Old 02-13-2018, 09:47 AM   #1
SolderedCam
Default B230ft swap lh2.4 wiring questions
I've been looking up info on swapping an na Lh2.4 740 to an lh2.4 b230ft that I'm getting from an 940. I've looked up info regarding the swap but most if not all only have info on the swap for early model 240's. I can't find anything related to the swap for later cars except I know that I'll need to extend the wiring for the AMM. Can anyone chime in and give a little more info on what's needs to be done? Like swapping the body harness or swapping the engine harness/splicing into it? Or do I just need to swap the Computers and extend the AMM to get it running. Any help/info is greatly appreciated!
SolderedCam is offline   Reply With Quote
Old 02-13-2018, 10:05 AM   #2
petiww
petiww's Avatar
This is an NA 940 LH2.4 wiring i converted to a 240 turbo. The AMM wire iirc was the one with the winding in it.
With some hose cutting, depinning a few connectors, I'm fairly sure you can manage to put the AMM any place you want in the bay.
Other important thing is to remove/depin/cut the WOT wire, from the throttle switch connector or at the LH connector, pin nr 3.
http://ipdown.net/jetronic.info/tiki...Id=465&display
1980 Brown 244 GL
Old 02-13-2018, 10:23 AM   #3
white855T
Get the turbo ecu & ezk. Extend amm wiring. Everything else is pretty straight forward.
Buyer/Seller Feedback
Old 02-13-2018, 12:43 PM   #4
J_Jones
J_Jones's Avatar
Why?
Old 02-13-2018, 02:06 PM   #5
petiww
petiww's Avatar
Originally Posted by J_Jones View Post
Why?
Turbos do not use it as far as i know. Maybe the turbo ecus doesnt even check that pin though, but its easy to depin that single wire.
Old 02-13-2018, 02:25 PM   #6
J_Jones
J_Jones's Avatar
Interesting, thank you for the information. I will have to look more into this. Will report back with what I am able to find.
Old 02-13-2018, 03:39 PM   #7
sbabbs
sbabbs's Avatar
Don't forget you have to add the resistor pack if your using stock turbo injectors.
Old 02-13-2018, 03:39 PM   #8
culberro
culberro's Avatar
Just follow this guide....
http://forums.turbobricks.com/showthread.php?t=230687
Old 02-13-2018, 04:54 PM   #9
SolderedCam
Yeah I picked up some Red S70 Injectors to eliminate the need to run a resistor pack
Old 02-13-2018, 04:56 PM   #10
SolderedCam
Thanks for the Heads up I'll be sure to do so!
Old 02-13-2018, 10:32 PM   #11
SolderedCam
Originally Posted by culberro View Post
Thanks I'll be sure to review it
Old 02-15-2018, 01:44 PM   #12
sbabbs
sbabbs's Avatar
What I'd try and do is leave the motor harness on the turbo 940 motor that you are putting in the na 740 and plug it into that plug on the firewall. That would be easiest.
That link is for using a NA 240 harness. I did that in my 89 lh2.2 740 turbo car, but since your 740 is already lh2.4 you don't have to take harnesses all apart or use a 240 na 2.4 harness or any of that bs. Should be fairly easy for you to do it.
Old 02-16-2018, 04:12 PM   #13
Spelling "you"re" incorrectly makes you seem uneducated.
Higher flow fuel pump/s?
Larger sway/s.
Larger tires/wheels.
Old 02-16-2018, 04:31 PM   #14
sbabbs
sbabbs's Avatar
wut?
Here's the problem that guide thread by dat wanna be isn't what he needs for wut he's doing, but okay yeah you all is smarty morer dan me so do wut you want, I don't car no more.
Old 02-16-2018, 10:57 PM   #15
To old for this
wut?
Bravo!
To old for this is offline   Reply With Quote
Old 02-17-2018, 01:05 AM   #16
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
Nah no need to do that.
OP, install turbo ecu and ezk and turbo parts, extend AMM wiring and do a durnout.
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
PromiseRing is online now   Reply With Quote
Old 02-17-2018, 08:16 PM   #17
Washer bottle relocate so turbo airbox fits.
Old 02-28-2018, 12:26 AM   #18
Tbrick707
On my 89 240 with lh 2.4 I swapped both ecus for the turbo ones before I did turbo install just to have it run and eliminate problems ..And it runs like **** tried 56x 9xx ecus and removed the white and blue wire from the tps ... idk what to do now since everyone says it just swap ecus and it'll be fine
Tbrick707 is offline   Reply With Quote
Old 02-28-2018, 12:31 AM   #19
^^^You did something wrong.
Old 02-28-2018, 01:02 AM   #20
Tbrick707
Did literally nothing but swap ecus..... I plug the stock n/a ecus back in just fine ..
Old 02-28-2018, 06:37 AM   #21
J_Jones
J_Jones's Avatar
You didn't change injectors when you moved to the turbo ecus did you?
Old 02-28-2018, 02:00 PM   #22
Tbrick707
Nope not yet
Old 02-28-2018, 03:20 PM   #23
sbabbs
sbabbs's Avatar
Yeah turbo ECU wants turbo injector flow rate sized injectors.
Old 02-28-2018, 03:20 PM   #24
You "should" be able to run a turbo computer with the high rez non turbo injectors, but it may run like **** until it learns. If you run a bon turbo computer on low rez greentop injectors and do NOT run the rez pack.....you will get the computer.
Old 02-28-2018, 05:54 PM   #25
Tbrick707
Maybe I'm not letting it sit long enough to let it learn .. once I get the turbo finished up I'll let it sit idling for a while ... but I keep hearing ppl run turbo ecu's for a while on there n/a with no problems before they swap
