Old 01-22-2018, 09:27 PM   #151
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Also as an awesome side note. I beat the **** out of the car and never once got it over 195 the whole time. Even after doing a pull and coming to a stop. The stock 240 radiator is shockingly good. Only thing I did was a PT cruiser fan running on low speed and a stock 4.8 thermostat with a few extra holes drilled around the edge to aid in air leeding and flow.
Seriously impressed.
60' 1.66
1/8 6.53 @ 113.3mph
1/4 9.99 @ 140.4mph
21psi 14.5deg timing E85
3140lb no driver
3320lb with driver
Old 01-22-2018, 11:26 PM   #152
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So I just walked out to the garage to check the ring gaps. I only checked the top ring gap as a quick test. Every hole was almost dead on .025.
Makes me lean towards timing was way off or bad gas. These are brand new deka 80# injectors. Fuel pressure was great on the pull too. I am going to move the "suspect" injector to number 2 though as a just incase. See if it follows. I dont usually ever hear #2 going. Usually 5 and 7.
Going to go grab some e85 top it up to give me a bit of a safety net and verify timing once its back together. Not sure Im going to gap the rings anymore than they already are.
Old 01-23-2018, 12:09 AM   #153
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
in the winter mine didn't run hot either. it wasn't until the summer that it started creeping. it never overheated, but even with a lower temp t-stat it would hit 200 without any abuse.
Megasquirt Tuning!
Old 01-23-2018, 08:21 AM   #154
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I will absolutely be keeping an eye on it. It wasnt an overly cool day Saturday. I think it was in the mid 60's.
Old 01-28-2018, 09:32 PM   #155
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Picked up a used Hurst QuarterStick fro $60. Really like it so far. It needed a really good clean and regrease. Ooerates very smoothly now.
Also spent most of the day mounting it. I like how it turned out. I may redo it later though.
Old 02-05-2018, 12:03 AM   #156
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Got everything back together and driving. I have a weird vibration at 3k that wasnt there before. Going to check the converter and make sure nothing funny is going on down there.
Also runs 7psi now instead of the 3 or 4 it had before. Not sure what thats about.
Need to get a consistent way to datalog so I can fix this tune. Its way lean even at 7psi. Trying to figure out if its tune or there is an issue.
Old 02-05-2018, 11:42 AM   #157
cosbySweater
cosbySweater's Avatar
What are you running for fuel lines? Are you using stock wiring for the pump or did you upgrade it?
Old 02-07-2018, 01:33 AM   #158
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I bought some Parker 801-6 line and a walbro 450 pump. I ran a 8awg wire dedicated to the pump straight from the battery. Its all on the factory return line.
As a side note I figured out why I popped my engine the first time around and was running super lean this time too. The ****in cheap ass MAP sensor split wide open. So I pried it apart, cleaned out the old sealant, RTV'd the halves together, ziptied it all to hell and then Double Bubbled the part that split open.
In this video you can actually see the ECU only seeing a max of 106kpa while the engine was actually around 140kpa (5psi). The e85 saved my ass bigtime with this recent error and mess up of mine.
The sealant and epoxy has cured and Ill check it out tomorrow to see if I fixed the issue. If the sealed sensor does the trick Im going to buy a genuine GM 3 Bar MAP and swap it out.
Old 02-07-2018, 08:32 PM   #159
Marvelous3
Who engineered this?
Marvelous3's Avatar
holy **** thats super frustrating. wtf sensor?!
Old 02-09-2018, 01:29 PM   #160
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Its extremely frustrating to be honest.
Everything cured and is holding up great so far. Did some more testing and noe I have an uncontrollable boost issue. I currently have the shortest smallest diameter spring from the VSR 44mm in it. Initially I had the longest one in it because it felt the softest.
That spring was allowing me to hit WAY to high of boost. If I keep my foot in it I will scatter the motor on the ground I've datalogged 17psi so far and I let off when I saw the needle swinging right past 15psi.
I did at least get a good video of some burnout action. Ripping on the 6800 rpm limiter and controlling boost with my right foot haha
Old 02-09-2018, 01:32 PM   #161
linuxman51
linuxman51's Avatar
pull the gate, air check with shop air. this is why I only use tial gates on my junk.
Old 02-09-2018, 01:35 PM   #162
linuxman51
linuxman51's Avatar
also, on the amazon map sensors.. they can flake without splitting apart, I have one on the blue 242 that just... got slow... almost like you plugged the line going to it.. it'd pull some vacuum, and show some boost. I'm not sure what to really do about it, doesn't seem to be an extremely common problem but I guess one that shouldn't be all together surprising.
Old 02-11-2018, 01:37 AM   #163
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So I'm pushing coolant under boost now. Enough to where I blew a line off the steam port and emptied the engine of coolant, saw 225 by the time I got home but was probly far over that bc of having very little coolant in the motor.
I'll see if it starts in the morning and get it warmed up then do a compression test. If it starts without issue and tests good I'm going to buy new headgaskets and maybe a used set of ARP studs (not sure on that part yet). The gaskets were reused 4 or 5 times so far and the head bolts probly had 5 full torque cycles on them as well.
Old 02-11-2018, 03:57 AM   #164
cosbySweater
They push coolant if you reuse stock headbolts and gaskets. I even have issues with new hgs and reused bolts. It works if you want, but I think studs and new gaskets are the way to go
Old 02-11-2018, 10:48 AM   #165
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Pulled the gate, gate works fine with air, doesn't stick either. Tested all 3 springs for when they open. Put the lightest spring in there. Still over boosts. I think the exhaust has too little restriction to allow the wastegate to work correctly or the gate placement isnt right on the housing. I cant change the gate location but I can add restriction to the exhaust to see if that makes the wastegate more effective at bleeding exhaust.
EDIT: Just thought I could also add a second gate onto my crossover to bleed more exhaust gas. That will most likely be my final solution.
I will also pull the bolts one by one and clean the threads. Maybe some gunk was causeing the bolts to hit torque before they hit full clamping force. If it still pushes coolant I'll fix it.
Old 02-11-2018, 11:52 PM   #166
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Good news!! I filled it up with water this morning and drove it about 15miles round trip with no issues. Even did a few pulls around 5-7psi without pushing coolant.
Im gonna order a second VSR 44mm gate and weld it on the crossover to control my boost better. Hopefully preventing HG issues in the future.
Once I get the tune straightened out Ill fix the HG issue and install new bolts, new gaskets and try again.
Old 02-11-2018, 11:55 PM   #167
77volvo245
77volvo245's Avatar
Head Bolts and gaskets are cheap
STSmachining
Old 02-12-2018, 01:23 PM   #168
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
They are cheap but I need to get my boost control issue fixed first then Ill work on the gaskets and such. Dont want to do too much at once.
Its very very likely Im going to grab new bolts and new oem gaskets.
Old 02-21-2018, 07:07 AM   #169
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
Little update.
Went and drove it again last week. Hit 16-18psi again. Didnt push coolant this time though. Before I drove it I added some more e85 to the tank and brought my content up to e70 ish. Maybe I was having a bit of detonation and was pushing coolant because of it. Not sure yet on that. Going to mark balancer and check timing.
Boost is still uncontrollable. So I bought and have received my second 44mm gate. Im just going to cut a hole in the crossover and weld it in there. Ill put the lightest spring in both gates so they open together and dont fight each other.
I did remove and retest the old wastegate to make sure it wasnt sticking. Also verified the opening pressures on all three springs you get with the VSR 44mm gate.
On the drive I noticed the boost gauge and ecu reading were a little off again. So today I tested the sensor for leaks and sure as ****, its leaking. Just not from my repair area, its leaking through the connector. I'm sure I could take it apart and grease it up and reseal it but I'm done with this MAP sensor.
Here's another fun issue I'm having. I suspect that I'm overspinning the alternator and causeing a sharp voltage drop(right at 5600rpm which equates to about 18k alt RPM), which is causeing my fuel pressure to tank as well at the same time. My hopeful solution to both the voltage drop and my following FP drop is to install a larger alt pulley to bring alt RPM down to 17.8k when Im on the 6800rpm limiter. Ill go from 14.1 down to 12.5 within 200 engine rpm. Alt has new brushes, new slipring and new voltage regulator from when I rebuilt it. All this is visible in my datalogs, I have a fuel pressure sensor wired in and working. Even if it doesnt cure the fuel pressure drop the alt will still be better off not being overspun like it currently is.
What MAP sensors have you guys used that havent blown apart. Is the LS1 style GM 3bar more robust, or do I just need to switch over to a pressure transducer style sensor?
Has anybody else had high rpm voltage drop issues and what was your solution? Currently factory truck accesories.
Old 02-21-2018, 01:20 PM   #170
cosbySweater
I converted to the ls9 map. It works really well. My 3bar ls1 style map took a **** on me
Old 02-21-2018, 03:22 PM   #171
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
How did your ls1 style **** out on you? Was it a genuine one? They look better suited to boost because there is less space for the pressure to split the sensor apart.
Does the LS9 have the ability to put a hose with a clamp on it so it can hang in the breeze? I dont have a way to mount the sensor on my intake.
Old 02-21-2018, 03:39 PM   #172
cosbySweater
im sure you could smash a hose over the end of it, the oem ones are like 35 bucks, the ls1 style 3 bar from efi source is what I had and it just started reading nothing but atmosphere pressure one day with no change. it has a very small orifice and I think maybe it got contaminated. the ls9 sensor has a o ring on it so and has a boss for a bolt to hold it down. you could just blast a hole in the intake and bolt it down. lol
Old 02-21-2018, 06:58 PM   #173
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I really like the price of the sensor for sure. It seems capable, cheap and an OEM part so the quality should be there for it to last through some abuse.
Old 02-21-2018, 07:17 PM   #174
cosbySweater
Yea it's a nice piece. And works really well
Old 02-24-2018, 09:55 AM   #175
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
So I'm finding between the sensor($30-35) and the pigtail I'll need to wire it in($20-25) I'm gonna be at the same cost as the AEM 3.5bar brass sensor.
I'm far less worried about the AEM style sensor failing with a 100psi burst pressure rating over the unknown LS9 sensor. I think its also the heat coming off my exhaust that is causeing the sensor to fail. I just don't want the glue to separate on the LS9 like it did on my GM 3 bar.
The AEM will be the sensor Im going with because of cost, style and proximity to a heat source.
