Old 02-07-2018, 02:34 PM   #376
oldschoolvolvo
oldschoolvolvo's Avatar
That’s what I have in mine What bearing did you go with ?
I only notice it sometimes... in neutral at stop with foot off clutch, I usually keep my foot on it. First thing I thought was
Overall there is a lot more to a t5 swap than most ever talk about.... fixed one set of problems with the m46 and replaced it with other in the t5... fuk
Truth.
For the pilot bearing you can use a 6003-2RS ball bearing instead of the needle bearing. It is a drop in replacement.
I’m curious how your sound deadening will work out. I have some Dynamat-style product on the floor and tunnel and just ordered some 40oz jute padding to go underneath the carpet. Hopefully that will take some more noise out.
-Mike
1998 V70 T5
|Feedback|
Old 02-07-2018, 03:17 PM   #377
Tfrasca
Tfrasca's Avatar
I left the Ford needle bearing in there since it felt fine. And really, the only way the pilot bearing could cause the rattle noise I hear in the case is if it was sized improperly, and allowing the nose of the input shaft to wiggle around. But that's not happening, and the input shaft on mine is rock solid. Zero play.
Old 02-07-2018, 03:22 PM   #378
Tfrasca
Tfrasca's Avatar
Originally Posted by oldschoolvolvo View Post
Truth.
Like I said, I can't imagine how the pilot bearing would cause this noise unless the ID was just way too big. I'm sticking with the needle bearing for now. Maybe I'll try the ball bearing next time I pull the trans, just for science.
I have high hopes for the Dynaliner. It's the same thickness as the jute under my carpet, and that makes a huge difference in overall noise and heat. The stock jute comes about halfway up the sides of the tunnel, and right above it, the tunnel is scorching hot. But an inch below where the jute starts, it's cool to the touch.
Even if it helps the noise a bit, I still wouldn't recommend a T5 for a nice daily driver.
Old 02-07-2018, 03:29 PM   #379
Jack
Banned
Jack's Avatar
The noise I’m trying to trace is a droning at highway speeds. Dynamat was a big improvement in noise and sun heat in my 245... so much so that you can “comfortably” drive with windows up in mid 90s with the kickerpanel vents both open
Well worth the money
Old 02-07-2018, 04:15 PM   #380
Tfrasca
Tfrasca's Avatar
The droning in 5th is bad on mine too. It seems to be worse from 2500-3k, and really bad on decel.
Did you put Dynamat on the roof of your 245?
Old 02-07-2018, 04:40 PM   #381
Jack
Banned
Jack's Avatar
damn it I thought maybe my driveshaft was still scraping or I had the angles wrong .... but i dont feel any vibrations..
yes. along with the foam stuff - HUGE difference. I lined my floor with the lows stuff when I first got the car 7(?) years ago. Im planning on going back and redoing it all with dynamat
just looked at my thread and all the damn pics are fubar.... but per sq inch dynamat is lighter than stock stuff but you end up using a lot more of it. (pg 9-10 if you got the fix for dead photobucket)
Old 02-07-2018, 05:25 PM   #382
Pro Sneaker Peddler
Same here. I think it's endemic to B230s.
Old 02-07-2018, 06:07 PM   #383
Stiggy Pop
Stiggy Pop's Avatar
good sound deadening material (recommend RAAMmat) and some insulation will help with the trans noise.
I'd rather listen to the trans a bit then keep all the heat in it with a blanket if it's at all a 'regular use' car.
'79 242
943 pickup
Old 02-07-2018, 06:23 PM   #384
Tfrasca
Tfrasca's Avatar
Does yours only do it in 5th?
Old 02-07-2018, 06:25 PM   #385
Tfrasca
Tfrasca's Avatar
Yeah, I abandoned the blanket idea pretty much instantly. I'm going to pack as much sound deadening in there as I can, drain out some of that Lucas Oil Stabilizer, and just run it.
Old 02-07-2018, 10:19 PM   #386
FreeEMSFred
FreeEMSFred's Avatar
You said it was rebuilt, was it rebuilt with new gears? Or just bearings/synchros? If the latter, (some of) the gears likely have a wear pattern on them that is no longer aligned with the bearings replaced. Quite a common issue on rebuilt boxes, irrespective of box.
Old 02-07-2018, 10:51 PM   #387
Tfrasca
Tfrasca's Avatar
I wish I knew. The seller just said "rebuilt with an HD rebuild kit", and I hadn't done any research at that point, so I didn't have much to say to that.
Old 02-27-2018, 11:56 AM   #388
Tfrasca
Tfrasca's Avatar
I put in about 1000 really hard miles over the weekend while doing the Coastal Range Rally out here in California. The car did amazingly well, both in the turns and where power is concerned. Really impressed with the car, overall.
That said, the T5 has only gotten louder, and now has a substantial input shaft seal leak. (I thought this was the RMS, but it's mostly the input shaft). I'll be pulling the trans soon, but the thought of tearing into it and probably replacing gears and having to re-rebuild it is bumming me out. I currently have a Ford Motorsport m-7003-z sitting in my Summit Racing cart. It would be a completely ridiculous purchase, considering how much I paid for the T5 I currently have, but I'm pretty ready to bite the bullet and move past the transmission part of this build.
This is the trans I'm looking at. The 2.95 first would be really nice with my 4.30:1 rear end.
https://www.summitracing.com/parts/fms-m-7003-z
Feel free to advise for or against this move, if you have opinions.
Old 02-27-2018, 12:03 PM   #389
Stiggy Pop
Stiggy Pop's Avatar
That's the transmission I have in my car, with a 3.91 rear and a .8 5th. It's great, I really don't have any complaints with it. Mine came from Modern Driveline who supplied the fifth gear as well as a few other upgrades. I think it ran around $2,300.
Old 02-27-2018, 12:41 PM   #390
Tfrasca
Tfrasca's Avatar
I'm waffling on the .80 or .63 5th. The .63 even with my 4.30 axle is too tall for mountain roads, and I found myself between 4th and 5th a lot over the weekend. However, it's fantastic for highway cruising, which is realistically what I'll be doing most often.
Old 02-27-2018, 01:00 PM   #391
gsellstr
gsellstr's Avatar
I absolutely hated the .85 5th in my Celica box with a 4.10. Dropped about 300 rpm over 4th, so cruising on the freeway at 70 was spinning around 3800. With the .68 in the T5 it's around 3k. Yeah, it's a big drop, would be less with the 4.30, plus with boost it wouldn't be too bad I wouldn't think.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-27-2018, 01:06 PM   #392
Stiggy Pop
Stiggy Pop's Avatar
I don't really use my car on the highway, so that was not a factor in the decision for me. I use fifth gear to pull through twisty, elevation changing backroads where a good fast cruising speed is 65-70mph. It is FANTASTIC for that, car is always in a sweet spot. Honestly my Viggen isn't geared much taller in 5th and it never bothers me. I have just never felt the need for an '85mph at 2300rpm' gear. Our roads aren't that flat and it seems like a waste of gear to me.
A .63 would completely suck for my driving. That's why gearing is all about where you are and how you'll use the car.
Old 02-27-2018, 01:41 PM   #393
Tfrasca
Tfrasca's Avatar
Yeah, like I said I found myself winding 4th out as opposed to dropping into the low 5th, and at times it was annoying. But then I drive 300 miles back to Santa Cruz on 101, cruising at 80mph and 3k rpm. That was nice.
I think I'm going to pull the trigger on this new transmission. The one in my car now will have the leaky input shaft seal replaced and will be up for sale or kept as a spare. 2018 is expensive so far...
Old 02-27-2018, 01:53 PM   #394
cosbySweater
cosbySweater's Avatar
When I had the t5 in my hilux it had 4.53 gears in it iirc and that made the huge drop between 4th and 5th feel great
Old 02-27-2018, 02:33 PM   #395
Tfrasca
Tfrasca's Avatar
Yeah, that's the other cool thing about having a Dana 30. If I ever want a different FD, gears are dirt cheap.
Old 02-27-2018, 03:02 PM   #396
Stiggy Pop
Stiggy Pop's Avatar
anyone got a 5th you can drop in (that said I don't think the .8 was a direct drop in) that would split the difference a bit?
aren't they all!
Old 02-27-2018, 03:14 PM   #397
Tfrasca
Tfrasca's Avatar
aren't they all!
I've emailed Modern Driveline asking what the options are. Just looking around, I don't see anyhting other than .63 or .8.
Old 02-27-2018, 03:21 PM   #398
cwdodson88
didnt some v6 boxes get a .73 5th? pretty sure thats what mine is a 3.15 1st and .73 5th, 3.73 rear and its nice, except chirpping 1st all the time.
The Build Thread
SVEA - PUSHROD TURBO!
Old 02-27-2018, 03:41 PM   #399
gsellstr
gsellstr's Avatar
Hit up Astro down in Florida, they may have some info. A .73-ish would be nice for sure.
Old 02-27-2018, 07:59 PM   #400
Tfrasca
Tfrasca's Avatar
Just got off the phone with Modern Driveline. They can do a brand new T5z with a 2.95 first and a .73 5th for a little under $2300. That sounds like it's going to do the trick.
