Old 02-07-2018, 08:35 PM   #1
vwbusman66
sold his dream car
vwbusman66's Avatar
Default WTF turbo did I pull and is it good (enough)?
Went to the junkyard today to pull an intermediate shaft and distributor for a block mount distributor conversion and the car had already been crushed
I decided to see what kind of turbo I could find and stumbled into a 1998 s70 with the engine already dropped to the ground. After a little bit of a struggle, I pulled the turbo and 4 red body fuel injectors. From what I can gather, red bodies came on light pressure cars, meaning this car was a GLT.
What turbo was stock on a 1998 s70 GLT? The tag on the one I pulled is worn away and just says "Volvo", the serial number, and "made in Japan". It's definitely a Mitsubishi turbo.
Is it a 13T?
How does said turbo compare to a 15g? From what I gather, the 13t has a bigger hot side than the 15g and will produce more power overall. True or false?
Old 02-07-2018, 08:35 PM   #2
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
13t
Old 02-07-2018, 08:38 PM   #3
Jack
Banned
Jack's Avatar
yeah low pressure turbo high compression engine
YOU GOT FUKED
Old 02-07-2018, 08:48 PM   #4
13T is fine, its a lot better than a 13c. hot side is bigger and the housing is better.
Really depends what you are looking for if it will be good or not.
If you dont want to run a ton of boost and have something thats responsive... it should be great.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-07-2018, 08:49 PM   #5
Jack
Banned
Jack's Avatar
but 90% sure there was a 15G in the 850 next to it
Old 02-07-2018, 08:56 PM   #6
vwbusman66
sold his dream car
vwbusman66's Avatar
No 850's in the yard- I checked with the inventory lady and looked myself.
Old 02-07-2018, 08:58 PM   #7
vwbusman66
sold his dream car
vwbusman66's Avatar
I'm shooting for 15psi when all is said and done.
Can I throw a 19t cold side on it for higher CFM?
Old 02-07-2018, 08:58 PM   #8
Jack
Banned
Jack's Avatar
lol thats why only 90% but 98 70 is basically the same thing
look for a 16t or 15g
Old 02-07-2018, 09:00 PM   #9
vwbusman66
sold his dream car
vwbusman66's Avatar
I check pretty much every day for new Volvos (anything that comes into any yard within 50 miles of me).
For now, I'll use the 13t, run out of enjoyment, find a 15g/16t and sell the 13t for a profit.
Old 02-07-2018, 09:37 PM   #10
ElHefe910
ElHefe910's Avatar
How hard is it to get a Saab turbo to work? They are at the junkyards a lot and I think the majority of them are 14t and 15t turbos.
ElHefe910 is offline   Reply With Quote
Old 02-07-2018, 09:51 PM   #11
oldschoolvolvo
oldschoolvolvo's Avatar
I don't know the specifics, but they will likely bolt to the manifold since they are Mitsubishi TD04xx turbos.
You'll have to sort out the reclocking and oil/water lines, but that isn't a show-stopper.
FYI from a brief Google..the 14T turbos are from the TD04L family and the 15T turbos are from the TD04HL family (HL > L). So the 15T center cartridges, etc are interchangeable with the familiar 15G, 16T, 18T, etc turbos.
https://turbocentras.com/turbo-maker/Mitsubishi
-Mike
1998 V70 T5
|Feedback|
Old 02-08-2018, 11:46 AM   #12
Yes, you just need the wheel and compressor housing and get it balanced.
Old 02-22-2018, 12:59 PM   #13
vwbusman66
sold his dream car
vwbusman66's Avatar
Just to clarify, the link below is the correct wheel and cold side for my 13t right? I think the 13t is a TD04L so I think this is right.
https://www.ebay.com/itm/TD04L-13T-t...RSwlDM&vxp=mtr
Old 02-24-2018, 02:22 AM   #14
cwdodson88
I've got a 15g if you want bigger, but you'll need to find a HL hot side, or mill your manifold flat. HL frame cartridges let you run the less restrictive flat or angled flange hot side, so punches everything up a notch, even at 10 psi.
The Build Thread
SVEA - PUSHROD TURBO!
