Old 01-20-2014, 07:50 PM   #126
Jack
junkman
Jack's Avatar
I'm waiting for my wife to bring me a vernier caliper from Harbor Freight so I can get going with the cam. In the mean time I finally got around to installing the 75C turbo oil cooler and my oil pressure b230 block adapter. The 10bar sensor will go on once the alt belt is on so I can see how much clearance I have
Make old cars great again
Old 01-22-2014, 10:01 PM   #127
Sharingan 19
Sharingan 19's Avatar
This thread is awesome! Exactly the sort of enhancements (and level of execution) I'm looking for on my 245. Subscribed!
Sharingan 19 is offline   Reply With Quote
Old 01-22-2014, 10:09 PM   #128
240240
triggered attack survivor
240240's Avatar
why don't you put that oil sammich on a 740 arm??? and not kill motor mounts
Originally Posted by alschnertz View Post
What would 240240 do?
Old 01-23-2014, 04:21 PM   #129
Jack
junkman
Jack's Avatar
Thank you
much appreciated
I thought about that but when asked if the lines work with the 240 turbo cooler and/or lines no one had an answer and I didn't feel like messing with it.
also
I have the turbo engine mount cover plate (waiting to get powder coated)
I always put a rag there regardless.
I pressure wash my engine regularly to get all the crud off.
From what I hear (tb myth?) these engine mounts don't last long no matter what you do.
Got the car running on Tuesday night. It would have been done in the middle of the day but I had to redo the timing belt 3 times. Timing was around ~20 every time. I checked and triple checked every time it was off..... wtf....
Turns out the dizzy was off one tooth (not the aux shaft) from whoever did the Tbelt last time.
Car runs great but I think I have a small vac leak somewhere - The economy gauge is off just a bit (full vac) at idle.
Picture - moved the e-fan temp sensor to lower radiator hose. Now I need to shorten the wires to correct lengths. I will do that after swapping to EZK and removing the Chrysler garbage.
Old 01-23-2014, 04:52 PM   #130
Jack
junkman
Jack's Avatar
Mid cycle dash I scored with 4 tiny cracks - fixed thanks to Ken
According to Redwood "the nicest mid cycle dash he has seen"
Needs cleaning and will go in in the next few weeks
Also found a dealer installed 240 LSD
because LSD > Locker
Old 01-23-2014, 09:19 PM   #131
Ansel+
Bolbo Spotted
Ansel+'s Avatar
#rare
Ansel+ is offline   Reply With Quote
Old 01-23-2014, 09:23 PM   #132
Jack
junkman
Jack's Avatar
%what part
Old 01-23-2014, 09:32 PM   #133
Ansel+
Bolbo Spotted
Ansel+'s Avatar
dat LSD
Old 01-23-2014, 09:36 PM   #134
Jack
junkman
Jack's Avatar
yeah it is... it came out of an 87 245DL also had the volvo rear leveling system - shocks were gone but I snagged the pump/gauge/tubes
1/2 off sale too
pain in the ass to set it free. Cover/ bearing plates/ axles all came out easy but to free it took about an hour
Old 01-23-2014, 10:42 PM   #135
240240
240240's Avatar
1/2 off sale too
dafuq????? 1000 lb payloads ftw....
Old 01-24-2014, 12:19 PM   #136
Jack
junkman
Jack's Avatar
what shocks can be used with them?
Old 01-25-2014, 06:28 PM   #137
240240
240240's Avatar
The benzez are hydro filled with a pump.....you'd probably need to spec out an air shock that will fit.....maybe something off road quality....then you can adjust the height of your bolbo for road queen or hunting machine.....that would be the shizzz
And I've had motor mounts last me 300k miles......but then again I drive like a gramma.
Old 04-15-2014, 05:37 PM   #138
Jack
junkman
Jack's Avatar
I finally got around to installing EZK.
write up is here
Hardest part was getting to the knock sensor. I had to remove the intake support and take it off with a 27mm
Second hardest was splicing in all the wiring at both ecus since there's hardly any room. I took my time but the whole job took about 3-4 hours.
I mounted the powerstage in front of the battery on the inner fender
Car started right up on first crank!
out with the old
intake support bracket
Chrysler box gone. I need to move the fan relay to a better location
EZK box next to the ECU, not yet mounted with zip ties
Old 04-16-2014, 02:11 AM   #139
122power
dude
122power's Avatar
a 27mm wat? Now come do mine for a 6 pack a beer you wirey nerd,
Old 04-16-2014, 02:20 AM   #140
Jack
junkman
Jack's Avatar
27mm socket with 6 inch extension
With two people it should take no more than 1 1/2 hours.
Old 04-16-2014, 11:19 AM   #141
Sharingan 19
Looks like fun; makes me glad my wagon is a 91'. How's it running?
Old 04-16-2014, 11:39 AM   #142
Jack
junkman
Jack's Avatar
I actually like doing wiring on most days
However, I was stressed out because I didnt know if the parts I was putting in were any good...
Idle really smoothed out and the throttle response seems to be quicker. I sort of feels like going from carbureted car to a fuel injected (but not as drastic)
- ie getting on and off the throttle the car seems to react faster.
I recommend EZK to anyone with the Chrysler setup
nothing but benefits
- responds to throttle better
- cleaner looking engine bay
- easier to +T
- 70s tech vs 80s tech
- parts are more available
Old 04-16-2014, 04:59 PM   #143
Jack
junkman
Jack's Avatar
got some parts back from powder coating
- suspension
- 16v valve cover for later
- turbo coolant bracket
- 3rd seat self retracting/adjusting seatbelt brackets
- tow hook
Old 04-16-2014, 09:47 PM   #144
Jack
junkman
Jack's Avatar
installed a 240 turbo coolant overflow - Thanks Henry
pressed in poly bushings; used SuperLube for superior lubrication
Old 04-17-2014, 12:19 AM   #145
Jack
junkman
Jack's Avatar
Just finished installing one of the 3rd seat self retracting seatbelts. I had these for over a year now but never installed them because I wanted to get the base powder coated
AND .... the seatbelt latches are different from the manual adjustable ones . Make sure you grab the seat latches if you find these at a JY. I didnt and had to find a set that would both fit with the seat folded and latch. I ended up using S40 rear seat belt latches.
Old 04-17-2014, 09:34 PM   #146
530turbo
THE POLE CLIMBER
530turbo's Avatar
Looking good. Love the ezk ignition. Let me know when you are in town or local yards yo.
530turbo is offline   Reply With Quote
Old 04-17-2014, 09:48 PM   #147
Jack
junkman
Jack's Avatar
Thanks! I will get in touch.
Your old wagon got crushed about a week ago. Did you suddenly wake up sweating? Update your thread already so everyone can tell you what you are doing wrong
surprised you weren't at Davis
btw those are your old control arms with bushings (now with reinforcement plates)
Old 04-21-2014, 05:38 PM   #148
Jack
junkman
Jack's Avatar
Today I installed driver control arm and replaced a torn outer TRE
maybe later on I will do the other side.
Old 04-21-2014, 07:31 PM   #149
Jack
junkman
Jack's Avatar
just bought this to match my other gauges
Old 04-22-2014, 06:56 PM   #150
Jack
junkman
Jack's Avatar
my original block started knocking really bad this morning
after considering doing a full 16v swap I decided against it for now. I don't have all the parts or a good b230ft block
I'm going to use a what I have
150k b21ft block
ported b230ft head with 90+ mani and 15g turbo and B cam
just ordered a
turbo rebuild kit
earling HG and other gaskets from eeuroparts
