Old 09-02-2011, 01:32 PM   #151
KyleH
If anyone can help, please do.
KyleH is offline   Reply With Quote
Old 09-03-2011, 09:05 AM   #152
Walter
Walter's Avatar
Whoa! Awesome stuff!
My family lives in Hafnarfjörður, so they're not far from you. Good to see an Icelander on the board!
Walter is offline   Reply With Quote
Old 09-07-2011, 06:43 AM   #153
JoiOK
Originally Posted by KyleH View Post
JoiOK- I am considering doing a similar swap as you but I am planning on using the Mark VIII's 4R70W.
I have a few questions:
Why did you select the tremec?
Would you see any problems using the 4R70W?
Did you investigate swapping over the IRS? What conclusions did you come to? I was hoping to use the mark viii's diff housing with a supercoupe posi and 3.27 gears. Then I was (again hoping) to make new control arms and use coil overs at or near the factory shock tower mounting points and of course add some mounts to the rear subframe for the control arms.
Did you use the Mark VIII brakes? If not, did you consider swapping them over? Again I was hoping since the hubs are 5x108 to be able to use the Mark VIII brakes on the front and just machine some brake brackets to adapt to them.
What were the big sticking points for the swap?
This car my mom bought a few months after I was born, then my grandma bought it and now it may come to me. It just so happens I supercharged a Mark VIII when I was 17 and that was my daily driver in high school.
Actually I didn have thee Mark VIII, I bought the motor and trans locally, and it had already been pulled out of the car. It was supposed to be put in a 96 Mustang, but the guy sold the pony, so he had no use for this engine and trans and I got it cheap. At the time I was also thinking about puting in an IRS from 96 Cobra, but it was sold when I made my decission so i´ll be using a 9" Ford. About the big sticking points... I would say relocating the brake master cylender and brake booster to clear the head was the worst headache.
What supercharger did you use on your old Mark? I´m also considering some kind of forced inductin, but dont know if I go turbo or supercharged.
Volvo 240R '88 - 4.6l 32V V8 Supercharged/Tremec 3650 (In The Making)
Volvo 855R '97 - B5234T4/M59 (The ServiceCar)
JoiOK is offline   Reply With Quote
Old 09-14-2011, 09:15 AM   #154
KyleH
I used a Paxton Novi 1000. If the choice is between a centrifugal supercharger or a turbo, its turbo all the way. A centrifugal is much much easier if you have the space in the front. Its also cheaper most likely.
A turbo will move the start of the power band lower, make power sooner, be much easier to upgrade when you want to make more power, be easier to turn up boost to make more power, allow you to make more boost, etc. etc. The motor is already a higher RPM motor and having then centrifugal supercharger really made that more so. I've never been a big fan of roots superchargers because of price vs power. Turbo turbo turbo. Also the Mark VIII cam profile I think lends itself a bit more to the higher boost a turbo would put out but that's not really by a huge margin. In fact the Mark VIII cam profile is most similar to the Mach 1/03-04 Cobra except slightly less lift.
96 Cobra didn't have IRS. All mustangs had their garbage 4 link suspension with solid axle until 2004 except the 03-04 Cobra. In fact except for control arm length, control arms are interchangeable from 1979 to 2004. That said I wish this Mark had a 4 link and solid axle, its much much much easier to retrofit even if it's not very good.
I purchased a 1993 Mark VIII this past week for $2200. It has 58,000 miles 3.73 gears, posi, cobra brakes with upgraded calipers and rotors, 18" cobra wheels, and a piggyback chip in the ecu. Gotta love Florida, these things are everywhere.
I took a gander at the brake booster and master cyl in the Mark VIII just now and while smaller than the OEM Volvo I think, it looks significantly larger than the one you used. What years Mustang had that brake booster?
Old 09-14-2011, 10:51 AM   #155
doucheNozzle
doucheNozzle's Avatar
This really isn't true at all. It can be. It depends on what kind of turbo it is. It depends on what kind of blower you're using. You can't say the above as a 100% statement.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 09-15-2011, 01:02 PM   #156
badvlvo
Bad for Babies
badvlvo's Avatar
01 Cobra was IRS but NA motor. One-year suspension, no Cobra for 02, then revised design for 03-04 model years.
Died at age 35
Old 09-16-2011, 02:26 AM   #157
KyleH
When housing sizes are chosen even semi properly (No huge A/R diesel exhaust side or something of that nature) for the same power, when compared to a centrifugal as stated, it is.
Also, heh, guess you'd, heh, know that if you weren't, heh, being, condescending with your emoticons.
This is correct. The 99 had IRS as well. The V6/GT mustangs were all solid axle through 2004 and as stated before they were mostly garbage due to the suspension binding and causing wheel hop.
Old 09-20-2011, 05:27 AM   #158
JoiOK
Yea... Its true, the IRS i was thinking about was from 01 cobra, not 96 like i remembered... If I remember correct, this hydraulic brake booster came from 03 GT mustang,
Old 09-20-2011, 07:47 AM   #159
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Old 09-20-2011, 03:49 PM   #160
KyleH
You mentioned blowers, here's the Mark VIII I had. You can see the blower kit and DIY meth injection. If you're running unintercooled, meth injection is the way to go. You get all the throttle response and I had sub ambient IATs after a run. This kit cost about $120 or so to build and I used windshield washer fluid. The non detergent kind is just straight water/meth. In America you can get material safety and data sheets (MSDS) on all chemicals to verify their composition. I'd imagine iceland has something like that too)
http://www.youtube.com/watch?v=0fczKsPb0Gk
I have to sell a bunch of stuff in that silver tent to make room for the Volvo which is currently at my grandparents (as my grandma owns it).
Can't say I'm not serious though:
Old 09-23-2011, 08:10 AM   #161
Aronsson
Aronsson's Avatar
Really nice car ! Love it ! :D
Volvo 780 B6304F 24V Project , 740 GLE 1990
Aronsson is offline   Reply With Quote
Old 12-21-2011, 06:52 PM   #162
JoiOK
This was dropped in today....
Vortech V2 supercharger kit (with air to liquid intercooler etc) for 96 - 98 Cobra, it came off a stock engine and was dynoed 482 RWHP...
Next up is putting the 9" Ford rear end and new brakes aaaaand building the engine....(and more)! powerstuff!
Old 12-21-2011, 08:11 PM   #163
D123GT
sweet i want one haha your def going to need some bigger tires now
1987 760 turbo sold
R.I.P 1996 960 saved three lives
sold 1967 123 GT sold
sold 1998 C1500 sold
sold 1998 S70 sold
sold 1991 740 SE Project car
1978 Trans Am Project
1997 960 sold
2002 s80
D123GT is offline   Reply With Quote
Old 12-24-2011, 05:16 PM   #164
JoiOK
Test fitting......
Old 12-25-2011, 12:15 AM   #165
SR.William jetronic
Good lord, I think i just had an aneurysm. I cant imagine how good that thing will move air with all those valves. That is if you ever get that turbo to spool...
SR.William jetronic is offline   Reply With Quote
Old 12-25-2011, 12:33 AM   #166
DNAsEqUeNcE
†John3:16
It should spool, it's belt driven.
Old 12-25-2011, 12:41 AM   #167
doucheNozzle
What valves? And that's a supercharger.
Old 12-25-2011, 12:49 AM   #168
DNAsEqUeNcE
†John3:16
the 32 valves.................... guy
Old 12-25-2011, 12:49 AM   #169
doucheNozzle
I guess I was confused by his statement
Old 12-25-2011, 12:57 AM   #170
DNAsEqUeNcE
†John3:16
it happens
Merry Christmas, Dawg.
Old 02-04-2012, 07:05 PM   #171
KyleH
Is it up and running? I bet you'll eventually want to turbo it.
Old 02-04-2012, 08:25 PM   #172
2fast242gt
Do you have a cobalt?
No reason to turbo it that s/c will realy make it scooot!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 02-04-2012, 08:29 PM   #173
Pro Sneaker Peddler
Yes. Bet you anything the stock axle and Virgos will not be able to handle that
Old 02-05-2012, 10:23 AM   #174
KyleH
I completely agree. He will still end up wanting a turbo. Its just the natural progression to insanity.
Old 02-06-2012, 05:30 PM   #175
JoiOK
No, nothing has been done yet, first we need to build the motor for the boost.
But we were actually looking at turbo setup when we came across this vortech, but it is just close to impossible to install turbos in the car without building the front end from tubes, because there is absalutely no room for turbo manifolds.
But about the axle, we will be installing a 9" ford and definitely some bigger tires
