Old 11-12-2015, 02:22 AM   #101
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Wow, never seen one like that. I'm jealous of your H4s
Originally Posted by Coupid View Post
Ordered some clips from IPD but didn't want to wait until later this week to see my much improved lighting. Cobbled the old crumbly ones back together yesterday so I could take it around the block tonight.
Before I took it out, I decided to play around with the timing a little. After a few degrees of advancing the idle sounded better than ever.
A short test drive confirmed that the car ran the best it has since I bought it and the lights are "night and day"
Can't wait to drive it more this weekend but I decided to splurge a little on the rear suspension. More photos to follow soon but in the mean time can someone ID this rear sway bar[/img][/url]
Also ordered my High Mileage Badges from Volvo. What a good night!
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
Old 11-13-2015, 02:35 AM   #102
Coupid
Coupid's Avatar
Yeah if anyone can figure out what kind of swaybar that is I'm curious.
A little update from tonight.
Got the new headlight clips from IPD today... much better:
I noticed it was a little wet up by the valve cover so I thought that the seal I installed might have been failing. Then I looked closer and saw it was coolant:
Which is perfect timing because there was a Volvo upper radiator pipe NIB in the trunk when I bought it. When I ordered the headlight clips, I also ordered a new lower pipe in anticipation of doing this job:
IPD shows an 82C thermostat for this car but the gauge has always stayed on the cool side of the middle. I figure I will just replace it with the same temp as I take out since the temp gauges are flakey and it seems happy as is.
The truly bad news is that I noticed this also:
When I bought this exhaust manifold off ebay I noticed that it had been welded on the opposite side of this new crack. Now I have to decide if I am going to:
a. get aftermarket headers
b. get another stock manifold
c. do nothing
d. slice and separate my stock intake/exhaust manifold
I am leaning towards d right now.
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 11-13-2015, 03:10 AM   #103
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Thanks for the warning to buy headlight clips!
Oh you need to brace the sway bar brackets vertically and horizontally
Remember cooler is not always better. Whatever thermostat I have my rally gauge sits at the minimum operating temperature almost all the time
I have a 4into1 header that needs work. But a header counteracts the weber setup
Your manifold is going to keep on cracking. Someone tried to repair it but didn't understand how the crack works.
Old 11-13-2015, 03:34 AM   #104
I had a 1974 145 with a cracked header. I replaced with a fresher manifold. Cast iron doesn't repair well from my information gathered here on Earth. Others may argue otherwise. Meh. Adding steel to iron isn't my thing. I try to keep my metals separate when possible. After years of expansion/contraction, different metals will go their separate ways.
Old 11-13-2015, 12:08 PM   #105
Coupid
Coupid's Avatar
I was joking about not doing anything, the manifold that is on there is toast. I think I will start by cutting the intake manifold off the exhaust manifold that came with the car. Should be a good start while I try to plan out if I want to go another route.
Old 11-18-2015, 12:03 AM   #106
Coupid
Coupid's Avatar
This should help:
Old 11-18-2015, 12:07 AM   #107
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Oh what!? Do tell more!
This should help
Old 11-18-2015, 12:29 AM   #108
Can't wait to drive it more this weekend but I decided to splurge a little on the rear suspension. More photos to follow soon but in the mean time can someone ID this rear sway:
Addco.
Old 11-18-2015, 12:35 AM   #109
Coupid
Coupid's Avatar
Addco.
Thanks! I was able to dig through their site and find install instructions: http://addco.s3.amazonaws.com/wp-con...012/03/942.pdf
Old 11-19-2015, 10:50 PM   #110
Coupid
Coupid's Avatar
This should help:
So I got both of the Carrera front shocks on the car yesterday and noticed that when the car was back on the ground it was resting on the bump stops. When I was still on the old blown KYBs, it cornered very flat but didn't seem to soak up the bumps. I think that given how blown the old shocks were it was pretty clearly riding on the bump stops. (Sorry about that ride to Goleta Keith!)
Tonight I removed the bump stops and took it out and wouldn't ya know, between the new shocks and this thing called "suspension travel" its like a whole new car.
For the rear I have Kaplhenke adjustable spring perches, 5x8 250lb springs and KYBs waiting to go in as soon as I get new 240 spring perches.
Now that the bump stops are out it is about 1/2 an inch lower, which will look great but is borderline useless at getting around town. You heard it hear first but the front end might need to come up a little now.
Old 11-19-2015, 11:09 PM   #111
No drilling and plating the floor like the IPD bars.
Not that 140's need rear bars anyway with the wider rear axle track width.
Old 11-25-2015, 01:23 AM   #112
Coupid
Coupid's Avatar
A few posts ago I alluded to some parts for the rear suspension arriving. Today the final bits did and I set to work on the driver's side.
The upper shock bolt had been giving me problems since I first tried to install the new KYBs a month ago. I soaked them in PB blaster for a week and with some pressure the bolt finally gave.
I ordered Kaplhenke adjustable perches and 5x8 250lb springs. I can't say enough about how awesome they are. The fit and finish is outstanding and they even shipped with all the hardware. Best of all Ben got them in the mail in less than a day!
Since I don't have the later 240 style spring perches I looked around for a while before I finally found them for sale. That would have been a great junkyard buy in retrospect but they weren't that expensive and they are brand new.
Here is what it all looks like outside the car:
With the perches adjusted about three quarters of the way up the sleeves the body was fully resting on the tire. I took a quick photo and then adjusted them up further.
Tomorrow I will do the other side and then the car will be due for some pretty extensive fender rolling. I can't wait to see it without all the rake and what it handles like with new shocks! Hopefully it will still make it out of my driveway at the lower height. If not I'll be in the market for taller springs...
Old 11-25-2015, 02:15 PM   #113
timpanama
timpanama's Avatar
i have a stock manifold
timpanama is offline   Reply With Quote
Old 11-25-2015, 04:01 PM   #114
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
KYB gas-a-justs for the rear? Did you make the adapter for the tops of the Carreras? I'm looking for shock for the 142 right now and am trying to decide on what to get.
Old 11-25-2015, 04:33 PM   #115
AndrewNance
Amateur hour!
AndrewNance's Avatar
I have the same rear spring and adjuster and they're almost as high as they can go. You might want a 10" spring instead. Not sure how low you are trying to get it.
'71 142
'80 245
Feedback
Old 11-25-2015, 04:33 PM   #116
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
You Want mono tube shocks.
Look up late model suburban 2wd for front. S10 front for rear
Old 11-25-2015, 04:45 PM   #117
Coupid
Coupid's Avatar
I think you're right about the 10" tall spring. I'm going to see how much I need to roll the fenders tonight and if therear wheels will fit with these springs. I would also really benefit from an adjustable panhard rod for centering.
The Carreras came with those adapters. If I were you I'd just order the Kyb gasadjusts for all four corners.
Old 11-25-2015, 04:50 PM   #118
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Really? I love the kyb monomax. Gas-a-justs arnt stiff enough for me
if I were you I'd just order the Kyb gasadjusts for all four corners.
Old 11-25-2015, 06:35 PM   #119
240keith
Floats your Boat
240keith's Avatar
No worries, glad to hear its better now...
just drop it down like that and let it self clearance....
glad to see you are making progress ... let me know when you are ready to cut those bumpers off, grinder is at the ready!
-Black on Tan-
225, XXX Miles!
-B cam-
Single Rounds / Flathood
Originally Posted by Mr.Borrie View Post
Is this real life?
No.
This is TB.
240keith is offline   Reply With Quote
Old 11-25-2015, 06:35 PM   #120
240keith
Floats your Boat
240keith's Avatar
double postage!
using this space to ask you to PLEASE pull the bumpers and at least see what it looks like...
Old 11-25-2015, 07:40 PM   #121
Coupid
Coupid's Avatar
Originally Posted by 240keith View Post
double postage!
As long as I can just unbolt and not cut I am willing to give it a shot lol
Old 11-25-2015, 09:22 PM   #122
Uncleknucklez
bruspeed
Yes! First thing I did was pull the front bumper off mine when I got home! They look so good nekid up front.
Old 11-25-2015, 09:56 PM   #123
240keith
Floats your Boat
240keith's Avatar
bring it in, ill bring the electric impact, and I am sure we can figure it out ... lets ask that guy above - i am sure it unbolts without needing to cut it off...
Old 11-27-2015, 01:07 PM   #124
UTAHGTBRICK
UTAHGTBRICK's Avatar
Please dont take the bumpers off. That is sooo hipster douchey status. Plus you better hope you dont get hit. I put my bumpers back on because its a cool look but theres always that what happens if... anyways i am very glad you are using the parts you got from me. The car looks amazing with those wheels.
my feedback thread here
http://forums.turbobricks.com/showth...86#post5022386
UTAHGTBRICK is offline   Reply With Quote
Old 11-27-2015, 01:18 PM   #125
+1
It's not an Indy car.
