Old 01-26-2020, 09:14 AM   #1
jim_hoyland
Default Rear window squirter How to remove/repair 240 Wagon
While waiting for a replacement squirter, I need to know how it is removed. And, would like to know if anyone has repaired one.
Mine broke off at the hatch. I have the outer part, the nipple that extended from the door to the plastic diverter broke.
jim_hoyland is offline   Reply With Quote
Old 01-26-2020, 12:41 PM   #2
As far as I recall it's a press fit into the hole. That is what my 93 has.
Old 01-26-2020, 01:22 PM   #3
TestPoint
TestPoint's Avatar
My experience is that it is not removable without serious damage. The plastic spring clips broke off when I tried. Order the entire unit and carefully retain the hose for attachment to the new one.
Ford V8 Conversion Manual -
Old 01-26-2020, 02:00 PM   #4
oleseahorse
Don't monkey with it unless you are sure that it's the squirter that is inoperable. They are available from FCP. now that I think of it they may not be available for FCP because I think I got my last squirter at LKQ.
You want to be sure that you can access the small tubing and fittings that could be clogged preventing the rear squirter from operating. Often that requires taking down some very brittle panels depending upon your model. There is a check valve towards the rear that often clogs.
Good luck
Marty
oleseahorse is offline   Reply With Quote
Old 01-26-2020, 08:49 PM   #5
jim_hoyland
Thanks for that info; The outer part got knocked off at the base. Water flows through the hose. I can feel/partially see those clips on the inside. The hose is still attached to the broken fitting. So, when water just shoots straight back.
A second idea might be to find a similar rear window squirter for a different car or model ?
Old 01-26-2020, 09:05 PM   #6
Sounds like a junkyard item to me.
Old 01-26-2020, 09:12 PM   #7
The Librarian
I just noticed that Skandix has 3 of the nozzles for earlier wagons. They're NLA from Volvo so you might want to have 2turbotoys grab them ASAP.
http://www.skandix.de/en/spare-parts...indow/1015630/
Disclaimer: I don't know if the hole in the body is the same size for the early and late nozzles.
FYI, I have a NOS early nozzle in stock if you're in a hurry to try it.
Old 01-26-2020, 10:17 PM   #8
jim_hoyland
We have it back ordered as part of the group buy, seems like it’s still on back order. Could you send me a couple of pics of your black part ?( porsche.jim@earthlinl.net )
Thanks for the added help.
Old 01-26-2020, 10:24 PM   #9
The Librarian
The later nozzles are on back order.
The one I linked to is in stock and looks like the one I have.
Old 01-27-2020, 09:18 AM   #10
oleseahorse
If you can hold on to your hat, I will be back in, argh, Chicago the beginning of March, where I have a jy squirter. We can hook up then if you are still interested.
Old 01-27-2020, 12:24 PM   #11
jim_hoyland
That top picture is the correct squirter for sure.
I’ll wait for your return, got some other glitches to clan up; seat heater, driver side door switch for dome light, and one of the console lights
Thanks all for your help,
Jim
