Old 02-12-2018, 10:45 PM   #551
Tfrasca
Tfrasca's Avatar
Originally Posted by Tfrasca View Post
What's so hard about the upper arms?
FYI, I'm currently eating these words. Getting the upper bushings back in is a nightmare. The only thing I can think to try is cutting a section of pipe that will span the inner faces of the bushing surfaces, then notching it to fit over the spindle that has to be there. Otherwise you're just flexing the control arm instead of pushing the second bushing in. I recommend never doing the uppers.
Old 02-13-2018, 01:28 AM   #552
Coupid
Coupid's Avatar
Thanks for the confirmation. I really might not do them. The lowers were 1000x worse looking but I have to take off the upper control arms to do the upper ball joints...
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 02-13-2018, 02:01 AM   #553
Tfrasca
Tfrasca's Avatar
Interesting. My lowers actually looked alright, but the uppers were dry rotted and the rubber literally crumbled out. But if your uppers look ok, just skip the bushings. You can pull the arm and leave the bushings intact.
Old 02-13-2018, 09:38 AM   #554
sksmith
sksmith's Avatar
They were a PITA, for sure, but if you can do the lower's, you can do the uppers.
If I recall, I did get a kit for doing uppers. They are like older GM's, with the a-arm shaft.
Dangerkitty, I'm surprised that the shop didn't have the shims. Again, they look like the shims on my old Buick Wildcat, which are standard old shims. Hell, Harbor Freight sells a kit with several sizes.
Steve
Old 03-21-2018, 10:36 PM   #555
Coupid
Coupid's Avatar
Quick update. The second upper ball joint is on its way from VP!
Also decided to replace the spark plugs since they survived the pre-fuel pressure regulator life. Glad I did...
Old 03-22-2018, 06:19 PM   #556
emem1160
read entire thread, never knew much about these 140s till now. fun car for you non-salters. drive straight and careful and keep up the good work
emem1160 is offline   Reply With Quote
Old 03-22-2018, 11:18 PM   #557
Coupid
Coupid's Avatar
Thanks for the kind words! Glad the thread was informative.
Old 03-31-2018, 10:15 PM   #558
Coupid
Coupid's Avatar
Quick no photo update.
rewired the tach with black wire since for some reason I used green when installing the GT cluster.The green looked silly to me. Also properly sorted out the connection at the coil
Found a huge exhaust leak before the first muffler. The pipe wasn't in all the way so the expansion cut part was a huge hole. This involved hours of rolling around under the car and trying to wiggle the pipe in and out of the header. Very annoying but much improved. Still have a few more leaks down there. would benefit from some welding instead of c clamps.
Old 04-02-2018, 11:44 PM   #559
Coupid
Coupid's Avatar
My good friend got tired of looking at this combo in his garage and graciously gave me a great deal so I can hopefully make something out of it.
B234 head with a B230 block and T5!
Hoping the "93" means 1993?
Here is the T5
This will be a long term project. Luckily the B20 and M40 are doing fine so I can piece together everything to make this into my dream car. Plan is to keep it NA, use a lot of Yoshifab magic and MS. My wife's cousin has an MS2 setup that he was planning to put on a BMW 2002 that he just sold so I will probably go that route for engine management.
Old 04-03-2018, 10:48 AM   #560
Tfrasca
Tfrasca's Avatar
If you go NA, please rig up some ITBs.
Old 04-03-2018, 11:23 AM   #561
Coupid
Coupid's Avatar
I would love DCOEs or ITBs but there doesn’t seem to be a manifold to make it happen. Well, aside from the $500 sheet metal one on ebay
Old 04-03-2018, 04:47 PM   #562
MoCounselor
MoCounselor's Avatar
I think that there are manifolds available in the motherland...? (I've seen a few b234 cars on insta with itb's on them.
MoCounselor is offline   Reply With Quote
Old 04-03-2018, 04:48 PM   #563
itb-volvo
There is a intake out there somewhere. I know this isn't much help but on one of the FB groups someone posted a link to one. I tried to find it for you but was not able to find it. If I end up finding it I'll send it your way.
itb-volvo is offline   Reply With Quote
Old 04-03-2018, 06:48 PM   #565
itb-volvo
You the man.
Old 04-03-2018, 09:09 PM   #566
Coupid
Coupid's Avatar
Thanks guys, those look like a good option. Previously all I could find was this thing:
https://www.ebay.com/itm/Volvo-B234-...vip=true&rt=nc
That being said it would be hard to justify going that route given the deal I can get on MS2.
But then there is the sound lol
https://www.youtube.com/watch?v=RL1Hdvy7dc4
https://www.youtube.com/watch?v=YyzQqdREem4
Old 04-05-2018, 10:17 AM   #567
Tfrasca
Tfrasca's Avatar
Yeah, I'd go with ITBs from a liter bike and MS. It'd take some adapting, but there's no way I'd do all that work and still have carbs.
eBay ITB
Old 04-05-2018, 07:59 PM   #568
Coupid
Coupid's Avatar
eBay ITB
There's another interesting idea.
From what I am reading, since I don't plan to put a turbo on the engine the freed up space from mounting the engine upright isn't needed. I could mount the engine slanted, use an M47 (with some transmission tunnel cutting) and a readily available B230 intake might just clear the brake booster?
Old 04-05-2018, 08:13 PM   #569
Tfrasca
Tfrasca's Avatar
But you'd need a B234 intake, and aren't those a bit longer?
Old 04-05-2018, 09:01 PM   #570
77volvo245
77volvo245's Avatar
http://www.unikracing.com/eng/volvo.html#
STSmachining
Old 04-05-2018, 10:36 PM   #571
Tfrasca
Tfrasca's Avatar
Originally Posted by 77volvo245 View Post
DAMN.
Old 04-05-2018, 11:17 PM   #572
Coupid
Coupid's Avatar
DAMN.
Damn is right.
Old 04-05-2018, 11:37 PM   #573
77volvo245
77volvo245's Avatar
We are planning on running a cosworth intake modified the flange to a 16v . should clear the brake booster
Old 04-06-2018, 11:12 AM   #574
AndrewNance
Amateur hour!
AndrewNance's Avatar
If it needs it, you could just shorten the b234 intake like people do for 240s. I know this is 8v but mounting the engine slanted seems to leave a really good amount of space between the head and brake booster.
'71 142
'80 245
Feedback
Old 04-06-2018, 11:31 AM   #575
Tfrasca
Tfrasca's Avatar
Oh wow, I didn't realize clearance was that good with the engine slanted. Definitely do that, Colin.
