Old 03-20-2019, 06:35 PM   #1
tomasss
tomasss's Avatar
Default m46 to m90 swap list
As my target horsepower is around 300hp, I am considering a preventive swap of my m46 to m90. I went through >this< topic, but as I found a guy selling the m90 today, I just want to double check what do I need to take from the donor car.
My car: '91 740 sedan b204gt with m46 (lh2.4)
Donor car: '97 940 wagoon b230fk with m90
So as far as I know:
I want to keep the single mass flywheel, so that one will be reused from m46.
Clutch and pressure plate cant be reused, I need to get it separately new.
And therefore I need:
- transmission
- shifter linkage
- gear shifter itself
- crossmember
How about the driveshaft, do I need to take it from the donor? Will wagoon driveshaft fit the sedan?
Anything else to take out?
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 03-20-2019, 07:10 PM   #2
classicswede
Volvo upgrades
- transmission
- gear linkage
- gear lever itself
- gear lever support and gaiter
- crossmember
- propshaft
- keep the bolts etc
Clutch, do you know what power level you are at?
Old 03-21-2019, 04:12 AM   #3
tomasss
tomasss's Avatar
- transmission
- gear linkage
- gear lever itself
- crossmember
- propshaft
Ok. For the propshaft, do I need the whole one or just the first half?
Stock power level is 200 engine horsepower, my target is somewhere around 300 wheel horsepower. No racing though, more likely an occasional pulls...
Old 03-21-2019, 04:50 AM   #4
Brotkasten
Jonas
Brotkasten's Avatar
You need the whole one because they are balanced as a unit. Also Mark the orientation they were in before separating.
91' 940 B230FB+T M90
Old 03-21-2019, 06:36 AM   #5
classicswede
Volvo upgrades
Best to use the full propshaft as mentioned they are a balanced unit.
Clutch if you want to keep the 228mm flywheel you are really looking at a paddle clutch or use a sachs 763 cover with a sinter plate
The other option is to upgrade to a 240mm flat flywheel and use a 850R clutch or a sachs 707 cover.
Makes sense to get the right clutch while it is all apart
Old 03-21-2019, 02:16 PM   #6
sbabbs
sbabbs's Avatar
Yeah each half is balanced separately from the other. Then they slide together. I've put different halves of different driveshaft together over the last 30 years any way I wanted and never ever had a problem. Who worked at the volvo factory and balanced both half's of a slipped together yoked driveshaft at the same time slipped together? Buehler???
Show me the machina that does that???
More BS...
Old 03-21-2019, 09:45 PM   #7
okoye
okoye's Avatar
Never had driveline issues when swapping an m90 in. You only need the front half of the shaft from the m90 car. Never been an issue for me up to north of 120.
I recommend the ttv flywheel as thatís what Iíve been running for 3 years and swear by it. I recommend a better clutch than the stock 850r one.
Old 03-22-2019, 04:25 AM   #8
classicswede
Volvo upgrades
90 odd % of the time you are fine with just the front half. The 2 halves are balanced in phase and on odd occasions you can get vibration issues. If both halves are there for the taking then it makes sense to take it as a complete unit.
I have TTV flywheels drilled ready to accept the Sachs 707 cover as a popular choice for an upgrade
Old 03-25-2019, 05:14 PM   #9
JerryJS8
der Junge
JerryJS8's Avatar
The Sachs 763 pressure plate with an 850 glt fiber disk has been holding my 16v turbo @15psi just great.
You'll like the m90, it's a fantastic upgrade!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 03-26-2019, 09:31 AM   #10
tomasss
tomasss's Avatar
Thanks to everyone, last weekend I picked her up...directly went to the pressure washer to get rid of the dirt. Now I need to collect the rest (clutch, PP, release bearing etc...) to finally dive into the swap
https://forums.turbobricks.com/showp...1&postcount=20
Yeah...unfortunately I won't be able to appreciate the change as I have never driven the m46...this car we towed to my garage
Old 03-27-2019, 06:26 AM   #11
tomasss
tomasss's Avatar
I will actually use this topic for another list - what parts should I get while going for the swap.
I will reuse the m46 flywheel combined with the 850GLT clutch and 763 pressure plate.
So far I have (front to rear):
Crankshaft oil seal
Clutch 850GLT (1862 314 032)
M90 Clutch release bearing
Clutch pressure plate (3082 999 763)
2l of transmission oil
M90 rubber mount
Rubber M90 flex plate (guibo)
Driveshaft center support + bearing
Thinking about the >pilot bearing< but found >different< opinions...
What about the clutch slave cylinder...should I replace it or just leave it as it was working fine without leaks?
Anything else to consider?
Old 03-27-2019, 07:07 AM   #12
DET17
Reformed SAABaholic
As your clutch release slave is external, you can "run until failure" and not disassemble. I always like the comfort of NOS new parts.......
Old 03-27-2019, 12:57 PM   #13
tomasss
tomasss's Avatar
Yeah, I am also mostly inclined to that...
Old 03-27-2019, 08:25 PM   #14
Bproof
Not to side track but would you sell the trans whenever you complete the swap?
Bproof is offline   Reply With Quote
Old 03-27-2019, 10:43 PM   #15
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Its real fun when the failure happens while in stop and go bumper to bumper traffic going uphill........
Old 03-28-2019, 04:01 AM   #16
tomasss
tomasss's Avatar
Yeah, it will be for sale as a complete set. Clutch + pressure plate + transmission + driveshaft.
Old 03-28-2019, 04:18 AM   #17
tomasss
tomasss's Avatar
..and back to the original topic...I bought some extra bushings...unfortunately it seems nothing is available in bronze so I just went with regular parts:
1232173 Ball Socket, Shift stick
1232165 Bushing, Shift selector block
9143298 Bushing, Gear lever
9163851 Ball Socket Clutch fork
1014858 Bushing, Gear lever Kit
Old 05-14-2019, 06:46 PM   #18
Bproof
Update or pm when you have the package ready?
Old 05-14-2019, 07:26 PM   #19
shoestring
shoestring's Avatar
Crank bushing Volvo PN1397077. Classic part but stock still available in NJ as of yesterday.
Old 05-15-2019, 02:47 AM   #20
tomasss
tomasss's Avatar
This bearing is not compatible with M90...either it will not give support to the transmission or it needs to be replaced with the M90 bearing type from retroturbo...
http://forums.turbobricks.com/showthread.php?t=324088
Old 05-15-2019, 02:48 AM   #21
tomasss
tomasss's Avatar
Man, you should PM me earlier...I already made a deal with some other guy for the whole M46 setup...
Old 05-15-2019, 08:52 AM   #22
shoestring
shoestring's Avatar
Unfortunately we HAVE the bearing from Retroturbo and IT isn't compatible with our M90. The bearing has too small an inside diameter and the bearing housing does not seat fully in the crank. We did not try to hammer it in for fear of not being able to remove it.
The 1397077 comes directly from the Volvo parts catalog.
Old 05-15-2019, 10:15 AM   #23
tomasss
tomasss's Avatar
The possibility of the first issue is known...
"NOTE: It turns out that some of the input shafts are about 0.035 mm greater in diameter than the others giving interference fit with our adapter. To avoid that, you have to sand the input shaft with sand paper until it fits with ease."
The second one I had no problem with...it went in the crank without any issue.
Old 05-15-2019, 10:19 AM   #24
shoestring
shoestring's Avatar
Hmm. Bummer.
Edit to all my posts in this thread except reference to Volvo part number (which is application correct but does not address the issue raised):
I am dumb.
