Old 12-06-2015, 11:43 PM   #151
Coupid
Coupid's Avatar
Did you put a little dab of silicone grease on the follower, and oil the bronze bushing on the bottom of the dizzy tower?
No, but now I will! Thanks Ken
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 12-06-2015, 11:45 PM   #152
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
Now this situation will teach you when it's time to adjust the points. If before the mileage interval you will feel a change in power.
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
Old 12-06-2015, 11:47 PM   #153
A matchbook cover was the old school side of the road 'feeler' gauge, that's if you can find book matches anymore...
There should be a little barrel at the bottom of the dizzy, turn that till the hole in it points up and drizzle some oil in there to lubricate the bushing at the bottom of the shaft.
Old 12-06-2015, 11:55 PM   #154
You should also put a drop or two of oil on the felt wick under the rotor to lubricate the advance mechanism.
Old 12-13-2015, 10:36 PM   #155
Coupid
Coupid's Avatar
With the 5x8 rear springs the Kaplhenke perches were as set as low as possible. It looked great, but wasn't that practical since I could only lower the car further since the perches were screwed all the way down. With the 16x8 rear wheels even with the fenders rolled the car rubbed over uneven roads. The 5x11 springs I just ordered are a much better fit for the car. One side showed up today and I put it on to test the height. I can lower the perches all the way down so the body rests on the wheel (which I don't want) and raise them up so there is a few inches of fender gap. Much better!
Old 12-13-2015, 11:04 PM   #156
240keith
Floats your Boat
240keith's Avatar
sooo much gap .... just kidding - looking good Colin! nice to hear you got the ignition dialed in.
-Black on Tan-
225, XXX Miles!
-B cam-
Single Rounds / Flathood
Originally Posted by Mr.Borrie View Post
Is this real life?
No.
This is TB.
240keith is offline   Reply With Quote
Old 12-13-2015, 11:27 PM   #157
Coupid
Coupid's Avatar
Hahaha the car could be raised up another 2" from where it's set in these photos, then it would have some fender gap.
Old 12-16-2015, 01:09 AM   #158
Coupid
Coupid's Avatar
Okay I'll preface this with I know a few people on here told me to avoid the IPD header with their Weber setup. The other day I was looking at the crack in my exhaust manifold and noticed it had grown a lot. The previous owner tried to weld the crack which obviously doesn't work well.
I went ahead and ordered the IPD header and started fitting it last night. Initially I bolted it in place and then tried to fit the intake manifold. It wouldn't go on no matter what I did so I tried putting the intake on first. That didn't work either so I took a step back to see what was going on.
After a little searching and feeling, I saw that the intake was running into the exhaust manifold flange on the underside of the head.
Today I ground a small amount of material off the intake and they slipped together easily. I've emailed IPD to see if this has happened to others and we will see what they say.
With that behind me I can't wait to take it out and see how it sounds. Also looking forward to driving without worrying about that massive crack lol.
Old 12-16-2015, 01:15 AM   #159
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
I told you I had a manifold
But now that you have a 4into1 header it will sound great. The engine will want to rev a little quicker and your power range will be in higher RPMs
If you dont have a overdrive it's actually a good setup. The header is designed for more top end performance. I got 23mpg driving 65-75 to portland with another 250lbs guy using the same setup. I recommend 2 inch piping for usable power. Your stock engine doesn't need 2.250 or 2.5 with a single weber
When you want more power just upgrade to a weber 38dges it's like the progressive but both barrels are matched in size and fueling (both barrels open in sync)
Old 12-16-2015, 01:34 AM   #160
Coupid
Coupid's Avatar
Damn, yes you did! I completely forgot that. I still have that rear sway bar if you're interested.
The car doesn't have overdrive.
I was able to easily connect it to the stock exhaust where the cat should be. I think this should keep me satisfied for a while but I'll keep that 38dges recommendation for when I decided I need to get more power.
I fired it up in the garage and it sounds about the same as it did at idle. Since it was like 8:30 I figured I'd keep the revving to a minimum so I didn't upset the neighbors.
Can't wait to get it out this weekend so I can see how it drives with the taller springs and I can hear the new header! I'm going to install a tach so I can have a better idea of what the engine is doing. (if I install the tach I'll be a lot less likely to buy that gorgeous 140GT cluster that hiperfauto is selling)
Old 12-16-2015, 09:57 AM   #161
Jack
junkman
Jack's Avatar
Anyone know where I can get one of these?
still looking for one? I got one in "decent shape"
The mystery exhaust showed up and it exceeded my expectations:
love Anza mufflers - I have one on my 245 and it sounds great
great progress on the car! Inspiring me to update my thread and start working on it too
Old 12-16-2015, 05:21 PM   #162
Johann
Johann's Avatar
To bad those Anza's only last for several hours in harsh environment..
Johann is offline   Reply With Quote
Old 12-16-2015, 07:38 PM   #163
Jack
junkman
Jack's Avatar
you know nothing about volvos Johann
secretly drools over your shop and volvos and volvo powered opel
Old 12-17-2015, 01:34 AM   #164
Coupid
Coupid's Avatar
Thanks Jack! Yeah I found one in decent shape a few months ago.
Old 12-20-2015, 06:52 PM   #165
Coupid
Coupid's Avatar
Yesterday I followed this paint restoration tutorial:
http://blog.hemmings.com/index.php/2...e-stage-paint/
and went to town with the different Meguiars, cleaning wax, polish and show car glaze they recommend.
Besides having a really sore shoulder today, it came out really well. The oxidation is gone and the paint has a nice warm shine.
I took it to cars and coffee this morning. First time driving on the taller springs and with the header. Both are nice improvements and the car got a lot of interest from the "oh my old professor used to have one of those back in the day" crowd. It was an absolute blast!
Old 12-22-2015, 09:35 PM   #166
Coupid
Coupid's Avatar
Finally got around to installing a tach that I purchased a few months ago. When I bought it I thought it was a 52mm face but I was wrong. Since it's a lot larger than I would have liked I just mounted it with double sided tape under the dash.
It will be great to known for sure where the idle is set and then what the engine speeds are on the freeway! Then I can save my pennies for something more period correct or an r-sport cluster.
Old 12-23-2015, 05:34 PM   #167
Coupid
Coupid's Avatar
Thanks to the new tach I was able to confirm that the car was idling really high. It sounded like it was high but today I saw it was at 1200rpm. Since I did the initial carb tuning with the timing and points all out of wack, the carb needed to be readjusted.
I had bumped the primary idle jet up to a 65 and today I ended up dropping down to a 45. now the idle is around 800rpm! Learning is fun!
I took a little drive to celebrate:
Old 12-23-2015, 05:36 PM   #168
cwdodson88
good looking car!
The Build Thread
SVEA - PUSHROD TURBO!
Old 12-23-2015, 06:27 PM   #169
V-O-L-V-O
V-O-L-V-O's Avatar
Stance is sooo cool in that picture!
64 PV 11234E SPORT
65 PV 11134F
65 Amazon 13134 VE
72 145 SPORT
74 144GL 1444941 A
V-O-L-V-O is offline   Reply With Quote
Old 12-23-2015, 08:55 PM   #170
Coupid
Coupid's Avatar
Originally Posted by cwdodson88 View Post
good looking car!
Thanks
The road is a little downhill so it accentuates the rack a little bit.
Old 12-24-2015, 02:14 AM   #171
240keith
Floats your Boat
240keith's Avatar
that looks dead on man!
Old 12-24-2015, 10:51 AM   #172
LloydDobler
LloydDobler's Avatar
Looking good!
Also the proper way to adjust points is to unscrew them, throw them in the trash and install electronic ignition. Thank me later.
'66 122 - Collectible project
Old 12-24-2015, 11:36 AM   #173
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
That picture gave me a chubby!
Lookin good
hahah don't let ken read that! But I agree with you!
Originally Posted by LloydDobler View Post
Looking good!
Old 12-24-2015, 02:42 PM   #174
Coupid
Coupid's Avatar
Thanks Keith! It's come a long way since you rode in it last.
Looking good!
I was really tempted to do just that but I decided to keep trying with the points. Now that they are properly gapped, they work well. If they go out of adjustment again soon then I might get the pertronix.
Lookin good
Thanks man
Old 01-04-2016, 09:58 PM   #175
Tfrasca
Tfrasca's Avatar
This car looks great!
