Old 02-02-2018, 11:18 PM   #1
Vol242vo
Vol242vo's Avatar
Default 5x114.3 to 5x108 Wheel Fitment
I know this question has been beaten to death, I don’t have a clear understanding of offsets and adapters or spacers for proper fitment. I’m looking for some nice looking wheels for my 242 and came across these on eBay. However I’m not sure what adapters I’d need to run them, obviously 5x108 to 5x114.3 but thickness is my area unknown. The offset appears to be +20, also, I’ve read I’d want to run hub centric adapters vs. non hub centric...
https://m.ebay.com/itm/MST-MT-16-16x...pid=2213054925
Derek - 1980 242
Old 02-03-2018, 12:01 AM   #2
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
You are gonna need at least 25 mm to adapt the bolt pattern, and et25 is the factory wheel so et40+ wheels with adapters will be close to stock. Basically fwd wheels.
The non/centric argument is going to get you 12 answers from 9 members at least so when all is said and done, listen to the trees. Redwoods are generally old and wise...
Old 02-03-2018, 01:14 AM   #3
Fill and drill.
Old 02-03-2018, 01:22 AM   #4
Jack
Banned
Jack's Avatar
Came to see cabinets... disappointed
Old 02-03-2018, 01:25 AM   #5
Miata's take 4x100 anyway...
Old 02-03-2018, 08:34 AM   #6
Mojo Stealer
I have non hub centric adapters, it takes about 30 seconds longer to mount them, just have to make sure they go on straight. I use 2) of the lug nuts, skip one hole and tighten those evenly, it brings the wheel center on the other studs, then zap all 5 down with an impact. Hub centric is easier but the lugs and studs are what locate these as well once everything is tightened down.
Old 02-04-2018, 01:06 PM   #7
LloydDobler
LloydDobler's Avatar
If you put a spacer on those they'll be outside your fenders. Find a shop that can re-drill. Or keep shopping.
'66 122 - Collectible project
Old 02-04-2018, 03:52 PM   #8
Tuff240
240 Ninja
Tuff240's Avatar
They would fit at your ride height with a bit of work.
Custom 20mm adapters
Short lug nuts and trimmed down studs (if the wheels don't have good pockets on the hub mounting surface)
205-215 tires
Rolled fender lips
Front won't be too bad, it's the rear where you will struggle.
I like the 17" versions better.
-Patrick
Old 02-05-2018, 02:14 PM   #9
https://www.kaplhenke.com/collection...led-front-hubs
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-05-2018, 03:09 PM   #10
Tuff240
240 Ninja
Tuff240's Avatar
That's cheap, I wish you did axles also.
Old 02-05-2018, 03:15 PM   #11
Axles would be less cheap, between welding and machining etc....
I want to start stocking 5x114.3 axles though.
Old 02-05-2018, 03:37 PM   #12
culberro
culberro's Avatar
$200/set last time I checked.
https://www.dutchmanaxles.com
Old 02-05-2018, 03:59 PM   #13
exactly
Old 02-10-2018, 10:46 PM   #14
Vol242vo
Vol242vo's Avatar
Awesome Ben, that may be exactly what I do. Thank you.
