Old 01-28-2018, 09:09 PM   #1801
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Originally Posted by LC4CARL View Post
Got my new speakers installed...
...Walmart subs?
Old 01-28-2018, 10:50 PM   #1802
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by Centsableone View Post
Yes. I have a 1992, with the "enhanced" system which requires the extra hose portion and this kit was worth twice the price!
Thx!
Life begins at 10PSI.
Old 01-28-2018, 10:52 PM   #1803
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by KeizerBrickGuy View Post
Glad the car puts a smile on your face again.
Bars, Springs, shocks, etc, this car stays pretty flat through the bends. Well, you know...
Old 01-28-2018, 10:54 PM   #1804
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by Wilford Brimley View Post
...Walmart subs?
Naw, there was a dude in a van with the engine running. Seemed legit.
Old 01-29-2018, 11:12 PM   #1805
LC4CARL
Aero challenged
LC4CARL's Avatar
Nothing to see here...
Oddly, the driver's side was chewed up while the passenger side was solid.
Old 01-29-2018, 11:45 PM   #1806
LC4CARL
Aero challenged
LC4CARL's Avatar
So what's the deal with the lower rear arms? Rubber wears, poly binds, Ben's spherical?
Old 01-31-2018, 12:20 PM   #1807
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Ben's Spherical or Volvo rubber. The axle needs to be able to articulate and poly is a bit to stiff in that application.
-Stephen
#mclovethesenuts
Old 01-31-2018, 12:24 PM   #1808
Pro Sneaker Peddler
Poly makes it so loud too.
Old 01-31-2018, 12:26 PM   #1809
KeizerBrickGuy
Sh*t pot stirrer
Old 01-31-2018, 01:42 PM   #1810
aaronely-
clean
1987 744t m46 146k
1990 245 m47 198k broken odo
aaronely- is offline   Reply With Quote
Old 01-31-2018, 07:17 PM   #1811
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by aaronely- View Post
clean
You must be referring to Harlards car...
Old 01-31-2018, 07:18 PM   #1812
LC4CARL
Aero challenged
LC4CARL's Avatar
Hope to drive it tonight. The poly panhard is "clunky." The front actually seems good.
I understand the lower rears are a PITA, so I'll likely leave those alone.
Old 01-31-2018, 07:41 PM   #1813
Pro Sneaker Peddler
That thing's not clean :-/
Old 01-31-2018, 08:04 PM   #1814
KeizerBrickGuy
Sh*t pot stirrer
They are a PITA, but a necessary evil and much less frustrating when you install Ben's product.
Old 01-31-2018, 08:28 PM   #1815
LC4CARL
Aero challenged
LC4CARL's Avatar
On the lower rears, the "big ends" are pressed into the axle housing or the control arms?
Old 01-31-2018, 08:38 PM   #1816
Each bushing is pressed into two 'ears' on the axle.
Old 01-31-2018, 08:40 PM   #1817
KeizerBrickGuy
Sh*t pot stirrer
This.
Which is why everyone hates/avoids doing them.
Old 02-01-2018, 02:14 AM   #1818
LC4CARL
Aero challenged
LC4CARL's Avatar
Yeah, thatís what I thought. Just take the axle down to the machine shop? Oh well. Any locals want to walk me through this sometime? Iíll trade you some cut springs.
Old 02-01-2018, 02:18 AM   #1819
LC4CARL
Aero challenged
LC4CARL's Avatar
Car drove great tonight BTW. Streering wander problem is getting better. Exhaust is so awesome.
Old 02-08-2018, 12:23 AM   #1820
LC4CARL
Aero challenged
LC4CARL's Avatar
Tore down the old M47 to see what's inside. Interesting. Total respect for those that know how to service these.
A few drops of oil on the ground under the new trans. Loaded up the pressure sprayer with hot water and Simple Green. Looks like an output seal leak. Should have...
Put a wrench on all the trans and suspension fasteners. So far so good. Need to have it aligned. Going to let the rear control arms ride until after the turbo motor.
Ran by the PnP for some B21 bits. Found a T-belt cover, pulley and (unpainted) valve cover.
Got a call from Kjets, do I still have the old trans? Crap. Should have left it together...
Two and a half months until Davis: To order Wagonmeister heater valve. STS to have their power steering mounts in stock soon. Woot!
Old 02-08-2018, 07:36 AM   #1821
oldschoolvolvo
oldschoolvolvo's Avatar
This.
The large axle bushings are not that hard of a job when you use the correct type of tool and make sure you press them out towards the diff (they are slightly tapered). The DIY "homebrew" tool per these instructions works well.
http://www-ese.fnal.gov/People/wilce...shing_tool.htm
-Mike
1998 V70 T5
|Feedback|
Old 02-08-2018, 11:40 AM   #1822
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx boss!
Old 02-14-2018, 08:43 PM   #1823
LC4CARL
Aero challenged
LC4CARL's Avatar
Wagonmeister water valve on the way. STS pump mounts to be available any day now. Plan to fab up the battery mount Monday.
Old 02-15-2018, 12:54 PM   #1824
KeizerBrickGuy
Sh*t pot stirrer
I need to do the heater valve on the Wife's car...The controls are bi-polar.
Old 02-15-2018, 03:24 PM   #1825
LC4CARL
Aero challenged
LC4CARL's Avatar
Speaking of bi-polar, I think my wife needs one too...
