it's "ok"
It seems when in doubt replace but i thought i asked anyway
Old 01-18-2012, 07:54 PM   #84
Nice job there! Looking forward to seeing how the lpg runs with a turbo engine. I like the heated work space. Sure wish I had that here.
Old 01-23-2012, 03:19 PM   #85
Mr.Borrie
Mr.Borrie's Avatar
Got some new engine mounts, rear main sail and intake manifold gasket for when i have to move it to drill holes in it.
Also got both trannys inside now. the BW55 and the AW71L.
Already parted a BW55 a while ago to put on the 144 (kept the tail)
But this got me thinking.. The 240 had at one point a electronic KM gauage. what would be involved in swapping to electronic and not swap the tails of the BW55 on the AW71L?
Some wiring, a KM gauge that works with it and the rear axle box of a later 240? prob allot of work for nothing but i'd like to know whats involved with this.
Yeah thats sort of the old dinner room adjacent to the garden.. happy parents i haz not
Old 01-24-2012, 12:51 PM   #86
Mr.Borrie
Mr.Borrie's Avatar
Did some research today on the swapping of the tails VS the swap of the rear axle.
I'll be going for the swapping of the rear axle and converting the cluster from cable to electronic.
Found a complete +86 rear axle with everything on it plus a cluster that goes with it so i'll be picking that up soon.If anybody has some more info on swapping the clusters with pics (i heard some storys but no pics)
Also i have a question regarding the rear axle, the BW55 one is not going to fit because the AW71 and the BW55 are a few cm's apart in length. Does the 700 serie axle or at least the front part fit into the rear part of the axle?
Old 01-24-2012, 06:38 PM   #87
Mr.Borrie
Mr.Borrie's Avatar
Replaced the oil trap seal and started on getting the rear main sail i messed up out of the housing..
I got annoyed with that and decided that paining the engine and cleaning up was a better way to spend my time
Old 01-24-2012, 07:49 PM   #88
Janspeed
looking good! you have earned that coffee.
Old 01-24-2012, 07:56 PM   #89
DennisvdB
DennisvdB's Avatar
As far as I know that distributor won't fit with the firewall...
Old 01-25-2012, 03:49 AM   #90
Mr.Borrie
Mr.Borrie's Avatar
what whut...
I forgot all about that! okay anyone has a link on this " block mount conversion" and the best distribitor i can take. i found a few topics on this and it seems for LH2.4 i need a 001?
Old 01-25-2012, 04:57 AM   #91
Ruben
Ruben's Avatar
All you need is the hulpas/distributor drive shaft from a 240/360 which has the gear to drive the block mounted distributor.
How did you put that rear main seal in? Looks like it has some dents/scratches on the surface as well, screwdriver marks?
A dirty mind is a joy forever
Drove:
'87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL
Drive:
Citroen C15D
Ruben is offline   Reply With Quote
Old 01-25-2012, 05:02 AM   #92
Dirk242
Take it out of your old B21. You can also you use that B21 distrubutor.
‘81 245
Dirk242 is offline   Reply With Quote
Old 01-25-2012, 05:10 AM   #93
Mr.Borrie
Mr.Borrie's Avatar
I used a hamer and a piece of wood. but somehow it got dented. I already got a new one when i picked up the engine mount rubbers, intake many gasket. 10 euro's for a Elring one. kinda steep thinking that i got a whole gasket kit for around 60 euro's at one point?
Anyway i still have no idea what the right way is of removing and installing them correctly i cannot even seem to get this gasket out
I used this but i dont know what a " white plastic thing" is this guy talks about
http://cleanflametrap.com/RMS.html
Really? do i have to look at nr's ? I think i also have 200 serie's somewhere in a box i got once. I'm thinking of looking into the wated spark thing now but i'm not sure whats more complicated. swaping to block or wastedspark?
I already have this one around when i bought a complete Megasquirt kit, used on a turbo too. Not sure of the buchaspark works with that
Old 01-25-2012, 07:26 AM   #94
Turbosteen
I was born at a young age
Turbosteen's Avatar
The original volvo rear main seal has a plastic ring on/with it to help with putting it in correctly. They are expensive, but putting them in is pretty easy.
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 01-25-2012, 07:29 AM   #95
Mr.Borrie
Mr.Borrie's Avatar
I figured if you tap it in gently it should slide in, it did just that just got a bit sideways.
Then i had to get it out again and i damaged it a bit as you can see. So it did work
I wonder if the elring one i bought has this plastic thing, its in a box.
Old 01-25-2012, 12:50 PM   #96
Arjen
You should sell me this I can send you a bock mount distributor and auxiliary shaft
Arjen is offline   Reply With Quote
Old 01-25-2012, 02:40 PM   #97
Funkee
Funkee's Avatar
And you would likely put a cap in the hole when you take the distributor timing plate off, at least if you take it off, might as well cut the shaft down. TB style.
Red valve cover looks good by the way
Old 01-25-2012, 03:23 PM   #98
DennisvdB
DennisvdB's Avatar
WTF cut the shaft down?
Boris, you also need this to block off the hole where the distributor used to be.
http://www.vomd.nl/index.php?main_pa...roducts_id=760
I'd say go with Buchka WastedSpark. That way you don't need to put in the shaft for the distributor, and the distributor itself. Plus it has better, consistent spark. Might be better for your LPG. I think what you already got for that MS setup is suitable.
Old 01-25-2012, 06:27 PM   #99
rom
rom's Avatar
Now all i can think of is pies.
Religious people scare me.
rom is offline   Reply With Quote
Old 01-25-2012, 06:55 PM   #100
Mr.Borrie
Mr.Borrie's Avatar
I have a few head that where blockmounted so i have the block off plate.
Oh and thanks about the valve cover, now matched the block too
Yeah i'm gonna look into something like wasted spark. Not sure yet how i will manage it i had one offered by someone who is not using his.
I already have those plates like i said above, it does fit over the head mounted shafts right. difference in cams is just the little cut in them for the distributor, correct?
Anyway my dad replaced the seal for me, the trick is to clean it out first. apparently it was still to dirty. This seal is allot different btw it had ribs (for her pleasure) on it so it holds the seal better down when installing so crooked it not a thing anymore with that
