Old 02-06-2018, 04:35 AM   #1
fork
Default Boosting a redblock with stock ECU's
I have read a few threads that I can't seem to find anymore, where there were people that had boosted redblocks with no change to the ECU, injectors, etc.. All they did was swap the manifold, installed an intercooler, and extended the wires for the MAF. They ran about 5-6 PSI safely without blowing it up.
I am in the process of doing the same thing in my 1984 245. I have sourced out the manifold, turbo, downpipe, intercooler. Currently looking for an oil pan with pre-drilled oil holes.
Anyways, all said and done.. Should I be safe running my LH 2.1 with 5 PSI of boost? I'm going to do it anyways but I'm just looking for some input- maybe those threads that I read..
Thank you
fork is offline   Reply With Quote
Old 02-06-2018, 08:52 AM   #2
Dadssleeper
Dadssleeper's Avatar
Yes you can do it, but why would you want to skip the easiest step? I can go to the salvage yard and pull some turbo ecu's from a 2.1 in a few minutes.
Old 02-06-2018, 09:34 AM   #3
Trevor57
Trevor57's Avatar
I have to agree. I am doing my second JY turbo setup, and don't think the ecu step is really worth skipping. Between TB, junkyard, and ebay. You should be able to get ecus for $50-$100.
14 Mazda 5 6spd / 86 245 24hol racer / 92 245 / 86 245 lsx ( http://forums.turbobricks.com/showthread.php?t=321150 )
If you start threads, and do not reply to those threads with a resolution, you are a human analog of photobucket.
Trevor57 is offline   Reply With Quote
Old 02-06-2018, 09:49 AM   #4
Broke4speed
Broke4speed's Avatar
So you want a turbo car without any of the safety that a turbo ecu offers. If you don't have a budget for the correct parts now, will you have the budget for a replacement engine later?
Don't rush it. Collect the proper parts and THEN boost it.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 02-06-2018, 09:54 AM   #5
oldschoolvolvo
oldschoolvolvo's Avatar
OP is saying he has LH2.1...IIRC there is not a turbo version of this generation of LH Jetronic, so not simply an ECU swap as is the case with LH2.2/2.4.
https://www.ipdusa.com/techtips/1008...n-my-volvo-240
OP...I'd dig into the wiring diagrams and see what the differences are between LH2.1 and 2.2 and see if you could change your wiring to match LH2.2 and then grab and ECU from an early 740T.
IMO boosting w/ the n/a ECU is playing with fire and asking for problems.
-Mike
1998 V70 T5
|Feedback|
Old 02-06-2018, 10:22 AM   #6
white855T
Op can easily convert over to 2.2 for the time being(using a 2.2 turbo ecu) and turbo car which will cover fuel. Later on he can do ezk ignition or breakerless. Not that big of a deal. But yeah you don't want to use the na ecu for too long. It's fine to do in stages.
Buyer/Seller Feedback
Old 02-06-2018, 02:35 PM   #7
fork
Unfortunately there is only one turbo Volvo in all the junkyards where I live. It's running LH2.4 and I believe it still has ECU''s. My plan is to just do a simple turbo swap for the time being and eventually find a 1994+ redblock paired to an AW71 with low mileage. Then I'd do a full proper swap rewiring the whole car, as there are a couple things that don't work. I do have another daily as well incase things go south.
I will read into some wiring diagrams and see what needs to be done to swap ECU, but most likely I'm going to run my 2.1 for science. If I hear anything funny while driving I'll have to avoid flooring it I guess.
Old 02-06-2018, 02:44 PM   #8
pat244ti
pat244ti's Avatar
https://forums.tbforums.com/forumdisplay.php?f=14
You do realize you can just make a wanted post for ECU's/injectors on here and have mr UPS bring em right to your door....
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
Old 02-08-2018, 04:12 PM   #9
11110000
11110000's Avatar
The Bosch 507 ECU from a B23FT is a drop-in for the 83-84 B23F. There is a pin on the ECU that connects to the EZ-115K ignition (which the B23F doesn't have) but you can ignore it.
Sounds like some of you need handling by Rancho. - stevemd
11110000 is offline   Reply With Quote
Old 02-09-2018, 12:21 AM   #10
Jack
Banned
Jack's Avatar
Yeah lh 2.1 to be 2.2 is easy
