Old 10-06-2015, 04:54 PM   #1
St3v3
Default The Frog v3 - 242 5.3tt
I have previously owned two Shenandoah green/Medium green 242 from 1976.
The first one had a M50B25 from BMW E34 with VEMS ecu
The second one had a S38B36 from BMW E34 M5, also with a VEMS ecu
So when i found another one i just had to buy it
Someone had started to build a turbo B230 in it and it was in bits and pieces so i started with some rustrepair on the floor, and it was a quick job because there wasnt any ;)
Got the interior together
Made it driveable and got it thru inspection(and then it is road legal for two years)
St3v3 is offline   Reply With Quote
Old 10-06-2015, 04:55 PM   #2
St3v3
Same day as the inspection i threw the B20 out and started to fit the new engine
5.3 LM7 from a Tahoe
Not much space for the truck intake, had to cut som plastic and reinforcement on the hood
The pan needed some cutting too, and obviously i have to cut it some more
I used this device to get the engine centered in the front while i was getting it to sit like i wanted. Makes the job alot easier
Old 10-06-2015, 04:58 PM   #3
St3v3
Today i went and bought some bling for the engine. LTT=LuxeTwinTurbo
Super HX40, should get the job done!
Thinking about using the stock manifolds. Nice fit in the 240 engine bay
Old 10-06-2015, 05:28 PM   #4
St3v3
Maybe i should mention that i am from Sweden...some words may not be correct
Old 10-06-2015, 06:34 PM   #5
Coupid
Coupid's Avatar
Your English is great and this build is going to be outstanding to watch
1972 142S Project Thread: http://www.turbobricks.com/forums/sh...d.php?t=311926
1991 780 Sold
1979 244DL Sold
1986 740+T Sold
1983 242T Sold
Coupid is offline   Reply With Quote
Old 10-06-2015, 07:04 PM   #6
matt b
Yeah, even if your english lets you down in the future (it hasn't yet), the scope of your project and the quality of the build more than make up for it. We'll be all right.
matt b is online now   Reply With Quote
Old 10-06-2015, 08:11 PM   #7
Duder
His Dudeness, El Duderino
Duder's Avatar
This looks promising.
What happened to the S38 powered 242? I found your build thread but last post was from a few years back.
How well was the S38 suited to the car?
Old 10-06-2015, 08:28 PM   #8
Tuff240
240 Ninja
Tuff240's Avatar
Frog... perfect name.
Your English is better than most Americans, you'll be fine.
Subscribed.
-Patrick
Old 10-07-2015, 05:52 AM   #9
adomz
Volvo 486 owner :D
adomz's Avatar
Hey!! Great car and great name for it too!!
Don't worry about your english too much. You're all good!
Keep the updates flowing ;)
ADam
1991 244 GL, lh2.4 b230ft, 3" SS Exhaust, 7krpm Chips, 16t at 1.3bar , and some more
=->Adam's Joint Creations<-=
adomz is offline   Reply With Quote
Old 10-07-2015, 07:05 AM   #10
ryan350ci
ryan350ci's Avatar
This is heading in the right direction
1977 264GL - 383/700r4
1983 242 - (shell)
1995 944 Turbo - B230FT
2006 XC90 V8 AWD (Wife's Daily)
2007 S60 2.5T AWD (Daily)
1985 300zx - V8 Swap
1989 S-10 - V8 Swap
1974 Nova SS Hatchback
1993 F150 - Straight Six
1992 Ranger 4x4 - 2.9 V6
1968 Mustang GT Fastback 428 Cobra-Jet
1988 F250 4x4 - 5.8 V8
(Sold)1989 765 Turbo/IC - B230FT
(Sold)1990 Mustang LX 5.0
Feedback Thread:
http://forums.turbobricks.com/showth...24#post5254924
ryan350ci is offline   Reply With Quote
Old 10-07-2015, 10:44 AM   #11
Råda
Volvoretard/Partshoarder
Råda's Avatar
Ballt bygge!
Jonas
Old 10-07-2015, 11:18 AM   #12
Pasis
Nice turbo Frog))!
Pasis is offline   Reply With Quote
Old 10-07-2015, 03:49 PM   #13
St3v3
Thanks everyone! Och tack Råda ;)
I sold it and the guy who bought it drove it for a while and then he took the engine out and put in in a BMW e30
The S38 is a HUGE engine but a 240 fits everything Only had to notch the oilpan a little, change the angle at the end of the headers and make a new lower mount for the radiator because the engine is so long.
Old 10-10-2015, 06:15 PM   #14
St3v3
Started to do some plumbing today...not so complicated and should do the job
Old 10-11-2015, 03:58 AM   #15
Pasis
What transmission you plan use?
Old 10-11-2015, 04:34 PM   #16
St3v3
Old 10-12-2015, 01:27 PM   #17
chris gilmour
dear god, i love you. watching this!!
chris gilmour is offline   Reply With Quote
Old 10-12-2015, 01:52 PM   #18
propav8r
F*ck Edgar
propav8r's Avatar
Saw a photo of your centering jig on the LS forum the other day. Great work so far!
What are the plans for the motor? (Cam, springs, etc?)
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 10-12-2015, 05:55 PM   #19
St3v3
Manual 6-speed from a BMW diesel
I am going to swap cam, springs and pushrods...don´t know what i am going to use yet. Rest of the engine will be stock
I will be running manual 6-speed, E85, intercooler
Old 10-14-2015, 07:11 PM   #20
St3v3
Anyone got a T56 from a LS1 who can be kind and measure some dimensions for me?
I need to know the following:
A. How long is the part of the input shaft that is sticking out of the bellhousing?
B. How long is the part of the input shaft that is for the pilot bearing?
C. How long are the splines?
Old 10-16-2015, 04:08 AM   #21
cosbySweater
cosbySweater's Avatar
Im in boston but i have one at the shop i can measure for you when i return home. Ill be in sweden next summer, would love a ride in this beast!
Old 10-17-2015, 05:23 AM   #22
St3v3
That would be very kind! When will you return home? Where in Sweden? I live in the north
Made some brackets for the Holset twins yesterday, the exhaust manifolds should like that
Today i started with the downpipes. Made some reductions for the 3.5" downpipes so they would fit the turbo. Used a hydrualic press and some parts from a wheels balancer
Then to the downpipes
Old 10-17-2015, 11:45 AM   #23
cosbySweater
Rattvik, its a far drive but judging from the build it will be worth it!
Old 10-17-2015, 12:07 PM   #24
240 JAH
Volvo Curator
240 JAH's Avatar
Those seats you put in there are great ! I haven't seen that combo before. I like what you are doing here !
82' F613, 78' 264GL / 79' 242GT / 84' 244 Diesel / 70' 164 / 66' 122 4dr (Project RAT ROD) /67' 122s (P132441M) / 88' 244DL
/ 86' 245GL / 89' 245 Trailer
EBAY Handle: Guitarphotoman
Seller/Buyer feedback
1967 122s Restoration Thread
240 JAH is offline   Reply With Quote
Old 10-17-2015, 12:37 PM   #25
St3v3
The seats are the original ones. It´s a 242L, the big differenses from the DL is the seats, the rear side windows cant be opened, black rubber floor mat instead of the brown one(in my car it is from a 245 -78 so it is totally wrong), no clock in the middle of the dash, B20 engine, no air vents in the kick panels
