Old 04-01-2019, 06:58 PM   #1
klork
Default 740 rear 4 link?
Has anyone done a 4 link for the rear of a 740 to get rid of te weak stock suspension.
klork is offline   Reply With Quote
Old 04-02-2019, 03:54 PM   #2
jwernerny
jwernerny's Avatar
Kaplhenke Racing makes something interesting.
Start here: https://www.bneshop.com/collections/...0-900-subframe
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 04-02-2019, 06:19 PM   #3
klork
I have seen that. I would reinforce the stock piece before i did that. Its a nice piece but not spending over $500 on it.
Old 04-03-2019, 09:36 AM   #4
240wagonguy
Friend of mine is working on a bolt in 4 link for 7/9 chassis. Will likely test it on my car whenever he gets it done.
Old 04-03-2019, 10:58 AM   #5
klork
What is he doing to get around the fuel tank?
Old 04-03-2019, 12:13 PM   #6
jbab
jbab's Avatar
https://shop.klracing.se/sv/artiklar...n-740-940.html
jbab is offline   Reply With Quote
Old 04-03-2019, 02:30 PM   #7
klork
That needs more pictures to tell what is going on. Would be nice to see it bolted to the car.
Old 04-05-2019, 02:07 PM   #8
UrbanHillbilly
UrbanHillbilly's Avatar
This is probably the best system that I've seen out there, but it's still using the stock rear axle:
http://www.retroturbo.com/?product=v...r-link-kit-txr
I went up to a Ford 9" in my car, reinforced the stock subframe, and bolted the axle to the stock trailing arms.... We'll see how it plays out.
1987 Volvo 745 Project, 1978 Volvo 242 B230F+T M46, 2018 F150
UrbanHillbilly is offline   Reply With Quote
Old 04-05-2019, 02:14 PM   #9
klork
I have an explorer 8.8 that I will be putting in. I am pretty sure the stock rear end will not hold up to around 400 whp and slicks.
Old 04-05-2019, 10:00 PM   #10
okoye
okoye's Avatar
A guy I know is doing the 4 link on his 740. In order to do it properly the tank has to be replaced with a fuel cell because it would be in the way otherwise.
Old 04-07-2019, 06:41 AM   #11
klork
That's what I was wondering about. I really don't want to replace the fuel tank as this is going to be my summer daily.
Old 04-07-2019, 12:29 PM   #12
okoye
okoye's Avatar
Only other option I can suggest is swapping a mk1 Irs from a 960 sedan. A few people have done it. All the points are there 89 + with the exception of one. But it’s a mod that if you do it you can’t really go back.
Old 04-07-2019, 01:02 PM   #13
DET17
Reformed SAABaholic
Nathan did.... don't know if his 9 series still exists? I think his pics were all Photobuggered.
Old 04-08-2019, 07:35 AM   #14
klork
I have no desire to go IRS. Everything about IRS gets very expensive when stuff starts to break and you have to get better half shafts, stub shafts and center section. Been there done that.
Old 04-16-2019, 10:58 AM   #15
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
iirc nathan had an 8.8 in his car, not irs. he did a number of things with the rear suspension though.
so it all depends on what you're doing relative to what you need. a reinforced subframe and adjustable torque rods will go a looonng way. if you've got something with say.. v8 torque and sticky tires, you'll want to do some chassis reinforcements where the trailing arms attach, and probably upgrade the trailing arms. On a 7/9, the fuel tank is really kind of in the way, swapping to a spare tire well fuel tank would help the situation a lot.
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old 04-17-2019, 11:18 PM   #16
Greg Wong
John Dega had a V8 swapped 740 in One Lap of America a while back. He had a Ford 8.8, with a single ladder setup. I just have this one photo, and no more info. But it may give you some ideas.
Ford Rear
Homepage
90 245 V8
07 V70 2.5T
Greg Wong is offline   Reply With Quote
Old 04-17-2019, 11:31 PM   #17
55superbeetle
That's a torque arm style suspension. Commonly found on 3rd and 4th gen Camaro's. Pretty cool to see under a volvo, looks like a fox body 8.8 axle too.
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
