Old 03-09-2013, 10:37 AM   #101
AndrewNance
Amateur hour!
AndrewNance's Avatar
Originally Posted by frodosm3 View Post
by far one of my favorite 122's on the forum, great job, definitely sets the standard for my 122 sedan
Originally Posted by Chance View Post
Wow killer looking 122. You do great work. Still remember standing in the driveway watching a guy drive off in my old mans '67 122s wagon for $300 thinking "wait a minute what just happened?!" I was 17 with 2 2nd gen Camaros and an 84 240 wagon so couldn't really convince him to let me have it....... I won't even get into the feeling of the last 544 leaving......
Anyhow great looking car! Subscribed...
Originally Posted by ibcmoore View Post
That tunnel came out super nice after a simple kero-bath. Nice!!
Thanks guys!
'71 142
'80 245
Feedback
Old 03-13-2013, 09:42 PM   #102
AndrewNance
Amateur hour!
Finally got the car down to the shop and got a little more done today. Slowly working up to getting the motor in. Should have the rest of the old tunnel cut out and the new tunnel riveted in tomorrow. I'll get it welded sooner than later. I'm really excited about the short shifter. I think it's really going to feel like a different car. I can't even believe it's getting this close to being running again. It only spent one season off the road!
Old 03-13-2013, 11:16 PM   #103
Corey
Corey's Avatar
Awesome! Im so jealous!
'81 242 turbo
Corey is offline   Reply With Quote
Old 03-14-2013, 06:25 PM   #104
AndrewNance
Amateur hour!
Got the tunnel to fit down on the old one. It's still gonna need some tweaking and some relief cuts but it should fit in there nicely when it's all done. I have to get the engine in first so I can see where my shifter is going to sit when it's all done.
Old 03-15-2013, 12:18 PM   #105
propav8r
F*ck Edgar
propav8r's Avatar
Hurry up and fix it so it can show up at the meet on Sunday!
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo,
1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 03-15-2013, 12:48 PM   #106
AndrewNance
Amateur hour!
It won't be making it to this one either. The engine isn't even in and it will still need an exhaust after that. So, unfortunately, the wagon is coming. Maybe next week it will run again?
Old 03-21-2013, 05:04 PM   #107
AndrewNance
Amateur hour!
Happy Birthday to me!
Old 03-21-2013, 05:07 PM   #108
ibcmoore
ibcmoore's Avatar
It's (almost) alive....ALIVE!!! Looking good!!
Oh, and Happy Birthday!!
cmoore
WANTED: Volvo C306 (1314) 6x6 with radio/ambulance box
Posted by TrickMick on 122313: "ether be yo fren".
ibcmoore is offline   Reply With Quote
Old 03-21-2013, 05:19 PM   #109
AndrewNance
Amateur hour!
Thanks Chris! Maybe you can answer this: is there a B20-specific heater hose that connects the upper outlet on the heater core to the water return that runs back to the front of the block? I bought the molded 90* hose but this engine came with a water return that is shaped a little different and rather than swap this pipe for my old one I'd like to just get the correct hose. This engine was from a '74 140.
Old 03-21-2013, 05:23 PM   #110
ibcmoore
ibcmoore's Avatar
I'll go look on the wagon when I get home.
Old 03-21-2013, 05:24 PM   #111
Fivehundred
Fivehundred's Avatar
You need to turn the 90 degree elbow in the back of the head and use the water pipe from the pump that came off the B18.
And it looks like you're using a bottom hose at the top of the rad......
Fivehundred is offline   Reply With Quote
Old 03-21-2013, 05:26 PM   #112
AndrewNance
Amateur hour!
Plus I think I put that one up there on the wrong pipe from the heater core, correct? Shouldn't it run to the upper one?
It's not pushed down on the thermostat housing. I have a new replacement for that but I had to cut out early for the day.
Old 03-21-2013, 05:28 PM   #113
Fivehundred
Top heater connector goes to top connector on heater valve
Old 03-21-2013, 05:31 PM   #114
AndrewNance
Amateur hour!
Then yes, I have it installed incorrectly . That would explain why the 90* heater hose doesn't want to reach the elbow at the back of the head. I will swap out the return pipes this weekend.
Old 03-21-2013, 05:34 PM   #115
Fivehundred
If the engine came out of a 140 then you just stick a bar in the 90 degree elbow and turn it a bit further, the thread is tapered so it'll go. It shouldn't need much force.
Old 03-21-2013, 05:43 PM   #116
AndrewNance
Amateur hour!
Yeah I did that but the hose was still just a little too short. Probably because I was trying to run it from the top connector instead of the bottom.
Old 04-08-2013, 12:08 PM   #117
AndrewNance
Amateur hour!
Well the engine ran for the first time yesterday. Sounds good. Need to change the oil, retorque the head, readjust valves, and fix exhaust misalignment. It's rattling on the floor and so so annoying. Possible vids later. But probably not.
Also picked up some Style 5s today for what I considered to be a a good deal. $400 for the set. Tires are no good. They need a little refinishing work but all are straight. I'll either redrill to 4.5 or see if I could trade centers with someone. Color is undecided yet but I'll most likely go for something dark.
Old 04-08-2013, 12:24 PM   #118
Corey
Corey's Avatar
Sweet! Thats a really good deal for those. Are they the 17x8 et 20 ones? cant wait to see what they look like on the car. What size tire are you going with?
Old 04-08-2013, 12:28 PM   #119
AndrewNance
Amateur hour!
Those are the specs exactly! I'm just going to swap the 205/50s from the TSWs over once the BBS are done. I think next time I have to buy tires I'll go with 215/45 or 225/45.
Old 04-08-2013, 12:43 PM   #120
66amazonwag
wanna sell the TSW's???
66amazonwag is offline   Reply With Quote
Old 04-08-2013, 12:44 PM   #121
66amazonwag
or possibly some trades for some parts and cash on my end lol
Old 04-08-2013, 12:55 PM   #122
ibcmoore
ibcmoore's Avatar
I knew someone would hit on those TSW's...
Old 04-08-2013, 12:58 PM   #123
66amazonwag
haha those are good looking wheels.
Old 04-08-2013, 01:03 PM   #124
AndrewNance
Amateur hour!
Eventually. The Style 5s will need some work and a re-drill. The rest of my money for the next month is going into getting the car ready for Carlisle.
Plus after I get them refinished I might see if there's any interest in trading them for some LMs. I like those better
Old 04-08-2013, 01:11 PM   #125
Corey
Corey's Avatar
Nice. I had 215/45 on mine I was pretty happy with that size
