Old 06-25-2017, 06:53 PM   #26
Old Iron
I Roll
Old Iron's Avatar
Good save, many would have run from this one! A 1993, a 245, a classic! What more to say!
Look forward to seeing more progress!
Turbobricked
Old Iron is online now   Reply With Quote
Old 06-29-2017, 11:23 PM   #27
Johann245
Volvoholic
Johann245's Avatar
Wired in some Euro lights this evening.
Johann245 is offline   Reply With Quote
Old 07-02-2017, 03:14 AM   #28
Johann245
Volvoholic
Johann245's Avatar
pFound the source of the smell of fuel from around my main pump. The hose from tank to main pump had a gouge in it. Got it replaced and also replaced both pumps and filters and all the associated small parts. Got my silicone heater hoses in today. Just waiting on a delivery from FCP so I can do the head gasket.
Old 07-15-2017, 10:59 PM   #29
Johann245
Volvoholic
Johann245's Avatar
From this
To this
Old 07-16-2017, 11:59 AM   #30
Johann245
Volvoholic
Johann245's Avatar
Ordered some bilstein hds for the front end from amazon, saved $60 but also not sure when they'll be here. I've also gotten new tires, from these crap Kelly tires
To these hankooks. mounted and siped at les Schwab, bought off amazon. They'll work till the rim is upgraded.
Fixed the turn assembly lenses with just some cheap PPS ones.
Bought new hella license plate lights with some led bulbs.
Waiting on some inner tie rods from FCP to do some steering maintenance. Next purchase will be rear hds and then brakes, exhaust, bushings and then on to cosmetics.
I'll slowly fix the pictures here.
Old 07-18-2017, 10:45 PM   #31
Old Iron
I Roll
Old Iron's Avatar
Keep up the good work! It's nice seeing a classic get some love!
Old 12-12-2017, 01:36 AM   #32
Johann245
Volvoholic
Johann245's Avatar
Been awhile...
She's currently running the old RSI stage1 n/a cam(11.07mm lift, 252 deg. @ .050 lift, and 110 LSA) and pink injectors. Straight piped with single magnaflow in rear. Got my window raingaurds back. Just picked up another header from Sweden, so when I've got the money I'll get the exhaust work done at a shop. Believe I found a friend of a friend to do some head work on a spare head for not his shops rate which will be nice when I get bigger valves and springs.
Old 12-12-2017, 01:38 AM   #33
Johann245
Volvoholic
Johann245's Avatar
Also made these. I've got Polk speakers up front as well, just need new rears.
Old 02-08-2018, 04:33 AM   #34
Johann245
Volvoholic
Johann245's Avatar
Got myself a welder and been pretty busy since then. I welded my own 2.25" over axle exhaust. With a 21" cherry bomb in resonator spot and a magnaflow muffler in back piped out driver side. No cat. O2 bung welded into pipe where cat use to be, 6"flex pipe ahead of that. I believe in back pressure now. Right before I made that system I was just a cherry bomb and straight out pass side. The difference in pedal feel is definitely noticeable.
I also modified the WAAG grille gaurd that I got from a junkyard '99 Isuzu trooper. Had to cut 7" from the sides and weld it back together. Mod new upper and lower bumper brackets(still working on lower). Added the fogs I got the same day with some old school brackets I had. It's come together so well. I made the top mounts the bolt to bumper from alternator brackets and enginehoist brackets from the exhaust manifold.
Day of test fitting on jy 240
This evening
Old 02-08-2018, 08:47 AM   #35
JohnMc
JohnMc's Avatar
Heh, those are often called 'damage multpliers' in the off-loading community.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-08-2018, 06:00 PM   #36
Can play the blues
I have #1205 in green and tan interior. My left rear quarter was hit on my car as well and not very well repaired. So, it is the daily car. I will repair the rust sometime but not before I fix the turbo.
It is great you are fixing up a classic. Wish you well with it.
Old 02-08-2018, 06:02 PM   #37
JohnMc
JohnMc's Avatar
I have #1141, ruby red wagon with tan interior. Currently 16V turbo with a 5 spd manual, soon to have a turbo LS and 6 spd manual.
Old 02-10-2018, 10:42 PM   #38
FreeEMSFred
FreeEMSFred's Avatar
My 91 GLE has the same wheels, except that the spare one still has the original tyre and is in perfect condition (used, but not abused, maybe used once or twice). They do look pretty sweet in brand new condition or restored :-) Let me see if I can find my photo of it... hmm, only found the back, but it should illustrate the state of the front well enough:
I see this thread has a 1 star rating - Let me balance that out a bit...
Old 02-11-2018, 08:58 PM   #39
Johann245
Volvoholic
Johann245's Avatar
Haters gonna hate. Glad I'm not building my car for them. Thanks for positive thread feedback though.
Ohh jeeze that it is one freaking nice wheel!!
Old 02-11-2018, 11:34 PM   #40
FreeEMSFred
No worries! I noticed after I noticed my own thread had a 1 star rating from 1 vote from 1 person who doesn't like me or doesn't understand that build threads are long term. Then I scrolled down and saw yours and thought, I'll either counter or second that, and checked. :-)
In effect those ratings have no value whatsoever without widespread participation, as outlier(s) completely skew the result to their weird biases. In any case, now it's biased toward centre, so the only effect on future votes is to slow the drift to the correct community driven rating. Fine.
Glad you liked the wheel. If/when I next pull it out of hiding I'll grab a front photo for you and post it here.
Old 02-12-2018, 12:30 AM   #41
Johann245
Volvoholic
Johann245's Avatar
These old unused or barely used parts are like time capsules of what once was Volvo's legacy. lol
Old 02-12-2018, 09:28 AM   #42
spruill242
spruill242's Avatar
The front guard is not my style but you get 4 stars for not hacking it together.
All in all very clean!
'90 Spec Miata.. The barbie car I never got as a kid.....
http://norfolkdustlessblasting.com/ ... Professional stripper...
Originally Posted by HiSPL View Post
I like to masturbate with a cheese grater.
spruill242 is offline   Reply With Quote
Old 02-12-2018, 05:10 PM   #43
Johann245
Volvoholic
Johann245's Avatar
Thanks man, this pic was yesterday at the XXX Drive-In Meet.
If the car didn't have rear quarter rust issues and some rear quarter dents, I would have gone a different route in upkeep.
Old 02-12-2018, 05:12 PM   #44
Johann245
Volvoholic
Johann245's Avatar
Got new cargo panels from John L.
Old 02-17-2018, 10:31 PM   #45
Johann245
Volvoholic
Johann245's Avatar
Replaced my hinges, gaskets and wire harnesses today. Hoping to keep the new black panels from molding. Have a third brake light again and should have defrost again as well.
Old 02-18-2018, 01:03 PM   #46
Vol242vo
Vol242vo's Avatar
I like what you’re doing. Look forward to seeing your progress.
Derek - 1980 242
Old 03-09-2018, 03:11 PM   #47
Johann245
Volvoholic
Johann245's Avatar
Repainted the guard and fogs, also got them wired in with new bulbs. Can't wait for camping season. Bosch amber lenses and guards will be here soon.
New tip and decided to hide the exhaust with black paint since no rear valance.
Current engine picture.
Old 03-26-2018, 12:15 AM   #48
Johann245
Volvoholic
Johann245's Avatar
found some lighted window switches and got them installed. Repainted the lower trim all around with truck bed coating... slow going right now.
Old 03-26-2018, 12:21 AM   #49
Johann245
Volvoholic
Johann245's Avatar
Got the fog guards in a week or so ago too.
Old 03-26-2018, 07:26 AM   #50
Venlonaer
Venlonaer's Avatar
Badass!
Venlonaer is offline   Reply With Quote
