Old 01-25-2017, 12:07 PM   #751
Pro Sneaker Peddler
Originally Posted by mblue240 View Post
He got married and bought a house, he's too busy adulting.
I did those things, plus had 2 kids, and swapped in a T-5 into mine last week. There is no excuse.
Old 01-26-2017, 01:32 AM   #752
mblue240
mblue240's Avatar
When you turn 30 you slow down. Just wait and see.
-Michael
Tbricks build
Yep, Michael is right.
Old 02-12-2018, 09:08 PM   #753
klr142
Turbo, what?
klr142's Avatar
Turbobricks? What is this Turbobricks?
I'll just leave these here for you guys to ponder.
http://forums.turbobricks.com/showthread.php?t=66779
http://forums.turbobricks.com/showth...hlight=flyfaen
http://forums.turbobricks.com/showthread.php?t=310630
http://forums.turbobricks.com/showth...en#post5080589
Old 02-12-2018, 09:17 PM   #754
Old 02-12-2018, 09:25 PM   #755
klr142
Turbo, what?
klr142's Avatar
Hi Ken!!
Old 02-12-2018, 09:31 PM   #756
Couple of us still driving these old buckets.
Old 02-12-2018, 09:40 PM   #757
Jack
Banned
Jack's Avatar
Adults don’t use “adulting”
Old 02-13-2018, 01:46 PM   #758
klr142
Turbo, what?
klr142's Avatar
Just in case no one clicked a link, here's a more direct statement:
http://forums.turbobricks.com/showpo...0&postcount=26
Old 02-13-2018, 01:57 PM   #759
122power
dude
122power's Avatar
Dude its cracked, lol
Old 02-13-2018, 04:39 PM   #760
doucheNozzle
doucheNozzle's Avatar
Re: timing
Sorry, my question came off like the rest of my comments: dickish. From reading Njal's post, it sounded like the big advantage was to be able to add extra timing and to run leaner. Was curious what you were going to do.
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 02-13-2018, 05:10 PM   #761
klr142
Turbo, what?
klr142's Avatar
Thumbs up
Originally Posted by doucheNozzle View Post
Re: timing
WHY GROOVE?!
I want to increase the detonation threshold. I want to be able to run more advanced ignition timing(if necessary to make more power). I want to have better idle quality and reduced emissions at idle while still having a decently large camshaft(see the emissions test results from last year below). I want to be able to drive around the car at obnoxiously low rpm when I don't need more power for better gas mileage. I want better acceleration under 2000rpm without going to a smaller camshaft. I want to be able to run even higher static compression with an even larger camshaft in the future, without giving up all of my low rpm drivability.
The head is now off, I just need to do the grooves after I figure out exactly how I'm going to do them and then put the head back on the car. I am NOT even cleaning the carbon build-up in the chambers or piston tops so it's a back to back comparison. Not changing the spark plugs(or their rotation). Nothing is being changed but the grooves and a fresh oil change. The oil that's in the engine now only has 2,000 miles on it and is clean still, barely darker than fresh.
Old 02-13-2018, 06:26 PM   #762
klr142
Turbo, what?
klr142's Avatar
Car's current spec:
-230k mile, original bottom end, never been touched and with some cylinder bore wear and very slight oil consumption. Full synthetic oil.
-Stock 530 cylinder head with low hours/mileage since rebuilding(was used on the General Leif for a while). Very mild port work. ~.032" shaved off of it. Untouched chambers.
-H camshaft advanced 2° with valve clearances initially set to ~.015" on the intakes and ~.017" on the exhausts.
-.036" MLS headgasket.
-87° C thermostat, stock cooling system with proper air guides.
-Stock b230F intake manifold, air filter and airbox with exhaust preheat routed to cold air and flapper removed.
-KGT/Timos Type 1 header with 44mm primaries and custom Type 3/51mm sized secondaries added. Shortened secondaries when compared to original header using Columbia River Mandrel Bending's tubing and merge.
-Custom 2.5" exhaust with a small Magnaflow spun/race cat, a small Magnaflow muffler for a resonator in stock location and a Dynomax Super Turbo(junk, just wanted it quieter but it really needs softer motor mounts) at the back.
-LH2.4 + EZK, various tunes including stock and not depending on what I want and the temperature and so on.
-Stock ignition components, NGK BPR7ES spark plugs.
-M47 transmission w/3.73 rear end(Trutrac diff).
-225/45-17 DWS 06 tires on Tethys.
-Full interior with added sound deadening and a 10" sub w/amp in the trunk.
-Chevron "Supreme" 92 octane gas, full tank.
Combustion chamber pictures after 12,000 miles since last cleaned/installed(sorry for size):
#1-3 look generally like this:
#4 has more build-up, maybe from oil burning? Maybe from #4 running hotter because it's at the back of the engine? Maybe because?
Old 02-13-2018, 10:30 PM   #763
klr142
Turbo, what?
klr142's Avatar
Performance:(more information to come)
Emissions testing from early 2017 with the same setup but the valves adjusted to .018/.020"(later checked at .020-.021" before resetting them to .015/.017" after passing DEQ)
Old 02-13-2018, 11:43 PM   #764
Quin
ಠ_ಠ
very curious to see the after chart.
Old 02-14-2018, 01:28 AM   #765
klr142
Turbo, what?
klr142's Avatar
Me too!
Old 02-15-2018, 06:13 PM   #766
klr142
Turbo, what?
klr142's Avatar
HMMM!
#4 is the old way of thinking and more tried and true Somender Singh groove variant(with various number of grooves on the larger quench surface). The swirl in the chamber supposedly goes opposite that groove towards the spark plug though, so options 2 and 3 may be better???
That being said, more modern OEM 2V heads look more like #1 with the quench pads even more gone, particularly on the exhaust side(tapered into the cylinder) and the spark plug unshrouded. I don't want to reduce my compression that much and make that large of a change on this iteration, though. This is more of a basic proof of concept attempt and then I'll go further with my big valve, ported head for the next setup.
Interesting info from Datsun L series heads:
"There are two main combustion chamber designs, commonly known as “open” and “closed,” or “peanut,” referencing the similarity of the closed-chamber shape to that of the typical peanut shell. Neither book referenced earlier really describes the differences in chamber design or why there are differences in the first place. Put simply, the open heads resulted in lower compression ratios. The open chamber design reduced hydrocarbon (HC) emissions for US offerings and did not do much else beneficial to the 510 enthusiast. With their lower compression the engines were tuned less aggressively and produced somewhat less emissions but as a result were less efficient and more susceptible to detonation.
The closed heads were designed with a good amount of quench area, the flat bottom of the cylinder head exposed to the combustion chamber. This quench area helps to add turbulence to the intake charge as the piston rises to TDC on the combustion stroke. This turbulence is beneficial because it helps to mix the air and fuel, providing a more homogeneous mixture and a stronger power stroke upon ignition. As typically the closed heads were fitted to engines with flat-top pistons to maximize the benefits of the closed-head design, there was minimal space between the top of the piston and the quench area (often just the thickness of the head gasket). The one downside of closed chambered heads is that the quench area can shield a small amount of the fuel from igniting, resulting in higher HC emissions. Thus the closed chambered heads were not selected for meeting USA emissions requirements."
https://en.wikipedia.org/wiki/Hemisp...ustion_chamber
Modern design at the bottom, basically spark plug is more in the chamber instead of being shrouded, the chamber is open with smaller quench pads and everything is tapered up. None of these vertical walls that Volvo has in the combustion chamber design from the '40s or whatever.
V8 high flow head:
http://d23c3kq2pqf30j.cloudfront.net...chief-2_lg.jpg
Erland's work:
http://www.topplocksverkstan.se/fyrtaktsid6.html
Motordesign:
http://www.motordesign.se/images/F%C...A4ningsrum.JPG
Etc..
Old 02-16-2018, 02:21 AM   #767
122power
dude
122power's Avatar
From what ive read on chamber readings you want it to be directed torwards the exhaust valve. Are you doing dimples on the clean chamber wall also?
Yeah the volvo chamber sucks for design.
Old 02-16-2018, 12:56 PM   #768
klr142
Turbo, what?
klr142's Avatar
Yes, directing towards the hot exhaust valve is suggested. I'm not doing anything with the chamber walls for now, just adding a single groove or three. Right now I'm leaning towards just doing a larger one on the main quench pad, thus leaving the rest of the chamber open to further modification in the future.
Old 02-16-2018, 03:43 PM   #769
gsellstr
gsellstr's Avatar
Seems like Option 2 might encourage swirl a little more than #3.
That said, what is this BS of doing a controlled test, before/after, numbers, etc.? It's hogwash around here, you know that. lol
/end TB mentality
I'm VERY curious to know what you find! I played with it years back when I swapped on a 530, seemed like it did help the detonation issue slightly, but that was purely SOTP impression. If you find something that does indeed help, I might go that route next time the 531 comes off.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-16-2018, 04:50 PM   #770
klr142
Turbo, what?
klr142's Avatar
Yeah!
Acutoff wheel to the cylinder head is a bit sketchy!!! That said, it gives a nice curved groove with no square edges. I then used a triangular file to open them up and will do a little more before it gets reinstalled. I'll also use rolled and/or folded emery cloth to smooth things a little further.
Last edited by klr142; 02-26-2018 at 07:27 PM.. Reason: Accidental post. Edited to add some mid-progress pictures.
Old 02-26-2018, 07:24 PM   #771
klr142
Turbo, what?
klr142's Avatar
Sorry the head is "upside down" in comparison to the previous pictures, but you get the idea. I may smooth the edges of the grooves a little bit more, but I'm basically done and just need to clean the head up for reassembly!
Old 02-26-2018, 07:29 PM   #772
doucheNozzle
How long did that take you?
Old 02-26-2018, 08:26 PM   #773
klr142
Turbo, what?
klr142's Avatar
The grooving process, probably 2-3 hours? Taking my time, being cautious and anal as usual. The cutting with the cutoff wheel took like 5 minutes. The filing and being anal with it took the longest. And cleaning up here and there.
Old 05-21-2018, 03:19 AM   #774
Pro Sneaker Peddler
Turned 30. Didn't slow down. Just for the record.
Just re-read through the first few pages. Good times.
Old 05-21-2018, 03:09 PM   #775
Any results from the grooving?
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
