Old 10-12-2017, 09:18 PM   #651
AndrewNance
Amateur hour!
AndrewNance's Avatar
For imgur, copy the BBCode link straight to here.
'71 142
'80 245
Feedback
Old 11-05-2017, 05:42 AM   #652
HUB
Needs more cowbell
HUB's Avatar
Got it to work!!! Woot woot. It appears Imgur doesn't play well on my Linux computer, but it works great on Windows 10 (could also be my web browser). Going to start fixing pictures today.
Thanks,
HUB is offline   Reply With Quote
Old 11-11-2017, 01:23 PM   #653
HUB
Needs more cowbell
HUB's Avatar
Default B230FT Valve Shim, painting of motor mounts and manifold
Afternoon Everyone,
Painted the new motor mounts and manifold.
Been working on shimming the valves the last few nights. Going to need more cigars and beer. Haha.
Then I started working on the coil setup.
Current shot of car.
Thanks,
Old 11-11-2017, 01:24 PM   #654
HUB
Needs more cowbell
HUB's Avatar
All pictures have been fixed. Sorry for the delay everyone.
Thanks,
Old 11-11-2017, 03:31 PM   #655
soclosenotnear
Man, that coil bracket is nice. I almost wish I would have went with those coils so I could use that fancy looking bracket. You wagon is super clean. Fine job.
soclosenotnear is online now   Reply With Quote
Old 11-11-2017, 05:51 PM   #656
fortbrick
fortbrick's Avatar
27 pages later...
This is awesome. Love the attention to detail. Hope to see this in person someday.
Old 11-11-2017, 08:10 PM   #657
HUB
Needs more cowbell
HUB's Avatar
Originally Posted by fortbrick View Post
27 pages later...
Took forever to get them fixed. More than welcome to come by. Plenty of beer, scotch, and cigars.
Thanks,
Old 11-18-2017, 04:12 PM   #658
HUB
Needs more cowbell
HUB's Avatar
Evening everyone,
Worked on the coils some more. Used phenolic for now. Will most likely make a metal piece and powder coat it. Temporary hardware installed.
Thanks,
Old 12-09-2017, 04:33 PM   #659
HUB
Needs more cowbell
HUB's Avatar
Afternoon everyone,
Not much to report. Got a drill press to help with some of the Volvo and house work.
Thanks,
Old 12-09-2017, 04:55 PM   #660
Tfrasca
Tfrasca's Avatar
Nice progress. Shop is looking great, too!
Old 12-09-2017, 05:00 PM   #661
HUB
Needs more cowbell
HUB's Avatar
Thanks. Sent you a PM a few weeks ago. Never heard back.
Thanks,
Old 12-09-2017, 06:20 PM   #662
fortbrick
fortbrick's Avatar
Thanks,
Come spring time that will have to be arranged
Old 01-27-2018, 10:57 AM   #663
HUB
Needs more cowbell
HUB's Avatar
Good Morning Everyone,
Ordered my flywheel, clutch, and pressure plate the other day. Should arrive next week. Will yank the motor out this weekend.
The MS3pro arrived today. Will start planning my attack to learn how to install this system.
Thanks,
Old 01-27-2018, 11:18 AM   #664
cwdodson88
Nice! I’ve been checking every day for updates. How’s life?
The Build Thread
SVEA - PUSHROD TURBO!
Old 01-27-2018, 11:55 AM   #665
HUB
Needs more cowbell
HUB's Avatar
Its going well. Trying to get some of these big purchases out of the way before our first kid arrives May 28th. My feeling is once our daughter is born, time and money for the volvo will decrease. Haha.
Thanks,
Old 01-28-2018, 04:59 PM   #666
ZyreX
ZyreX's Avatar
Great project! You're doing good work, very fun to follow
'66 Volvo Amazon / P130
'83 Volvo 240
'05 Volvo V70 2.0T
ZyreX is offline   Reply With Quote
Old 02-03-2018, 12:27 PM   #667
HUB
Needs more cowbell
HUB's Avatar
Morning Everyone,
Got the clutch setup in the other day. Got it put in this afternoon.
However, when I press the fork all the way, it hits the BH and is just barely touching the pressure plate. Leads me to believe the fork and or TOB isn't the correct setup for this...
Pressed all the way
Thanks,
Old 02-04-2018, 02:47 PM   #668
HUB
Needs more cowbell
HUB's Avatar
Good Afternoon everyone,
Worked on adjusting the fork and TOB today. Ended up putting .306" spacer under the pivot ball to have the TOB just barely touching the pressure plate. If I removed one more washer, the TOB wasn't touching the PP. Don't know if there is supposed to be an air gap of some sort. Still researching.
Will setup a clutch fork return spring (don't know if I need it) and will need to get some different bolts for the starter.
Thanks,
Old 02-11-2018, 02:08 PM   #669
HUB
Needs more cowbell
HUB's Avatar
Good Afternoon Everyone,
Got the motor and trans in the other other day. Bolted everything up today. Realized I was missing the collar for engine and BH. Found it in a box of parts and started cleaning it up. Debating on powder coating it...
I started to mock up the J-pipe design for the exhaust manifold and turbo setup. Wanted to get the turbo up more. Used some PVC and wood to come with a design. Will then take it to a coworker to fabricate this correctly out of steel.
Was thinking of putting the external wastegate on the backside ( this would be about the middle of the PVC). Thoughts?
Thanks,
Old 02-11-2018, 02:31 PM   #670
vintagewrench
vintagewrench's Avatar
Lookin good.
Old 02-11-2018, 03:04 PM   #671
cwdodson88
Looks great!
For your wastegate, that idea sounds good, but be sure to get it clocked for suspension space.
Old 02-12-2018, 12:13 PM   #672
AndrewNance
Amateur hour!
I don’t see why the wastegate wouldn’t work there. I’d try to angle it up a little if you can just so the exhaust doesn’t have to make a hard 90* when it opens. I’m just gonna use an internal gate this time around. Easy packaging, less noise.
Old 02-18-2018, 12:03 PM   #673
HUB
Needs more cowbell
HUB's Avatar
I was thinking about moving it more to the front to give the exhaust more room to clear. Will know more when everything arrives next week.
Thanks,
Old 02-18-2018, 07:43 PM   #674
DET17
Reformed SAABaholic
Excellent build Mr. Hub! I'm not an Amazon man, but came close. I was in Japan back in 2010 and a fantastic 122S came up for sale in south GA. I tried to hold the guy with a deposit until I could get back to the States, but someone showed up with cash (a 2 owner 2 door 122S).
You are doing excellent work.... and will find it a bit more challenging after that baby arrives! I do like the 122 Wagon, always makes me think of surfboards and wood sides.......
Old 02-18-2018, 08:36 PM   #675
HUB
Needs more cowbell
HUB's Avatar
Thank you for your kind words. I’ll keep everyone posted.
