Old 10-19-2017, 09:07 AM   #26
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Originally Posted by 1slo9_4_oh View Post
Awesome buy!! Simi and myself are apart of flvc aswell like you mentioned above. Can't wait to see more updates! Post in the group page aswell that way if you need a couple of extra hands or random bits for any of your work, someone will be sure to help out :-)
FLVC is the only reason I even keep my facebook active
However, my son was born on OCT 2nd, so all volvo activities have been put on the back burner. I might even start bribing FLVC members with volvo parts to help clean out my garage
Need to put down a slab behind the house to move the whole operation out of the garage...
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 12-14-2017, 04:40 AM   #27
Otto Mattik
Otto Mattik's Avatar
I think those side markers(possible blinkers) are from an 850 (I have same), but hard to say in your pics ?
Nice for lane changes on freeway for annoying "Blind-spot" drivers (I actually had a "driver" do it for 10 miles, couldn't believe it when I changed lanes, after thinking he/she turned off miles back, insane)
Originally posted by Jack
_________________________
Old 12-14-2017, 09:54 AM   #28
SlowRide
SlowRide's Avatar
I feel like they’re always in gray or dark gray cars too, just blendin’ in with the road
Old 02-07-2018, 10:05 AM   #29
SlowRide
SlowRide's Avatar
Oooooookay, update time
Almost done making the parts GLT pay for itself. Just need to sell the virgos and interior bits and drag her off to zee crusher, or sell empty shell for derby or racecar.
Will be pulling the m46 soon, then will pull the b230f/aw71 from the 242.
Need to replace the water pump, too.
Parts in hand:
Ported 90+ manifold
T3/T4 with 0.48 hotside and ATP ultimate waste gate
Stock intercooler, pipes, hoses, recirc valve, maf wire extension
Stock 240 oil cooler to replace the diy job that’s on there
Ipd turbo cam, ipd two piece adjustable gear (will swap over, currently on B cam installed)
White 850 injectors (have 8 that will be sent off for testing and cleaning for 4 of the good ones)
3bar fpr
Chipped ecu/ezk
Many gauges
Coolant tees, turbo overflow and wash bottles, and other random supporting bits.
Plus T will be done on the engine stand so I’ll drill the oil return boss rather than mod an oil pan, though I do have a few I can weld a return to if I chicken out. Gonna start around stock boost level until I
Still need:
Turbo oil/water lines
PCV plate and catch can
Down pipe
Wideband
Bronze bushings for m46
Short throw shifter
I’ll keep the aw71 for accumulator mod and for when the m46 dies.
There is a plan B incase time/money becomes a factor:
Simple +T using stock garret, downpipe, and modified turbo exhaust from parts GLT.
Old 02-08-2018, 07:36 AM   #30
DET17
Reformed SAABaholic
Nice 242.... is that paint color an original VOLVO option?
Suggest you find/build a 3" DP, and then HI-FLOW CAT (if you intend to run one... hope so). CAT back, at least the size of the IPD "sport exhaust".
I'm sure you know the M46 clutch "slip" is designed to protect that weak-a$$ M46 gearbox. Unless you are going to resist the more boost urge, you'll soon be swapping that AW71 or other. Have you considered just going T5 and be done with it?
Overall, a very nice start. I've got the black Bertone leather for my 242..... swanky!
Old 02-13-2018, 09:06 PM   #31
Simi
Upsetti Spaghetti
Simi's Avatar
Parts in hand:
Ported 90+ manifold
3bar fpr
Chipped ecu/ezk
Many gauges
Still need:
Down pipe
Wideband
Short throw shifter
How parted out is the 240T? With the extra parts laying around you could maybe make it functional?
Also if you have the chance, go T5, its a world of difference.
1989 240 Turbo
1988 745 Turbo - SOLD
1991 940SE - SOLD
1995 850 T5-R
1991 740 Turbo
1987 240
Leave Me Feedback
Simi is offline   Reply With Quote
Old 02-13-2018, 10:49 PM   #32
SlowRide
SlowRide's Avatar
It’s pretty much going to be a shell with a gas tank when I’m done. It’s going to be winched across lumber onto a trailer when it goes.
There’s a T5 on facebook right now for $400, but I’ve blown the months volvo budget out of the water. Puts a big damper on the parts hoarding.
Old 02-15-2018, 10:54 AM   #33
SlowRide
SlowRide's Avatar
Have a line on some T5 swap goodies, and a greenlight from the Commander in Chief... Things might get interesting sooner than promised.
Old 02-18-2018, 01:44 PM   #34
SlowRide
SlowRide's Avatar
This is what $500 of T5 swap for the 242 looks like. Complete with Yoshifab goodies. LH3.1, hit a deer, popped a u-joint. Need to get under it and check out what they did with the crossmember and replace a u-joint or two. Time to order the hurst shifter and boot gromet ŗ la Dave Barton.
New plan:
-Compression test both b230f engines (deer 244 and 242).
-Pull LH3.1 B230f/T5 from deer 244, pull LH2.4 B230f/AW71 from 242,
-The B230f with best compression numbers goes on the engine stand for +T
-T5 goes into 242.
-LH2.4 B230F+T goes into 242
-3” DP and some exhaust
-Pick both 244’s clean and crush crush crush
Shooting to be done by summer.
Old 02-19-2018, 12:35 AM   #35
Old 02-19-2018, 01:46 AM   #36
Jack
junkman
Jack's Avatar
Pick a section of the car strip it completely. Example interior... throw out everything bad first, then save everything what you want or is good. Move to the next section with undercarriage last
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 02-19-2018, 07:49 AM   #37
SlowRide
SlowRide's Avatar
This. The GLT has almost paid for itself, still need to sell the virgos and cluster, gauge bits, interior. Only bought it for the m46 and turno headliner, but will probably keep the the rolling gear and suspension, and just winch it up onto the trailer. The lowering springs on the 242 (B&G I think) aren’t convincing me they’re worth keeping.
The 91 244 was only really purchased for the T5 and yoshifab bits, but the motor is strong/worth keeping. Might just have someone roll the chassis away
That’s how I’ve slowly been doing it. Lately, I’ve only had the 20 min or so of daylight after I get home from work to pull engine bits. Things should accelerate once my son is a little older, but at 4mo he hasn’t discovered sleeping in yet. There’s gonna be so much blue velour in the garage...
Been buttering up the manager at LKQ in an effort to let me film them being crushed. TBricks snuff film for the fan girls.
Old 02-19-2018, 01:18 PM   #38
Jack
junkman
Jack's Avatar
T Iíve only had the 20 min or so of daylight after I get home from work to pull engine bits. Things should accelerate once my son is a little older, but at 4mo he hasnít discovered sleeping in yet.
Im here to tell you you cant do much until they are 5 if you're alone with him
as for the video.. yes please
Old 03-12-2018, 08:00 PM   #39
Simi
Upsetti Spaghetti
Simi's Avatar
If you want, i'd love to come by and see what parts you got before you crush, I could maybe build a car from the spare parts you got.
Old 03-18-2018, 06:38 PM   #40
SlowRide
SlowRide's Avatar
We’ll see. I plan to replace the tired interior of the 91 with the perky velour of the GLT, seems easier than trying to sell it here or on FLVC.
