Old 02-12-2018, 03:06 PM   #26
EivlEvo
Do people swapping T5's in truly care about the accuracy of their odometer? For car people it's just a reference anyway.
Old 02-12-2018, 03:51 PM   #27
seads505
seads505's Avatar
^^ not helpful to the thread and provides no help for the questions asked. If you don't care about the discussion or have something of value to add, no worries, just simply tap the back button on your browser and read the next thread...
So often, what ends up happening is these threads go way off topic into some ridiculous argument (completely pointless) and the real questions never get answered!
I bet SOME people care about how many miles they've traveled...or how many miles it has been since their last oil change...or how many miles it has been since they swapped out their motor/trans...or...C'mon, there are countless reasons why a person would want to know their vehicle's mileage.
Back to this thread: look, if we're already talking about modifying circuits, why not go one step further and ask a question that may provide the ability to have our factory-installed speedo/odometer work properly?
This isn't OT, can we try and keep things on topic? This isn't some far-fetched, rocket-science level question. I'm sure some of our fellow Tbrickers have experience in this...let's give them a chance to respond before derailing the entire thing.
seads505 is offline   Reply With Quote
Old 02-12-2018, 04:44 PM   #28
A tough rowing ho
I think an hour meter is a better gauge of when to change oil, might not be so good for getting your tire mileage warranty though.
Old 02-12-2018, 06:27 PM   #29
Tfrasca
Tfrasca's Avatar
This is relevant to me trying to get an LH 2.4 vehicle speed signal out of a T5. My T5 has a cable speedo gear, but I'm wondering if one of these could provide a signal to an LH 2.4 ECU. Has anyone successfully gotten VSS out of a T5 and into a 2.4 ECU?
Old 02-12-2018, 08:06 PM   #30
photoman327
photoman327's Avatar
Planning a t-5 swap on my Red 84 242 as soon as the weather breaks and a working speedometer is the haropart to me. Havenít looked into yet but prepping
photoman327 is online now   Reply With Quote
Old 02-12-2018, 08:20 PM   #31
Tfrasca
Tfrasca's Avatar
This looks promising:
http://turbobricks.org/forums/showthread.php?t=229965
Old 02-12-2018, 10:17 PM   #32
A tough rowing ho
I've been driving my car using a GPS for a speedometer for a couple years now, fingers crossed no tickets so far.
Old 02-12-2018, 10:49 PM   #33
Tfrasca
Tfrasca's Avatar
I have a GPS speedo too. I'm just trying to get vehicle speed to talk to LH 2.4 so it knows whether the car is moving or idling.
Old 02-12-2018, 11:29 PM   #34
bobxyz
bobxyz's Avatar
Based on cleanflametrap's speedo schematics and the UAF2115 datasheet
http://cleanflametrap.com/speedo.html
https://www.google.com/search?q=UAF2115
the odometer is setup for 12-pulses per tire (or differential) rev. From the schematics, you might be able to rework the speedo PCB to work with 6-pulses/rev or 3-pulses/rev.
The front wheel 240 ABS sensors are 48pulses/rev. I don't know if these are directly usable with a late 240 speedo board that's wired directly to the late 240 48pulse/rev differential. There's a discussion here about the 91-only 48-to-12 converter relay:
http://turbobricks.com/forums/showthread.php?t=288593
'85 245glt aw71 k-jet -> lh2.4
Old 02-13-2018, 12:17 AM   #35
EivlEvo
You're not relevant. And no one even touched the thread so I bumped it. Sometimes loosely relevant discussion leads to relevant results. Relax.
Old 02-13-2018, 09:02 PM   #36
Simi
Upsetti Spaghetti
Simi's Avatar
I've actually researched this myself because I don't feel like putting a tone ring on my truetrac when I install it.
On my T5 I have this sensor.
Supposedly that electrical connection is an output for the cruise control, it puts out a similar pulse to the non abs speedo. I was going to attempt wiring it up and seeing what it does shortly. Also since I had a Fox T5, it most likely is already set up for 3.73 gearing.
The other idea I had was using a strut housing from an ABS 240 and using the ABS sensor as a speedo pickup.
1989 240 Turbo
1988 745 Turbo - SOLD
1991 940SE - SOLD
1995 850 T5-R
1991 740 Turbo
1987 240
Leave Me Feedback
Simi is offline   Reply With Quote
Old 02-13-2018, 09:18 PM   #37
Tfrasca
Tfrasca's Avatar
Yeah I just ordered one of those, and I think it'll work. Just need to get my hands on an LH 2.4 speedo to convert the signal to something the ECU can use.
Old 02-15-2018, 05:20 PM   #38
Mudbutt
I don't know if this will be helpful but I recently put a G80 in a T5 swapped lh2.4 240. I swapped a 1997 v6 T5 with an electronic sender and was going to use a dakota digital speedometer adapter to connect the t5 speed sender to the stock speedometer. Before I tried connecting the speedometer adapter I just wired the T5 speed sender to where the stock differential speed sender and was amazed to find the speedometer/odometer within 2% of GPS recorded speed.
Mudbutt is offline   Reply With Quote
