Old 09-25-2017, 12:31 PM   #76
Pasis
I think this size is chosen in place. As it was written above, for this purpose it is possible to use measuring plates.
Pasis is offline   Reply With Quote
Old 09-25-2017, 03:24 PM   #77
Lankku
Lankku's Avatar
Originally Posted by poulrais View Post
That's it?!? What was the thickness of these small metal plates?
0.8mm or thinner depending how much the cast has collapsed. A little tight fitment is good, assembly tapping with a hammer.
444 -55, 145 Express -71,
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 "B6284T", 945 Classic, 965 -93 B6304T
Old 09-26-2017, 03:11 PM   #78
poulrais
poulrais's Avatar
Is your BMW 6 speed tranny from a E90 330d car? Are there other BMW models carrying that transmission because these 330d are a pretty rare sauce over here!
1990, Volvo 740 16v +T
Old 09-26-2017, 03:37 PM   #79
Lankku
Lankku's Avatar
E90/91 325, 330, same age 525, 530D and some other diesel models have bigger GS6-53DZ. Smaller engines have GS6-37DZ which can take at least 700Nm. I have this behind my milder 6-cyl. A search with tranny models shows where you can find one. I've bought all but one from Germany or UK through Ebay, here those are more expensive.
Old 09-26-2017, 03:45 PM   #80
poulrais
poulrais's Avatar
There is one in California on EBay for $799 USD
http://www.ebay.com/itm/04-10-BMW-54...JZXvf~&vxp=mtr
Old 09-26-2017, 04:17 PM   #81
Lankku
Lankku's Avatar
V8 gasoline engine tranny(-BZ) has bigger bellhousing than diesel. Diesel bellhousing is better for conversion, diameter fits quite nicely together with whiteblock AW, M90 and 5-cyl M56 bellhousing.
Funny how in Europe diesel is more common and as well more manual transmission cars. Makes building/modifying easier in this case.
Old 09-28-2017, 06:12 AM   #82
Pasis
Lankku
And how much power and torque can withstand m90 for white block?
By the way, I have long met with information that some Finnish guys used a cast-iron 5-cylinder block from a diesel engine, on a gasoline engine, and got a power of about 1100 hp.
Old 09-28-2017, 07:27 AM   #83
Lankku
Lankku's Avatar
In my use M90 took 700Nm for some time and then broke teeth between input and side shafts. Some have used bigger torque without problems. And some have broken earlier.
Yeah, D5/2.4D block is stronger but naturally isn't just a bolt-on. Haven't had the need to study it more. Perhaps JuhaU could tell more what is needed? I recall that he has done it.
Old 10-02-2017, 05:26 AM   #84
Pasis
Yes, I thought it was him. I saw a photo on his page.
Old 02-01-2018, 12:57 PM   #85
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
I've used stock 1.8 Motronic for both under 300hp turbo engines ...
You mentioned E85 later in the thread.
But did you change injectors, ECU tune, or change MAP sensor for the addition of the Turbo on top of the stock 1.8 Motronic?
I like the idea of a straight forward low boost conversion. The idea would be to use a S80 T6 manifold and Turbo (T16?) setup on the 960 motor. Seems like a direct fit, maybe.
Thanks!
#79WDP
Old 02-10-2018, 08:12 PM   #86
Lankku
Lankku's Avatar
Thanks!
T6 injectors and around around 0.5-1bar higher fuel pressure. Otherwise stock. There is no MAP sensor in 960/x90.
When using T6 exhaust manifolds you'll need to fab flanges for the manifold side and runners to the turbo flange.
Old 03-10-2018, 06:25 AM   #87
Pasis
Hi!
We will continue the old topic of discussion of the boost for white block.
I plan to install a turbo on my B6304. Pistons I want to use from B5244T (V70 2000), 83mm, compression ratio 9.
My goal is to increase the torque from 2500 to 4000 rpms. The power is about 270-280hp. Boost is about 7-9ps. I'm considering various options for turbines. For example, the HX35 with an 8cm or 12cm body.
Maybe someone has already tried to install such, share the experience, what you got, maybe someone who has dyno measurements?
Old 03-10-2018, 10:08 AM   #88
poulrais
poulrais's Avatar
Originally Posted by Pasis View Post
Hi!
Stock ECU?
Old 03-10-2018, 11:30 AM   #89
Pasis
Stock ECU?
Probably yes. But it will not be a standard firmware, especially for boost.
Old 03-12-2018, 04:34 PM   #90
ryan242v
ryan242v's Avatar
http://pauter.com/parts/rods/volvo/
Incase you want to spend $1,300. Very nice rods though. From all the research I've done an I- Beam rod seems to be stronger and lighter than H-Beams. To each their own.
2009 Schwinn Leguna 50!! Scooter Puff Jr. 5,500 miles!
1998 S70 T5M, 264k miles, needs something
1987 244 DL, 234k miles (Current Daily Driver)
1979 242 DL, 500k miles, B230FT, M45, 3.31 diff
1973 1800ES awaiting restoration, not togethor
1971 Camaro, my highschool car, rusting away
1969 Suzuki T500 Titan II
ryan242v is offline   Reply With Quote
Old 03-19-2018, 08:45 PM   #91
poulrais
poulrais's Avatar
Originally Posted by TurboDenny View Post
Were you referring to this? Courtesy of Lankku's build thread in his signature.
Lankku how did you fill the gaps between the bores when you installed this block guard? Did you machine the gaps wider then pressed aluminum shims in?
Old 03-20-2018, 11:24 AM   #92
Lankku
Lankku's Avatar
It's a one piece design. Original casting was completely removed around the top of the cylinders.
Old 03-20-2018, 03:01 PM   #93
poulrais
poulrais's Avatar
Ok thanks for the info!
Old 03-20-2018, 03:12 PM   #94
Lankku
Lankku's Avatar
Started to think if it's really the way I said and had a look at the pictures again. It's not.
Only the cast between the cylinders is machined off and otherwise there is some original casting left around the cylinders. In the picture linked eariler you can quite clearly see the lines.
This is how the guard looks after being cut:
http://postimg.org/image/jstmt8dwb/
Old 03-20-2018, 04:14 PM   #95
poulrais
poulrais's Avatar
Ok pretty good picture there! Thanks!
Old 03-22-2018, 09:43 AM   #96
Pasis
Hello!
I now choose which turbo pistons to order for my B6304.
I found two types.
https://catalog.mahle-aftermarket.co...967237#divider
The first has pockets for valves and thicker rings. It was installed on B5254 to 98 year.
https://catalog.mahle-aftermarket.co...967206#divider
The second type does not have pockets for valves and has thinner rings. Oil-removable ring type dial.
The remaining geometric dimensions are the same for them. The second type only has a finger length of 66mm, instead of 61mm.
What do you think I should use? I will have a standard 6304 head and 204hp. camshafts.
Old 06-27-2018, 06:59 PM   #97
poulrais
poulrais's Avatar
I could snatch a B6294t engine from a 2004 XC90 T6 for cheap. Are these engine any good for a build? I'd have the deck closed with a block guard. They got the twin VVT I guess?
Old 07-20-2018, 06:54 AM   #98
TurboDenny
Why am I here?
I'm wondering the same thing since there is an option for closing the deck. Do we really need to source B6284 blocks for their strength over the B6304? The B6304 head is superior, so it would be nice to only buy one new engine.
Instagram: @itstotesdenny
