Old 08-24-2016, 05:44 PM   #76
St3v3
Woho! Green hood hinges at last! :D
Got my aluminium radiator welded so now its mounted in there somewhere
Had to ebay myself a new thermostat housing
The stock IAC doesnt work so well with the engine management system i am using so i made some fittings for another model
Some vacuum- and coolant-hoses to do and it will be ready for some longer startups
St3v3 is offline   Reply With Quote
Old 08-24-2016, 05:50 PM   #77
St3v3
A friend sent me this...pretty accurate
"When you're about that sleeper life"
Old 08-24-2016, 05:51 PM   #78
Duder
His Dudeness, El Duderino
Duder's Avatar
This is rad. Some great inspiration photos here!
I'm curious to read your impressions once you have it running & driving. I'm planning a similar project but using a 245 as the base vehicle and adding a 4.6L "3 valve" V8 from a 2005 Mustang GT, with twin GT2860RS turbos, and a 5-spd T45 trans. I have all the parts and the car but it's still in the project queue.
Old 09-04-2016, 04:53 PM   #79
St3v3
Got nothing better to do so started with the interior. Dont make me sit in the middle in the back seat
But it was nice to get the back seat in the car again, now i have somewhere to sit when im tired(happens pretty often) (to bad someone had drilled a bunch of holes in the dashboard before i bought the car, but will maybe put a bracket for a tablet connected to the VEMS)
Almost got the dashboard all together again and the shifter too, with working neutral safety switch(not so important when i dont even have a transmission ) But now i can sit in the car and play around some...feels good!
https://www.youtube.com/watch?v=p4fh036K_bI
In the video i start it for the first time that day and without touching the gas pedal...but will have someone help me with the tuning later on.
Old 09-04-2016, 05:03 PM   #80
Pro Sneaker Peddler
Was the clock an optional extra back in Sverige?
Old 09-04-2016, 05:12 PM   #81
St3v3
L didnt have the luxury items that a DL had Like no clock, the rear side windows cannot be flipped out in the rear, no fresh air inlets in front of the front doors, the floor carpet is black rubber, rear interior panel below the side windows is some painted cheap material and not like the door panels, engine is B20 instead of B21 and probably some more small details that i have forgot
Edit: The seat covers are different too
So in different word is L a light weight race car!
Old 10-02-2016, 01:38 PM   #82
St3v3
Havent been feeling good lately so not much progress
No more clutch and didnt have a brake pedal from an auto so made a special
Pute my other Volvo in storage for the winter so i tried the widened 17" steelies from it on the 240(did lower it in Paint though )
Put a bluetooth stereo and some speakers in it so i can play some heavy metal! (the dymo label says "No ****ing hip hop) in Swedish )
Old 10-02-2016, 02:19 PM   #83
Råda
Volvoretard/Partshoarder
Råda's Avatar
Ingen jävla hip-hop
Jonas
Old 10-06-2016, 07:48 PM   #84
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
nooooooooo cmon lol
Old 10-23-2016, 04:02 PM   #85
St3v3
He who has the most transmission mounts when he dies wins
(the th375 is only temporary so i can move the car under its own power)
Old 10-30-2016, 05:00 AM   #86
St3v3
Lame movie, but it´s alive!
https://youtu.be/SbJC2mYGibY
Old 10-30-2016, 08:37 AM   #87
babbit bearings
I love your car.
You know the TH375 is not really a bad transmission. The smaller output shaft is still strong enough.
babbit bearings is offline   Reply With Quote
Old 10-31-2016, 08:33 AM   #88
St3v3
Just doing some testing, cant wait to fix a couple of stuff and get it tuned
https://www.youtube.com/watch?v=CdXUmKUmB6o
Old 10-31-2016, 09:42 AM   #89
Thor
Thor's Avatar
The sound . . . .
Love it. Keep it up.
1991 240 M-47 daily driver
Build thread: 91 240
Feed back: Here
Thor is offline   Reply With Quote
Old 11-01-2016, 06:44 PM   #90
St3v3
Just playing around
https://youtu.be/jHPKUPQ5BcY
Old 11-01-2016, 08:03 PM   #91
babbit bearings
I bet your neighbors love you.
Why did you buy VEMS?
Old 11-02-2016, 12:00 AM   #92
St3v3
I already had the VEMS left over from another project and i have very good support on it from my tuner
Old 11-24-2016, 10:05 AM   #93
Pasis
Excellent project!
Tell us about the results of the project? What is the power at which the boost pressure at which RPMs?
I'm doing a similar project, but I use the engine LQ9 6 liters. Now I need to make a choice of the turbine. I have a goal about 600-700 HP. I think between Holset HX55pro or two turbines Hx40 Super. But because of the lack of experience with large engines I have my doubts. Perhaps one HX55 will be restrictive for this engine.
Pasis is offline   Reply With Quote
Old 11-29-2016, 05:31 PM   #94
St3v3
No updates for a while but i have been working on it
The oil pan was the lowest point on the car so i built some protection for it and also added a tow hook
My TH375 wasnt shifting from first so i bought a RVMB TH400 with a Hughes GM35 converter. Will be swapping converter when i turn the boost up
A previous owner had tried to install some gauges on the dashboard and totally destroyed it so i made a bracket for a pad that is connected to my engine management
Bought some 80lbs injectors
The new injectors were taller so i had to chop down the stock fuel rail so it wouldnt hit the hood. Found a pretty big restriction in the feed line so i grinded it down
The new transmission was shorter than the old so i made i new transmission mount
And a new drive shaft
Had to cut the carpet when i made the bigger transmission tunnel
Bought some carpet and filled in the blanks. Doesnt look to pretty in the picture but with the seats back in it isnt visible
Took it to the local supermarket for some shopping. Have driven it a couple of hours and it feels like its going to be a nice car!
Think it sounds pretty nice It needs some tuning(and more than half throttle)
https://www.youtube.com/watch?v=IAsaxq2BKN4
Old 01-01-2017, 07:56 AM   #95
St3v3
https://www.youtube.com/watch?v=FYxI0O0RLLk
Old 01-01-2017, 02:03 PM   #96
JPS
really cool car! love the sound.
JPS is offline   Reply With Quote
Old 01-01-2017, 02:17 PM   #97
p18002.5t
Vilket jävla bygge ...ass coolt
p18002.5t is offline   Reply With Quote
Old 01-02-2017, 10:40 AM   #98
cwdodson88
Love it! Happy new year! Amazing job.
The Build Thread
SVEA - PUSHROD TURBO!
Old 02-23-2017, 09:10 PM   #99
St3v3
Swap
https://www.youtube.com/watch?v=qtkpKxHFxd0
Old 02-23-2017, 09:46 PM   #100
megulon-7
Most awesome thing ever
megulon-7 is offline   Reply With Quote
