The Aspirator
It's a girl!
- Apr 7, 2003
- Vinemount, Ontario CANADA
This is a rebuilt engine right? Don't start it up "just to see if everything works" then shut if off again, that can be very hard on new engines. Only do it when you're ready to break it in properly, whichever method you choose to do. And MAKE SURE you have oil pressure before you even think of running it. Best method is to take your timing belt off and use a drill to spin the intermediate shaft, that'll spin the oil pump and you can watch your gauge to make sure there's pressure and no leaks. Another great way is to take a stock oil pump drive gear, grind off all the teeth, weld a hex head to the top, and slap it into the engine. Then you can use the drill to spin the pump without having to mess with your timing belt or remove the rad/fan to gain access. A worse, but completely acceptable way, is to just crank the engine with no fuel/spark until you have pressure.
Ohh and in case I haven't mentioned it yet, make sure there's oil pressure.
