Old 06-12-2017, 07:22 PM   #1176
LC4CARL
Aero challenged
LC4CARL's Avatar
Momma is still making noise about moving to DC. Mid '90's and stormy there this week. Bleh. I like the cool green of the PNW. Though I could literally do a coast to coast road trip in the DL. That in itself might justify moving. About 3000 miles +/-. If it's not winter, I think I would pack my tent, take a few weeks, and run across Hwy 2 or 94 so I could see my dad in Michigan. Maybe tint the windows. I better get on this...
Life begins at 10PSI.
Old 06-12-2017, 08:49 PM   #1177
What should I pay at the PNP? $100?
I've got the STS bushings in and a Homer short shifter coming. Are there any other bushings in the shifter? It's pretty loose.
She's only truly bad when cold. Although the noise in 5th gets pretty annoying after a while.
Ya hop in your time machine and go back to 1995, and that's what they'll be.
Old 06-12-2017, 11:24 PM   #1178
LC4CARL
Aero challenged
LC4CARL's Avatar
1995 eh? If only I had bought Intel back then...
Old 06-12-2017, 11:29 PM   #1179
LC4CARL
Aero challenged
LC4CARL's Avatar
The reman alternator is in! While pushing the four new bushings in I found that there was only one in the adjuster tube where it bolts to the front of the block. Found a longer bolt and we're golden. Fired it up and the voltmeter was a bit higher than usual. Hmm. The DVOM says 14.6v. Sounds good to me. Pretty sure the head lights are brighter. Probably wishful thinking, but that would really be a nice. Plus, chicks dig small alternators and fused batteries circuits.
Old 06-12-2017, 11:49 PM   #1180
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
According to you chicks dig all sorts of stuff
B5.5 passat wagon, low af sexier than most wagons here.
Old 06-13-2017, 09:45 AM   #1181
LC4CARL
Aero challenged
LC4CARL's Avatar
Just not my deodorant apparently...
14.6v isn't too high is it? I can't recall what the top end of the normal range is.
Thx.
Old 06-13-2017, 09:01 PM   #1182
MrBrown
You like popsicles?
MrBrown's Avatar
Chicks dig bags.
I know this for sure.
GhettoFab build thrizzie
Old 06-13-2017, 09:02 PM   #1183
MrBrown
You like popsicles?
MrBrown's Avatar
Thx.
I usually get 13.8v cruising and about 12.4 when the efan kicks on
Old 06-13-2017, 11:40 PM   #1184
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx. I'm hoping a little more juice will help my slow wipers (with good ground to motor).
Can't wait to see you guys at the show. When you meet the Mrs., be sure to tell her that I'm a very serious guy on the forum...
Old 06-14-2017, 11:48 AM   #1185
Jelloshark
Jelloshark's Avatar
Carl, would you want to write us a script so we say the right things about how serious, cool, and what a big shot you are on the boards? I'd hate if I didn't do you justice.
Jelloshark is offline   Reply With Quote
Old 06-14-2017, 11:53 AM   #1186
LC4CARL
Aero challenged
LC4CARL's Avatar
Hmm. On second thought, this may be one of those situations were the less that is said the better.
Old 06-14-2017, 01:43 PM   #1187
cwdodson88
You look like a serious forum goer and that hat, gotta head to panama for one of those.
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-14-2017, 02:40 PM   #1188
Marvelous3
Who engineered this?
Marvelous3's Avatar
That's in the good range for charging. Should be around 14 volts at idle if it's charging. The amount of charging voltage will depend on the state of the battery and how hot it is outside. Hotter = less charging voltage generally.
Old 06-14-2017, 02:56 PM   #1189
Cwazywazy
Single jingle
Cwazywazy's Avatar
14.6 sounds perfectly fine to me.
I don't know what I have
Old 06-14-2017, 04:52 PM   #1190
LC4CARL
Aero challenged
LC4CARL's Avatar
Excellent. Thx!
Old 06-14-2017, 04:53 PM   #1191
LC4CARL
Aero challenged
LC4CARL's Avatar
Can't wait to try the wipers and lights!
Old 06-14-2017, 04:55 PM   #1192
LC4CARL
Aero challenged
LC4CARL's Avatar
They only give those out a funny-hat secret society meetings.
Old 06-14-2017, 06:31 PM   #1193
I had my chance to rat him out at Davis but I bit my tongue.
Old 06-14-2017, 08:42 PM   #1194
LC4CARL
Aero challenged
LC4CARL's Avatar
You were a gentleman and a scholar. But your dog peed on my tire.
Old 06-14-2017, 09:36 PM   #1195
She couldn't do that.
Old 06-14-2017, 10:19 PM   #1196
LC4CARL
Aero challenged
LC4CARL's Avatar
It's true. Made a clean spot. Threw off my whole "patina."
Or maybe it was Harland.
Old 06-15-2017, 01:06 AM   #1197
Ya Harry likes to mark his territory like that.
Old 06-15-2017, 10:25 PM   #1198
LC4CARL
Aero challenged
LC4CARL's Avatar
Intermittent wipers.
Raise the stalk for the front and nothing happens. Switch the rear to the left and nothing happens. I saw that IPD sells a relay and it got me thinking. Where is this relay located? Does the one relay control both wipers?
Thx.
Old 06-15-2017, 11:40 PM   #1199
MrBrown
You like popsicles?
MrBrown's Avatar
It's down by your left foot under the carpet and this odd metal plate
Old 06-16-2017, 01:11 AM   #1200
LC4CARL
Aero challenged
LC4CARL's Avatar
Cool. Thx!
