Old 02-03-2018, 03:03 PM   #1
thegoldbrick
thegoldbrick's Avatar
Default Timing belt slip
Hey guys
What are the chances if I didnít hear anything the valves are fine in my car, as I have a proformance cam.
Car(s)
90 760 Turbo (HG DONE)
Roasted Head: http://imgur.com/a/x4uk8
91 940SE
Cut your springs in half, sell the other half, and profit again.
thegoldbrick is offline   Reply With Quote
Old 02-03-2018, 03:10 PM   #2
2manyturbos
Why speculate? Just put another timing belt on and run a compression test, or, just try to start it.
Old 02-03-2018, 03:51 PM   #3
thegoldbrick
I’m about to head over and put the belt on again. It’s a brand new belt and it should stay on this time. I just hope it’s not completely crapped nkw
Old 02-03-2018, 07:44 PM   #4
thegoldbrick
Will it start with bent valves?
Old 02-03-2018, 08:55 PM   #5
2manyturbos
Probably not.
Old 02-03-2018, 09:42 PM   #6
RP80242GT+T
R-Sport Cluster Guy
RP80242GT+T's Avatar
4 cylinder engines are non interference motors.
RP R-Sport and OEM Stock Instrument Cluster Restorations, Sales, parts, service, and customizing. LED Conversion Services
Volvo GT Stripe Kits.
1980 242 GT Turbo
2006 Mini Cooper S GP number 1148
1989 240 Wagon " The Beast" Daily Driver
RP80242GT+T is offline   Reply With Quote
Old 02-03-2018, 09:57 PM   #7
Mbeas96
Mbeas96's Avatar
My brother had a problem where his belt would slide forward into the cover and cause a burning plastic smell, I'm pretty sure he just swapped the tensioner pulley with a new one from fcp Euro and it was good to go. And yes, 940 with the b230 are non interference so no harm done
Old 02-03-2018, 10:01 PM   #8
oldschoolvolvo
oldschoolvolvo's Avatar
Originally Posted by thegoldbrick View Post
Hey guys
What cam do you have?
-Mike
1998 V70 T5
|Feedback|
Old 02-03-2018, 10:09 PM   #9
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Careful with this statement...
8-valve 4 cylinder engines with factory cams are non interference. Some serious performance cams have enough lift for the valves to contact piston.
Volvo 16 valve 4 cylinders are absolutely interference.
Old 02-04-2018, 12:09 AM   #10
RP80242GT+T
R-Sport Cluster Guy
Obviously the 16 valve is. I was referring to what he had in his signature
Old 02-04-2018, 01:07 AM   #11
NotSoFresh
NotSoFresh's Avatar
I know you know, and I know what you meant, however it wasn't what you said, I just clarified for future readers.
Not meanin to step on toes
Old 02-04-2018, 02:41 AM   #12
thegoldbrick
This is one from yoshifab, roughly a stage 3 and makes it interference
Old 02-04-2018, 03:51 AM   #13
tryingbe
Boosting along.
tryingbe's Avatar
Then you have bent valves.
85 GLH 367whp
00 Insight mpg > yours.
Old 02-04-2018, 05:47 AM   #14
Sjeng
Not necessarily. Then a valve would have to be stuck open at near full lift. Who says this was the case?
OP what do you mean with "slip"? Can you clarify what exactly happened?
Old 02-04-2018, 12:35 PM   #15
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
A lot of times it’s rpm dependent. I’ve see people snap belts on interference engines when the go to start it and they put a new one on and it was fine.
OP let us know
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 02-04-2018, 12:40 PM   #16
thegoldbrick
It fell off while it was running. Don’t know the cause because it was running fine before, and now that I have it retimed and rebelted it won’t start. Fml
Old 02-04-2018, 12:43 PM   #17
PromiseRing
It fell off while it was running. Donít know the cause because it was running fine before, and now that I have it retimed and rebelted it wonít start. Fml
For sure timed correctly? Do a compression check.
Old 02-04-2018, 01:46 PM   #18
thegoldbrick
Yes both marks are lined up. Compression test today or tomorrow
Old 02-04-2018, 02:04 PM   #19
2manyturbos
What caused a new belt to "slip"? That would be my first concern. You don't want history repeating itself.
Old 02-04-2018, 02:22 PM   #20
thegoldbrick
Yeah it was off the aux shaft. And there was oil everywhere cause the breather box hose broke so that’s my guess is oil
Old 02-04-2018, 05:30 PM   #21
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Old 02-04-2018, 08:31 PM   #22
thegoldbrick
Originally Posted by Wilford Brimley View Post
I put in a cam that made it an interference engine.
Old 02-04-2018, 08:37 PM   #23
Wilford Brimley
LOCAL ONLY
I got that, the blanket statement he made is retarded...mine is interference too.
Old 02-04-2018, 09:01 PM   #24
PromiseRing
I think he meant US market 8 valve single over head cam Volvo motors with factory cams are all non interference...
Old 02-04-2018, 09:36 PM   #25
NotSoFresh
NotSoFresh's Avatar
He has a 91 940SE in his sig. The non turbo version of this car was 16v.........
