dailywagon
- Jan 14, 2016
- Michigan
Starting platform is a 1993 Volvo 240 wagon.
Automatic AW70
Factory 951 ECU, and 169 EZK
So far I have purchased:
13c Turbo
90+ Manifold
740 Intercooler
850 Turbo Orange Top Injectors
Just arriving today was a 563 ECU and 148 EZK, well it showed up looking like this:
Now I read that if you want to do a +T swap in stages you can install a Turbo ECU and EZK first. So because of how the box looked I figured I would install them to see if they were damaged like the box (not sure if I should claim insurance with USPS). Now all I did was swapped them out in the brackets (not sure if I should have unhooked the battery, oh well).
It took an second or so longer of cranking than usual, then it started and seemed to idle okay (it lobed up and down a little). I went to rev the car and it hesitated and then didn't want to rev over 1200-1500 rpm. If i work the pedal up and down quickly it will rev up very slowly to 2000-2500. Its sounds like its hitting fuel cut, or like the timing is super retarded. ( i know the turbo ecu will have a more retarded ignition timing vs factory na ecu). I pulled the turbo ECU and EZK out and put my na parts back in, and all is back to normal. starts normal, idles normal and revs normal.
Now I'm left inconclusive...
Are the ECU and EZK junk?
Did I need my orange top injectors installed first?
Did the forums lie to me and I really can't run these ECU's while na?
Should I have unhooked the battery first to "reset" everything?
Or maybe am I dumb and ordered the wrong turbo ECU's for my car?
Automatic AW70
13c Turbo
90+ Manifold
740 Intercooler
