Old 02-08-2018, 02:19 AM   #1
Sweep
Default 302 brakes on 940, Girling or ATE?
As above, I read through the 302 guide and he mentioned using ATE calipers. Any reason why my Girling calipers can't be used?
Old 02-08-2018, 03:34 AM   #2
crogthomas
crogthomas's Avatar
What calipers?
You need the calipers from the 850/V70 that fit on the extended caliper brackets to match the 302 disks. You cannot use 940 parts.
crogthomas is offline   Reply With Quote
Old 02-08-2018, 07:42 AM   #3
DET17
Reformed SAABaholic
Yes.... I've converted my 940 "Saloon" to the same 302mm setup with Scandix special abutments. From what I recall in the referenced article, the caliper is from an 850 / other later models from Ovlov. The single piston diameter is exactly the same as that used in the 9 series, so no benefit from increased piston clamping.... just the leverage gain by virtue of the additional radius of rotor.
Several who made this upgrade have noted the improvement realized.....
Old 02-08-2018, 09:18 AM   #4
Sweep
Perfect, that makes more sense. I was under the impression we were using our 940 calipers with the bigger carriers. Cheers guys.
Old 02-08-2018, 11:16 AM   #5
Benjam83
Moar Volvos than Queen B
Here's some more info....
https://forums.tbforums.com/showthre...=175584&page=2
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 02-08-2018, 11:43 AM   #6
eabras
I ordered the 302mm brackets from skandix (or go to a junkyard and find a 850 with 302mm brakes), got some stock 850 calipers and a longer hoses (from 850's/v70's with 302mm disks). I'm actually using 305mm disks from 2002-up v70. If you have dual lines up front you need to block two of them (one on each circuit).
Then you need longer bolts, and 6-6,3mm spacers between the strut and caliper brackets. Geminis fit, but i had to grind a tiny bit on the calipers to fit 17" eiker e1's.
eabras is offline   Reply With Quote
Old 02-08-2018, 01:39 PM   #7
DET17
Reformed SAABaholic
The reviews of the referenced older thread confirm what I have been told. Not quite a Wilwood 4 pot binder, but also not $700 plus ! looking forward to having real brakes in my 940.
Old 02-08-2018, 04:10 PM   #8
Sweep
Thanks guys, much appreciated.
Re the longer hoses, myself and others have run this setup on 850's with the stock 280mm hoses without problem, do the 940s really need them?
I'm on Canopus wheels which I had on the 850 with 302s so should be fine.
Old 02-09-2018, 04:11 AM   #9
Sweep
By the way, do we have any favourite pads to use on the 302's?
Old 02-09-2018, 05:32 AM   #10
JerryJS8
der Junge
JerryJS8's Avatar
When you upgrade to 302 Brakes on your 940 check to see if you have 38mm or 40mm calipers in the rear. Going from 38mm to 40mm calipers is also a nice upgrade to do at the same time.
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) Turbo 16v (restauration project)
Originally Posted by gashog View Post
Unique for sure.
I don't think anyone is going to tell you it looks bad.
Kinda can't go wrong under the hood.
Old 02-09-2018, 07:45 AM   #11
DET17
Reformed SAABaholic
Jerry, do you know the years of the larger piston rears? I understood that the North American cars were all the same 91-95.
Old 02-09-2018, 05:18 PM   #12
Benjam83
The pad selection should be a bit better than with the older cars. But of course it's personal preference....
I've used EBC YellowStuff pads in the past and really like them. They tolerate heat really well, only dust a bit worse than stock, while also not needing heat to work like a lot of other "track" pads.
I just realized that I'm not sure if they make the YellowStuffs for the 302s though.....
