Old 04-22-2014, 11:14 PM   #151
Sharingan 19
Sharingan 19's Avatar
knock ....N/A....yeah, lets get this upgrade together asap!
Sharingan 19 is offline   Reply With Quote
Old 04-23-2014, 06:50 PM   #152
Jack
Banned
Jack's Avatar
I have my next weekend set to do this. Hopefully I will have all the parts by then.
picked all this today for $45 (excluding turbo and downpipe) included in the deal were powder coated IC pipes - I don't know how I feel about them yet
Not sure if i got the right - closest to turbo - IC pipe ?
Also started to strip old paint from the block
Old 04-23-2014, 11:11 PM   #153
Sharingan 19
Nice deal half off day at the JY? Too bad they snag all the cats by any means necessary, I eventually lucked out and found a 940 with a straight pipe exhaust system, that's the only way I could find a non-mangled downpipe. d
Looks like the IC piping from a 740 with the Peirburg.
Old 04-24-2014, 12:19 AM   #154
Jack
Banned
Jack's Avatar
Yeah I need to get another ic pipe..."
No 1/2 off m, the local yard is super cheap. Ie $150-200 for complete engine
Old 04-24-2014, 01:34 AM   #155
Sharingan 19
ohhhh, I skipped the part where you said there turbo wasn't included in that price. That's pretty reasonable.
Old 04-24-2014, 04:54 PM   #156
Jack
Banned
Jack's Avatar
Stripped and painted the block
I used "Easy-Off" over cleaner to prep the block.
Spray on and let sit for 30min. Come back with pressure washer and wash everything off - make sure not to get water into the block( I had the engine upside down)
Dry off with leaf blower
Repeat.
Go over rust spots with wire brush.
Spray everything down with brake cleaner.
Paint
Before paint
After paint - I used way too much on driver side - ohh well
Old 04-25-2014, 12:27 PM   #157
122power
dude
122power's Avatar
Wat no primer? Youve been busy.
Old 04-25-2014, 01:01 PM   #158
Jack
Banned
Jack's Avatar
primer included.
I need to get things ready for a smooth swap over (very wishful thinking)
Starting Friday I have 3 days to get it all done, otherwise it screws up my wife's work schedule.
Old 04-26-2014, 04:34 PM   #159
240240
Is Always crushing it
240240's Avatar
What are you gonna do about the smog Nazis? They aren't particularly fond of fire red pipi g.
240240 is online now   Reply With Quote
Old 04-26-2014, 05:07 PM   #160
Jack
Banned
Jack's Avatar
I don't need to
yesterday I removed the oil pan for painting.
found a broken crankshaft main cap bolt and what seems to be a broken chain link
engine must have been built on a Monday after a 3 day weekend- buy no damage anywhere
today I got my eBay turbo rebuilt kit so I cleaned it and replaced parts. Turbo's original brass bushings all looked good but there was just a lot of carbon buildup.
turbo before
turbo after cleaning
old brass and finished turbo
Old 04-26-2014, 10:13 PM   #161
122power
dude
122power's Avatar
That's all you did today?
Old 04-29-2014, 12:54 AM   #162
240240
240240's Avatar
I don't get it.????1985m???? No smog???
Old 04-29-2014, 01:10 AM   #163
Sharingan 19
the main bolt I get....but the chain link!?
Old 04-29-2014, 02:44 AM   #164
Jack
Banned
Jack's Avatar
yup and hung out with the kids. Anticipating this weekend
At least I will finally replace my "noisy-since-new" 10k mile TO bearing
All my cars are smog "exempt" - I only have to smog them when I sell them. They are all registered in middle no nowhere Siskiyou county
With no damage to anything - car was a daily driver to the PO
Old 04-29-2014, 03:13 PM   #165
122power
dude
122power's Avatar
He will sell everything, but not a car,
Old 05-02-2014, 01:25 PM   #166
Jack
Banned
Jack's Avatar
I make more $ selling parts
yesterday I found out that the formula for the Rustolum hammered paint has changed and brake clean takes it off........
I stripped the block and pan again but this time used Duplicolor engine paint.
much better
This morning Im here - went inside because it's hot
went out for 40min in the afternoon and did this
Old 05-03-2014, 10:36 AM   #167
Sharingan 19
Good call on the duplicolor engine paint, the clear coat for the engine paint really helps the resilience to chemicals btw, if you haven't done that already.
Old 05-04-2014, 01:26 PM   #168
Jack
Banned
Jack's Avatar
too late :( - although clear tends to turn yellow
Yesterday I feel a little behind schedule after swapping over bunch of little things to the new block and going to the JY for a timing belt cover (b21-b230 are different)
This morning I got the engine and trans mounted up
went together like magic on the first try
turns out I also been panning for gold with the old engine
I made my own clutch alignment tool - I cant find my old one
and a hybrid b21 to b230 head rear timing belt cover to get the timing marks
Old 05-05-2014, 02:34 AM   #169
122power
dude
122power's Avatar
Woop woop just about done.
Old 05-06-2014, 01:38 AM   #170
122power
dude
122power's Avatar
Dood its been like one day with no updates. Did you give up?
Old 05-06-2014, 03:03 PM   #171
Jack
Banned
Jack's Avatar
no crushing just yet
It's all the little thing that keep slowing me down.
- trim coolant hoses
- fabricate turbo oil drain - (b230 drain is longer than needed for a b21ft block)
- thunderstorm rolled in while I was working
- install correct hard lines for turbo - even though this one came off a b21ft it was jerry-rigged at best
I still need to
-set timing
-fabricate exhaust
Old 05-06-2014, 09:21 PM   #172
Jack
Banned
Jack's Avatar
Got it running and driving but only with an open donwpipe (modified 940)
way way too loud.
I still need
- sort out a couple of vacuum hoses
- solder in a ground for AMM
- install early windshield washer reservoir in passenger butt cheek
- get a BOOST gauge
- get a proper filter - not some $3 JY special
- finish installing exhaust
Old 05-06-2014, 09:33 PM   #173
Mylesofsmyles
You need these...
I had the ends for a TD04 turbo, welded to my B21FT oil lines...for a direct-fit, bolt in solution, that's as good as factory.
Old 05-06-2014, 09:37 PM   #174
Jack
Banned
Jack's Avatar
^ I made my oil drain pipe already - see 2 post above
The oil "feed" line I will make out of AN stuff eventually. I just wanted to get this thing running ASAP since it's my DD
Old 05-07-2014, 11:33 PM   #175
Jack
Banned
Jack's Avatar
I spent most of my day rolling around in the dirt fabricating the exhaust from 4 different setups
Catback is IPD sport pipes with ANZA muffler
I still need to sort out some hangers - currently hangers and bailing wire in few spots
Modified downpipe
