Old 02-24-2017, 01:48 PM   #101
Mr. Blewregaurd
Mr. Blewregaurd's Avatar
Originally Posted by St3v3 View Post
Finest piece of comedy I've seen here in a while.
"It's only temporary if it doesn't work."- Red Green
'85 244 N/A Auto-x money pit
'68 220 Arts and crafts project
'04 Ranger DD/Mobile home
Mr. Blewregaurd is offline   Reply With Quote
Old 02-24-2017, 02:24 PM   #102
JPS
JPS is offline   Reply With Quote
Old 02-24-2017, 02:43 PM   #103
Råda
Volvoretard/Partshoarder
Råda's Avatar
Haha, this is gold!
Jonas
Old 02-27-2017, 09:40 AM   #104
spruill242
spruill242's Avatar
But wait.... Does the Camolvo run?!
'90 Spec Miata.. The barbie car I never got as a kid.....
http://norfolkdustlessblasting.com/ ... Professional stripper...
Originally Posted by HiSPL View Post
I like to masturbate with a cheese grater.
spruill242 is offline   Reply With Quote
Old 02-27-2017, 09:54 AM   #105
St3v3
Yeah, it does 27 km/h(17 mph)@6000rpm
My friend bought it for about 5000usd, took the LS1, 4L60E and rear axle from it and replaced it with parts from a junk Volvo 740
Registered it as an "A-tractor", repainted it and sold it for 11000usd. 15 year olds in Sweden can drive A-tractors but they have to be limited at 30km/h top speed, and the top speed has to be at the rpm where the engine makes the most hp
I made an article about it in the swedish magazine Bilsport
St3v3 is offline   Reply With Quote
Old 03-02-2017, 03:30 PM   #106
St3v3
Started to build an exhaust with x-pipe
So far its ending with two mufflers in front of the rear axle, but i think it will have two more mufflers and end at the rear bumper.
I hate the sound of the 044, its a good think i have two in-tank pumps for later
https://www.youtube.com/watch?v=6SrouD9EXQU
Old 03-28-2017, 02:40 PM   #107
St3v3
Old 03-28-2017, 02:48 PM   #108
cwdodson88
Nicely done sir
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-28-2017, 11:40 PM   #109
BillyMaysHere
BillyMaysHere's Avatar
Dyno numbers?
Old 03-29-2017, 02:15 AM   #110
St3v3
Not been on the dyno yet but im running 11 psi in it so i guess its somewhere between 4-500 hp. More boost to come
Old 04-30-2017, 05:46 PM   #111
St3v3
Have done some work with my upgraded fuel tank. Here some CNC-drilliing with the carrot-lathe
Found en electrical connector that is made for fuel tanks
Didn´t feel to safe to use the grinder and welder on the tank But i am still alive Washed it and filled it with water
Anybody know what the plastic container is there fore? Its located in the tank between the fill tube and the fuel sender and is probably about 12x8x8 inches and there is a piece of metal holding it in place
Smuggling drugs maybe? :D
Anyone think this will work?
[img]
And i just got my order from Jakes Performance. Overhaul and upgrade-kit for my TH400
Old 05-24-2017, 03:20 PM   #112
St3v3
Bought a "$499 budget PTC converter"
Got my tank painted with some epoxy, Going to paint it with some thick paint to, maybe that will make the sound of the pumps even lower
Old 05-25-2017, 12:39 AM   #113
LC4CARL
Aero challenged
LC4CARL's Avatar
One of the most satisfying things I've done with cars over the years was a shift kit and adjustable centrifugal and vacuum modulators on my trucks TH400. It really helped get the combo working together.
Life begins at 10PSI.
Old 06-20-2017, 12:40 PM   #114
St3v3
Tore in to my slipping TH400 and these are some of my findings
But i also had a TH375 that i wasnt using so i decided to use the housing from it, but seems like someone had used a sledgehammer to put it together
Thankfully a friend could weld it for me, with really nice result
Putting together two broken autos + upgrading kit from Jakes Performance was really interesting
Old 06-20-2017, 12:44 PM   #115
St3v3
Alive and kicking again!
https://www.youtube.com/watch?v=8XMHDi4-Ji4
Installed the new tank with two Walbro 450. So much nicer than the external 044
Its really quiet with the stock cam and the "small" turbos. Was thinking about adding more mufflers but i dont know now..
1" instead of stock 5/8" (or 25mm instead of 16mm ;) )
Old 06-23-2017, 04:15 PM   #116
St3v3
Small burnout
https://www.youtube.com/watch?v=JGyt56fTSEk
Old 06-24-2017, 06:09 AM   #117
JPS
so there are the clouds come from when the wind is coming from the north
really cool car btw!
Old 06-24-2017, 06:44 AM   #118
St3v3
And another one:
https://www.youtube.com/watch?v=WKyvhSmME90
Old 06-24-2017, 03:52 PM   #119
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Love the burnout. Mr. Happel would be proud haha
60' 1.66
1/8 6.53 @ 113.3mph
1/4 9.99 @ 140.4mph
21psi 14.5deg timing E85
3140lb no driver
3320lb with driver
Old 07-07-2017, 02:31 PM   #120
St3v3
I have reuploaded almost all of the pictures in the thread so i hope someone will read it
No more Photo****et!
Old 07-31-2017, 11:25 AM   #121
St3v3
Some pictures from last week in Lycksele, Sweden. It´s called "Motor week" and some of the events are burnout competition, cruising and dirt track driving. Broke three axle shafts in 24 hours before the rear end exploded :D
Old 07-31-2017, 12:27 PM   #122
cosbySweater
cosbySweater's Avatar
God I miss swedish auto events
Old 08-03-2017, 04:11 PM   #123
St3v3
Burnout competition
https://www.youtube.com/watch?v=B1XKDqpPtDY
Old 08-20-2017, 04:05 AM   #124
St3v3
Three small burnouts
https://youtu.be/eYaRf4NnMVk
Old 09-22-2017, 09:03 AM   #125
St3v3
