Old 02-05-2018, 01:59 PM   #1
mikep
The MP
mikep's Avatar
Default Intake Manifold Plenum Design: Stubs or holes?
Inside a home-built plenum:
Stubs of tube, insides contoured (outer edges sharp)?
Stubs rounded inside and out?
No stubs, just holes into individual runners?
The stubs would be the sawed-off remnants of a 280ZX Nissan manifold.
I wonder if stubs, allowing air to flow past on the outside, will flow smoother the a wall with holes.
Everything about ancient rome was beautiful, so no 740s would exist.
Old 02-05-2018, 02:14 PM   #2
Tfrasca
Tfrasca's Avatar
Can you not get some stacks or bellmouths on those stubs?
Old 02-05-2018, 02:19 PM   #3
cwdodson88
Depending on the amount of material you have to work with, you could weld the tubes to a plate and take a router to round over the holes/welds making a velocity stack of sorts.
The Build Thread
SVEA - PUSHROD TURBO!
Old 02-05-2018, 02:41 PM   #4
sbabbs
sbabbs's Avatar
There is a Z fuel injected manifold without all that EGR stuff. Not sure what year, but I've seen it. I gotta buddie who has 30 plus Z's he's parting out.
Old 02-05-2018, 03:49 PM   #5
crogthomas
crogthomas's Avatar
There is only one way to do it. Radius the inlet, from a flat plate is easy to do.
Sharp edges cause turbulence and restrict airflow.
I refer you to D Vizard
A good example scrounged from the net:
crogthomas is offline   Reply With Quote
Old 02-05-2018, 04:04 PM   #6
mikep
The MP
mikep's Avatar
That would be the holes version I was describing.
The velocity stacks version would be the other (stubs) version with sharp outer edges.
Velocity stacks is what I would think flows the most, but does it?
I remember head bench testing where a half-round at the entrance flowed better. But I have no copy of the article.
I have limited space now, but will have more when I get rid of the struts in 2 years with a different suspension.
End-goal if possible is a plenum to receive an M90 supercharger from a T-Bird.
Old 02-05-2018, 04:06 PM   #7
mikep
The MP
mikep's Avatar
book excerpt on clay radius on a port
https://books.google.com/books?id=z7...inlets&f=false
Old 02-05-2018, 04:13 PM   #8
mikep
The MP
mikep's Avatar
According to this, it's only a 1% difference.
https://www.performancebyie.com/blog...ght-bellmouth/
It's from a group selling something, and they only did a computer simulation.
Old 02-05-2018, 05:47 PM   #9
Happy Mew Year!!!
Doesn't GM have an 8 hole manifold that fits on one of their l s motors?
Old 02-05-2018, 11:53 PM   #10
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Stubs or holes? Male/female? Why would it matter what gender a manifold is?
That joke aside, velocity stacks and radii help with an n/a engine, this is undoubtedly proven. Especially if you tune the intake to take advantage of the inversion wave. However, there is a lot of debate out there about whether there is benefit in a boosted engine. I am under the impression that the radius will help increase velocity and flow by smoothing the transition, but velocity stack length on a boosted engine wont make much difference. Well, 20 foot long intake runners(Bosuzoku ftw.) will effect throttle response but not flow.
Old 02-06-2018, 09:40 AM   #11
shoestring
shoestring's Avatar
Any reference to David Vizard concludes the conversation.
Old 02-06-2018, 01:42 PM   #12
mikep
The MP
mikep's Avatar
I tend to agree, but I need to find out if there is a more than 1% difference.
Personally, if I cut off at the green lines and weld the plate there, I will have clearance probs. If I try to turn those into stacks, the curves will make it hard to get a plate slide over far.
And if I shorten the cutoff lengths, I will have to run studs and nuts (I'm ok with that)
If I start from scratch, who knows.
I'm not interested in using any nissan intake. And I'm only going to inject it if I go with the supercharger or a turbo.
The SUs are going on there for now.
Old 02-06-2018, 01:42 PM   #13
mikep
The MP
mikep's Avatar
Thanks for the comments.
Old 02-10-2018, 08:25 PM   #14
freevolvos
freevolvos's Avatar
you would need a Dyno to find out look at the millions of different manifold designs, i would think the ram tuning would depend on what r.p.m. you would be running
Old 02-13-2018, 09:35 PM   #15
mikep
The MP
mikep's Avatar
Nope. Building this once.
