Old 09-01-2008, 09:21 PM   #26
ashvolvo
2 > 7
ashvolvo's Avatar
More expensive...more better? Baffled, big 3/8" npt bungs, large diameter filter, drain on the bottom. It's exactly what I was looking for.
http://cgi.ebay.com/ebaymotors/Alumi...em330266394191
This is exactly what I have.
It's very well made.
Likes good coffee & fast volvos. Builds stuff. Races stuff.
f: https://www.facebook.com/DvsPerformanceParts
twitter: ashd61 | w: http://www.dvs.net.au
1998 V70T5
2004 Holden Commodore wagon
ashvolvo is offline   Reply With Quote
Old 09-02-2008, 12:50 AM   #27
towerymt
the real Towery
towerymt's Avatar
Originally Posted by str8krewzn View Post
Thats what i got works good,one hole for the block and one is for the head
Where do you think I got the idea? It looked good and seemed to be larger than some others I've seen. So far, so good. I'll post pictures of the install this week (so everyone can laugh at my dual catch cans).
Old 09-02-2008, 08:14 AM   #28
SteveMD
Not A Typical Dating Site
SteveMD's Avatar
I was thinking that this subject is a good one for a How-to article.
Old 10-06-2015, 07:29 AM   #29
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
I have used my greddy catchtank in my 760 turbo for a while but thats being rebuild.
Now i want to use the can on my racecer Volvo 360 with B200 N/A.
Bought the Yoshifab crankcase adapter and now i am a bit confused how to hook this up as my Greddy catchtank only has 2 connectors.
I would say:
1: To intake hose / or vented to atmosphere (B200 N/A engine)
2: Block
But the Yoshifab adapter has 2 connectors..
Old 10-06-2015, 02:00 PM   #30
Canadan
Canadan's Avatar
I bought one of those standard eBay ones with both fittings close together on the top but stuffed it full of steel wool and a little downstraw on the inlet fitting so it didn't just loop back out into the other hose. My best working one is a stainless steel water bottle turned upside down stuffed full of stainless wool (must use stainless or it rusts) with a little filter breather on it
Canadan is offline   Reply With Quote
Old 10-06-2015, 02:48 PM   #31
Balzich
I would say:
2: Block
The smaller fitting is the oil drain from the catch can (sounds like your catch can doesn`t have one?). The larger one is the vent that goes to the catch can.
Balzich is offline   Reply With Quote
Old 10-06-2015, 04:41 PM   #32
Mr.Borrie
Mr.Borrie's Avatar
Yes my catch tank only has 2 fittings... Hmmm
Old 10-06-2015, 06:21 PM   #33
Canadan
Canadan's Avatar
Perhaps cap off the second port the "drain" and drain the catch can manually? I'd prefer it that way cause the stuff that comes out of the catch cans I've seen I'd NOT want to drain back into my engine. It's nasty milkshake looking junk
Old 10-07-2015, 03:58 AM   #34
Mr.Borrie
Mr.Borrie's Avatar
I was thinking that too, block off the second port on the Yoshifab adapter, and route it like i did on the b230ET. To sum it up on a B200 N/A Engine i would get away with
Big connector on yosifab adapter: > Catchtank line 1
Big connector on yosifab adapter: > Block it off
Catchtank line 2: vented to atmosphere
It's a race car , no emission laws etc. With the OEM breatherbox redblocks all puke oil around 7K revs. Hope this will keep the oil more in the block or the can
Old 02-11-2018, 11:38 PM   #35
Ilvmetal
Ilvmetal's Avatar
Thread from the dead.
Where does pulling vacuum on the Yoshifab catch can come into play. I have the breather and return plate from him. I will be making mega boost and was going to pull it from pre turbo but it appears one does not use vacuum in his design.
Maybe its not necessary or i'm just overthinking things as usual.
1973 142 Turbo 16V build
1986 FJ60 V8 conversion "lerch"
1989 740 bunch of stuff done
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 02-13-2018, 05:45 AM   #36
Mr.Borrie
Mr.Borrie's Avatar
I pulled both adapters from my redblock race engines btw
Old 02-13-2018, 07:48 AM   #37
Ilvmetal
Ilvmetal's Avatar
Which adapters are you speaking of?
Old 02-13-2018, 08:31 AM   #38
lverhagen
negahrevl
lverhagen's Avatar
Originally Posted by Balzich;5257254[IMG
https://yoshifab.com/store/images/source/oil_catchcan/b230_ccv_plumbing.jpg[/IMG]
If you have Josh’s catch cam as pictured above, I believe you want intake vacuum to be applied to the top fitting as shown in the picture.
Feedback Thread
7/900 Parts for Sale
Originally Posted by SquareD View Post
Restore this thread to stock.
Current Cars:
1987 Volvo 740 Sedan ~176k - ultra-swag beater/lender status (aiming for stage -1 at best)
1989 Volvo 740 Turbo Intercooler Wagon ~150k - some body and suspension damage resulting in a currently undecided fate
1995 Volvo 940 Sedan ~179k - bringing up to stage zero and beyond
lverhagen is offline   Reply With Quote
Old 02-13-2018, 11:43 AM   #39
Tfrasca
Tfrasca's Avatar
The top port on Yoshi's catch can should get routed to the pre-turbo intake pipe. His design doesn't really accommodate an intake manifold vacuum source, but you can run a tee with a vacuum line and check valve to the manifold if you want.
