Old 02-10-2018, 12:56 AM   #201
These Pipes Are Clean!!
Originally Posted by Canuckvolvo View Post
Not sure how you're getting brown tops to work. 2.2 has very little room for adjustment- I couldn't even get 940 turbo injectors to run properly(tried stock AND chipped ecu), and they are only 10% bigger than stock. Brown tops are about 30% larger iirc.
I made 209whp and 230ft/lbs tqs on brown tops/lh2.2 on a B21F+T. You have to turn the adjuster screw a lot to lean it out enough but it can be done.
Old 02-12-2018, 01:20 PM   #202
maxitoman007
Update: during may timing belt job, I think I found the issue... turbo was blown. I took of the intake pipe and wiggled the thing and instantly I knew. Blades of the compressor and turbine had hit the walls and begun bending on the ends. Due to the very obvious wheel and core damage to the turbo, I decided to swap on a new eBay turbo vs rebuilding. Found a “57 trim” (calculated to be more like a 47 trim) on my local classifieds site and ended up picking it up for $50 Cad. As you know the eBay turbos have an odd exhaust flange so I managed to swap the hot side to that of my old turbo (with an exhaust flange I could use). It took a little bit of dremel work to make it clear but it eventually worked without any binding (even while pushing to the sides and turning). I mounted it up yesterday and things already seem MUCH better. I can now build 5psi + in neutral where as I was barely able to break 0 with the old turbo. Haven’t had the chance to drive it yet but I’m excited.
maxitoman007 is offline   Reply With Quote
Old 02-13-2018, 10:51 PM   #203
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
They have an odd flange? Wat?
'91 744t...it's fast as phuck
Old 02-13-2018, 11:30 PM   #204
maxitoman007
Just not the 2.5” round 4 bolt flange I needed.
