Old 05-08-2008, 10:31 AM   #1
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Default What (e-bay) Catch Can to get?
There are many cans on ebay, just would like to get your thoughs on wich one to get?
ebaylink
Thanks
Old 05-08-2008, 11:15 AM   #2
gale
gale's Avatar
I will tell you this out of experience. The little red and black cans suck ASS!!
• They are small (a little bigger that two cans of pop stacked on each other).
• The openings in/out are too close to each other (defeating the purpose of a catch can).
• All the hardware is cheap and the tube they supply is about a foot long.
• They also ding you on the shipping (about20 bucks to Canada).
I ordered one and now I am making my own. Go to your local hardware store and you could get all the parts you need yourself. Then head to a metal supermarket and get some sheets of metal and weld them together with the shape that you want. Easy and cheap.
"never rub another mans rhubarb"
gale is offline   Reply With Quote
Old 05-08-2008, 11:18 AM   #3
Mr.Borrie
Mr.Borrie's Avatar
Hmm always good to ask, really that bad huh, too bad i kinda liked the red ones but now ill stay away from them
Old 05-08-2008, 11:34 AM   #4
kelley_aj
kelley_aj's Avatar
Get a piece of 2" or 3" black ABS pipe, 2 caps and 2 90 degree 5/8" nipple to whatever thread size, about 6' of 5/8" heater hose, steel wool = @ $10-15. Put in the steel wool, cap the ABS pipe. Drill 2 holes on the top to fit in the 90 degree fittings, run your heater hose put some band clamps on to secure it. DONE. Put mine in front of the air box and it is hardly noticable.
1993 940 Bili HD, TME springs, IPD sways and adjustable panhard, ported 15g and mani, 3" turbo back + Magnaflow=mmmmgood, Mike's chips, IPD turbo cam, Dale's gear, browntops shoving 14psi, MSD ign.
kelley_aj is offline   Reply With Quote
Old 05-08-2008, 09:37 PM   #5
sacrifice
here u go
http://www.pbase.com/rsrock/oil_catch_can
granny shifting not double clutchin like I should
sacrifice is offline   Reply With Quote
Old 05-08-2008, 11:16 PM   #6
Series #8217
Series #8217's Avatar
Originally Posted by sacrifice View Post
I like that. Those compressor filters are designed to filter oil out of the air. I think there's quite a pressure drop across them though. I dont know how that might affect the PCV system or reduce the effectiveness of the crankcase vent.
Series #8217 is offline   Reply With Quote
Old 05-09-2008, 07:37 AM   #7
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
whatever you do, get the large sized catch can, i got the smaller size one and wish i had got the larger one.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 05-09-2008, 03:00 PM   #8
fsl
Make one yourself like this.
20mm hose from crank to catchcan
20mm hose from valvecover to catchcan
35mm filter onto catchcan
O yea, it's swedish ;)
- 1997 volvo 944 lpt auto
- 1993 audi 100 2.5 tdi
fsl is offline   Reply With Quote
Old 05-09-2008, 03:05 PM   #9
MikiK
MikiK's Avatar
Get this one 35 bucks, can't build it cheaper and making it look this good.
http://store.driftmotion.com/Static/Itemoilcatchcan.php
MikiK is offline   Reply With Quote
Old 05-14-2008, 02:38 PM   #10
262 grand national
262 grand national's Avatar
http://cgi.ebay.com/ebaymotors/AMK-U...m220233826498&
I got one of these with no paint. It works fine, just had to ditch the hose but other wise ok for $29 shipped.
1/4 12.5 @ 113.5 R.I.P. 80 Bertone on the way looking for 11s with new converter :P
Blog on build up:
262 grand national is offline   Reply With Quote
Old 05-14-2008, 05:15 PM   #11
Mikoyan
Default yet another option
I like the looks of this one, but compared to the other options this one costs megabucks:
http://www.eliteengineeringusa.com/Catch_Can.html
Also am wondering what the filtering does for the pressure across the unit.
Mikoyan is offline   Reply With Quote
Old 05-15-2008, 12:19 AM   #12
crandandall
Turbobricks Low Life
crandandall's Avatar
I'm running a Greddy one that I bought off eBay. Works great, I think I paid like $30 shipped for it. It was used.
crandandall is offline   Reply With Quote
Old 05-15-2008, 12:24 AM   #13
Poik
Backwards Turbo
Poik's Avatar
Same one I am running:
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 05-15-2008, 12:34 AM   #14
mfpmax
Interesting, the fake old style greddy ones have disappeared from Ebay. Replaced by some new shape.
A 2.3, but not a Volvo...
Hesh wants some sex!
mfpmax is offline   Reply With Quote
Old 08-31-2008, 06:39 PM   #15
Mr.Borrie
Mr.Borrie's Avatar
I end up winning a GReddy one.. was a bit more then the others but i like the looks..
"It's the super-light aluminum 15mm, 1000cc. Greddy Part# 13500515. It will fit any car."
Old 08-31-2008, 10:45 PM   #16
towerymt
the real Towery
towerymt's Avatar
More expensive...more better? Baffled, big 3/8" npt bungs, large diameter filter, drain on the bottom. It's exactly what I was looking for.
http://cgi.ebay.com/ebaymotors/Alumi...em330266394191
Old 08-31-2008, 11:01 PM   #17
262 grand national
Default Nice
looks super clean too!
Old 08-31-2008, 11:06 PM   #18
maxman142001
I like turtles
maxman142001's Avatar
Towery's is nice....but the one im using works great too
i bought one off ebay and the nipples were too small and caused issues. this one is cheap too, and works
as nothing is impossible with God, even turbo's fixing themselves
-2011 VW GTi
maxman142001 is offline   Reply With Quote
Old 09-01-2008, 04:36 AM   #19
Mr.Borrie
Mr.Borrie's Avatar
that looks damn pretty, i got my GReddy for about the same price though
Old 09-01-2008, 07:20 AM   #20
DaButcher
Do a Burnout!
DaButcher's Avatar
I have read that the crankcase ventilation needs the vacuum to pull out the pressure?
Is this true?
eg. might a catch-can give you problems with leaky seals?
Or is it an urban myth?
DaButcher is offline   Reply With Quote
Old 09-01-2008, 08:09 AM   #21
Bishop
Bored Member
Bishop's Avatar
Sort of, engine vacuum can help with removal of crankcase gasses, but it's debatable as to how much it helps.
Seals etc can leak if you do have to much pressure, hence why people add like a vented cap, or valve cover, in the end though just make sure nothing creates a restriction, and you should be good.
If a mod wrote this, it would be hell funny...
Bishop is offline   Reply With Quote
Old 09-01-2008, 08:09 PM   #22
DrvSfly
Bored Clown
DrvSfly's Avatar
I myself am a believe in vac on the crankcase. It sucks cleaning your throttle body, but its not that bad.
Drive Safely
I think we'll either get rid of religion, or it will get rid of us.
'83 245 TIc sold
'97 960 totalled
'94 745 totalled (not mine)
'87 744 totalled (not mine)
'91 780 totalled and sold
'81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
DrvSfly is offline   Reply With Quote
Old 09-01-2008, 08:37 PM   #23
towerymt
the real Towery
towerymt's Avatar
Is this true?
I have a lot of blowby. I was pulling vac on the catch can by way of a ~1/2" ID hose plumbed to the pre-turbo pipe. It was sucking the oil out of the engine. Now I have the can I posted above plumbed into the system and I have removed the vac source so it's just venting to atmosphere. Now it's hardly putting oil into the can compared to before.
You should pull vacuum through the can if you can, and if you want to. In my case, the vac was too much. My engine was rebuilt including all new seals/gaskets and it's still clean. It does not show any oil leaks even with the positive crankcase pressure. At idle, there is pressure coming out of the head/block. If I loosen the oil cap while it's running, it will jump and bounce.
Old 09-01-2008, 09:15 PM   #24
lulu
ex-DSMer in rehab
lulu's Avatar
There's a DSM shop which is making 3 nice models. Build quality from those guys is awesome!
Catch can #1
Catch can #2
Catch can #3
lulu is offline   Reply With Quote
Old 09-01-2008, 09:20 PM   #25
str8krewzn
str8krewzn's Avatar
Thats what i got works good,one hole for the block and one is for the head
88 740:438WHP @20psi 95b230ft,Wiseco pistons,H-beam rods 9.1cr ,Minor ported 531 head with 38/47 SS valves,Rsi Stg3 cam,Rsi Adj Cam,Rsi solid mounts, Double Valve Springs ,BW S262 turbo,Nathaninwa custom header & Nathanwa Custom Intake Manifold,3.5inch exhaust turbo back,t-5 trans with BNE Adapter plate/shifter extender,stg 5 spec unsprung clutch.
01 IS300: Stock
99 CBR600 F4:(hit by a drunk driver)
02 CBR954rr :Akra Bolt On
str8krewzn is offline   Reply With Quote
