Old 02-10-2018, 04:57 PM   #1
Steerfromdarear
Default T3 turbo on bf230
I'm fitting a T3 turbo to a bf230 what psi do a run it at for around 300hp and what size wastegate do I use
Steerfromdarear is offline   Reply With Quote
Old 02-10-2018, 05:07 PM   #2
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
BOHICA.
But I'll throw you a bone before we get another 10 page thread about why a 60-1 won't spool on an untouched 8v B230.
What Turbo are you running? What manifold, custom or a 90+? If custom, single entry or twinscroll?
It doesn't take much to get there but you need to leave the gate with all the right stuff.
Old 02-12-2018, 10:33 AM   #3
towerymt
the real Towery
towerymt's Avatar
Ask a better question (or questions) and give more detail.
Old 02-12-2018, 10:21 PM   #4
Trevor57
Trevor57's Avatar
If you are using a turbo with an internal wastgate, it will be sized appropriately. If you are using an external wastegate, it would depend on it's location, and your turbo/manifold setup. Also if you get the wrong size external gate, it should be an easy swap to a different gate with the same flange. Maybe you could search some other builds to see what people are running to achieve desired goals.
14 Mazda 5 6spd / 86 245 24hol racer / 92 245 / 86 245 lsx ( http://forums.turbobricks.com/showthread.php?t=321150 )
If you start threads, and do not reply to those threads with a resolution, you are a human analog of photobucket.
Trevor57 is offline   Reply With Quote
